Old Sep 17, 2011, 12:18 AM
wheelspinner20 is offline
Find More Posts by wheelspinner20
wheelspinner20's Avatar
S.E.Michigan
Joined Jul 2010
I have FRSKY DIY module with telemetry on order and when I install it will I need to re-flash with the FRSKY version...?
I know that usb chord is heavy, and always tangled, if you can find it, but yes, you will have to drag it out and make a couple mouse clicks. Drag I know, I have to do it too, to keep current with the latest revisions every 2 months... sucks for sure....
GO TIGERS A.L. Comedy Central Champs.!!!!!
wheelspinner20 is offline Find More Posts by wheelspinner20
Old Sep 18, 2011, 04:58 PM
Soljutin is offline
Find More Posts by Soljutin
Trollhattan, Sweden
Joined Aug 2004
Lights out... :(
Hi.
Does anyone know of any problem/fix on the smartieparts unit with the EL backlight not working after a while? I have the blue version and it worked just perfect when i first installed it, but now after just a few hours of using it, it does not light up anymore. I can barely see it glow if it's dark, so it seems
that it is working but there is almost no light. Is the EL panel worn out?
Soljutin is offline Find More Posts by Soljutin
Old Sep 18, 2011, 05:54 PM
s_mack is offline
Find More Posts by s_mack
Registered Loser
Canada, BC, Central Okanagan H
Joined Jun 2010
Open up the case... carefully connect a wire between GND and one of the two EL pins and briefly turn it on... does the light come on now?
s_mack is offline Find More Posts by s_mack
Old Sep 19, 2011, 08:59 AM
Fugbucker is online now
Find More Posts by Fugbucker
Fugbucker's Avatar
Australia, VIC, Hampton Park
Joined Feb 2011
I suspect this was probably an attempt at sarcasm but what I was asking was will this version work with the FrSky DIY telemetry or will I have to install the FrySky version...? I will not be using telemetry ATM...
Fugbucker is online now Find More Posts by Fugbucker
Old Sep 19, 2011, 09:08 AM
gohsthb is offline
Find More Posts by gohsthb
Naperville, IL
Joined Mar 2009
If you do the mod for the telemetry. Moving a couple of switch inputs to different pins on the main Tx board then yes you will need the frysky version, since it knows to look for the switches in a different spot and how to use the telemetry features. Otherwise if you are just using the Tx without mods then install the plain er9x version.
-Gohst
gohsthb is offline Find More Posts by gohsthb
Old Sep 19, 2011, 10:45 AM
razorseal is offline
Find More Posts by razorseal
razorseal's Avatar
United States, FL, West Palm Beach
Joined Nov 2010
So this board isnt plug and play with a frsky telemetry module or DIY kit. Some soldering is still required?
razorseal is offline Find More Posts by razorseal
Old Sep 19, 2011, 11:01 AM
gohsthb is offline
Naperville, IL
Joined Mar 2009
yes but it is the frsky mod that requires the soldering.
Old Sep 19, 2011, 11:02 AM
razorseal's Avatar
Joined Nov 2010
I see
Old Sep 19, 2011, 11:30 AM
Soljutin is offline
Trollhattan, Sweden
Joined Aug 2004
No i'm sorry, everything is like before. Any more suggestions?
Old Sep 19, 2011, 12:54 PM
s_mack is offline
Registered Loser
Joined Jun 2010
Ok, then its probably not what I thought it might be (ESD damaged EL driver chip).
Go through the EL troubleshooting guide to narrow down where the issue is (radio, programmer board, or EL panel)
Old Sep 19, 2011, 04:33 PM
S.E.Michigan
Joined Jul 2010
fugbucker. sorry for the humor yesyou will need the frsky version once the hardware mods are done.
p.
Old Sep 19, 2011, 05:00 PM
Soljutin is offline
Trollhattan, Sweden
Joined Aug 2004
Thank you for your great advises, and for the link to the troubleshooting guide.
I followed the guide and in test 2 i measured the AC volt between one of the EL pins and GND to only 49 volts (same on both pins), so i guess the board is broken. It does not matter so much as long as the firmware updating works, anyway i know now whats wrong.
Thank you for your help.
Old Sep 19, 2011, 07:06 PM
s_mack is offline
Registered Loser
Joined Jun 2010
That's a normal reading if the panel is connected. Abnormal if the panel is not connected.
Old Sep 20, 2011, 03:14 AM
Soljutin is offline
Trollhattan, Sweden
Joined Aug 2004
I understand, i tried to follow the guide exactly. I had the board taken out
and measured with the panel disconnected.
Old Sep 20, 2011, 08:11 AM
Fugbucker's Avatar
Joined Feb 2011
p.
Thanks for that 'Wheels'... I can look forward to that mod when I get the present system sorted... Thanks to you as well 'Gohsthb' Good info...
Download RCDeskpilot Add-on Planes In Post #1 UPDATED MARCH 7 2011 Wilfor Simulators 207 Nov 27, 2015 12:21 AM
Sold RealFlight G3.5 With Controller and Vol. 3 Add-On Rob02Aggie Aircraft - General - Miscellaneous (FS/W) 3 Nov 13, 2010 02:13 PM
Question Searching RC Car with transmitter having the pots NOT soldered directly on the board Nase Electric Power Cars 0 Nov 07, 2010 08:46 AM
Discussion Built-in-Balancer: Replace a 14.4 nihm pack with 5S LiFE leveraging original charger? coreyfro DIY Electronics 0 Nov 05, 2010 09:33 AM
