Old Jul 07, 2011, 03:10 AM
Orphee is offline
Find More Posts by Orphee
Joined Jan 2011
Originally Posted by knutek View Post
I have some other folks in my street that has ordered your super-board. When will they expect to have a radio like mine?
Extract from the webshop :
Update (June 29, 2011): OK, that didn't take long! We're already 3 units backordered and its only the first day after the batch arrived. I very much planned on being caught up by now, but that Canada Post strike really messed things up! Sadly, it will probably be about a month before the next batch arrives because now there is a problem with component availability. I don't have an exact ETA. As always, thank you for your patience!
Orphee is offline Find More Posts by Orphee
Old Jul 07, 2011, 12:34 PM
s_mack is offline
Find More Posts by s_mack
Registered Loser
Canada, BC, Central Okanagan H
Joined Jun 2010
Thanks Orphee.
The "best guess" ETA I've been given is "end of July". My plan really was to have stock on hand by the end of May, so nobody had to wait during the prime flying season... but so much for that. Demand was much higher than I expected, and there have been several problems (the strike, component availability, and most recently - a small but important mistake by the PCB manufacturer).
- Steven
s_mack is offline Find More Posts by s_mack
Old Jul 07, 2011, 04:43 PM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Delivery
I finally received my backlight which was omitted from my order of many weeks ago.
I can now fit it to the tx. When I find the time that is.
Thanks Steven!
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Old Jul 07, 2011, 05:17 PM
s_mack is offline
Registered Loser
Joined Jun 2010
You're welcome Jim. I'm still not sure how I managed to screw that up.
You weren't the only one either. Out of the batch of ~95... there were SIX complaints that I forgot to include the EL panel!! Its embarrassing While I'd love to blame it on someone else...
wait, yeah, that's it! It was... umm... let's go with "Tom". It was Tom's fault!
Tom's since been fired.
- Steven
Old Jul 09, 2011, 01:19 AM
Joined Aug 2008
User's guide
I have begun trying to set up a simple 2 axis glider in my ER programmed tx. I am not doing any good at all with. Well, I did manage to get a 2 channel chevron wing programmed to flying stage, but on the second one, I am totally lost. The manual, which is called more appropriately, a "guide" is not much help. It seems to be written for people who have prior knowledge of their way around the tx. set up. I don't.
When I choose a channel order like RETA in the "Templates" window, it does not seem to apply. Because then when I get to mixes, the mixes come up in a different order. When I try and change them, the templates entry changes back to something else! There is something very basic that I don't know and the manual, sorry- "guide" - does nothing to help. Should I be doing a save operation after each entry?
At one stage I did get two channels to work, but I made the mistake of plugging a third servo into the rx. to power spoilers and lost control of the elevator servo. The entries on the tx. window all appeared the same.
I found I was going around in circles, and reduced to trying to shuffle around the plugs on the rx. to see which channels were being powered up. The channels that were working appeared to have little relation to the indicated ones on the set up.
Can someone please help here?
Thankfully, I still have 2 reliable, and relatively simple old Futaba 8U tx's to go flying with tomorrow. I was hoping to one day set up a full house glider with camber, reflex and crow etc. on the 9x. with the eR software.
Pipe dreams, I am now thinking.
Jim.
p.s. Is the standard software more "user friendly"?
Old Jul 09, 2011, 02:09 PM
s_mack is offline
Registered Loser
Joined Jun 2010
Hi Jim... I see you also posted in the firmware thead, and that is the appropriate place for your question, not here. This is for help regarding the add-on board itself. Evidenced by the fact you successfully used the add-on board to flash new firmware, it is clear that your issue is with the firmware, not the add-on board.
But some general advice: open your mind to the new way of doing things... you'll love it eventually! The Er9x firmware is so many magnitudes better than the original, that you really shouldn't even be thinking about using the original. Is it more "user friendly"? perhaps... but its also crap. You can do so much more with er9x... you just have to wrap your head around it. Anyway, continue to ask for advice on that other thread. They've already responded to you many times. Its a very busy thread so you can get lost if you don't check back often... but they are VERY helpful. Don't worry... you'll get it. And you'll love it.
- Steven
Old Jul 09, 2011, 03:53 PM
Joined Aug 2008
- Steven
You are right Steven, it is a software/firmware problem I have not a hardware problem. Actually, I am hoping it is neither and is actually an operator (me) problem! Apologies for posting on this thread instead of the other one.
And thanks for the encouragement. Your appraisal above echoes many that I have read, if not all. I hope that I can soon join the "chorus" of fans for the software. I'll go over to the other thread.
Jim.
Old Jul 09, 2011, 04:11 PM
wheelspinner20 is offline
Find More Posts by wheelspinner20
wheelspinner20's Avatar
S.E.Michigan
Joined Jul 2010
Some have posted that even when it is installed properly and working properly, the el backlight is not bright enough. This was my FIRST impression also, but having just recently installed good lights on my Polaris, and flown at a field where there in NO ambient light, I must say that the backligt is perfect, its bright enough to clearly make changes and check timers, and trim positions, and model changes. And it is not TOO BRIGHT to diminish the improved night vision that one gets as their eyes adjust to the relative darkness.
I am more than pleased with the product, and will be purchasing another soon for a 2nd 9x radio.!
Pat
wheelspinner20 is offline Find More Posts by wheelspinner20
Old Jul 10, 2011, 08:44 PM
Joined Aug 2008
Backlight not working.
I finally installed my backlight. It doesn't work! I pulled it out and turned it around and tried thinking I must have interpreted the instructions incorrectly, but it still doesn't light up.
I might live without it. This is taking up too much valuable building time!
Jim.
Old Jul 10, 2011, 08:54 PM
s_mack is offline
Registered Loser
Joined Jun 2010
EL troubleshooting tips are here: http://www.rcgroups.com/forums/showthread.php?t=1432042
- Steven
Old Jul 11, 2011, 07:39 PM
Joined Aug 2008
stubborness
I made one final (stubborn) attempt at getting the backlight working successfully! I am guessing it would have been a poor pogo connection. My tx. came with several stripped screws including two of the ones holding the add-on board in place. I found replacement screws that hold for the main case, but have not yet found 2 for the board. This was likely the problem, and may be again.
So at long last, my ER9x with backlight is all functional! Thanks to all.
Jim.
Old Jul 12, 2011, 04:41 AM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
Jim.
I wish I could be so lucky. Mine still refuses to function...
WimH is offline Find More Posts by WimH
Old Jul 12, 2011, 05:07 AM
GrootWitBaas is offline
Find More Posts by GrootWitBaas
I don't speak German ....Yet !
GrootWitBaas's Avatar
Germany, Baden-Württemberg, Weissach im Tal
Joined Dec 2010
Maybe I can help / Assist you to get it working ?
GrootWitBaas is offline Find More Posts by GrootWitBaas
Old Jul 12, 2011, 07:11 AM
WimH is offline
WimH's Avatar
Joined Dec 2001
I'm almost sure it's a bad contact from the pogo pin. Just not sure what to do next to try and improve,I'll probably unscrew the whole board again and try putting it back "better". But I already did that several times and now I'm afraid to loose the flashing functionality (took me 3 tries already to get that working).
On the positive side, I've found a "solution" for the intermittent aileron non-functionality, but that has nothing to do with the board. After the flying season I'll see to the back-light with my "electronic friend".
Old Jul 12, 2011, 07:58 AM
Joined Dec 2010
Ok, If you need help feel free to ask. Cleaning the pads helps, some boards have a coating on some of those pads. Most of the points is covered in Stevens guide on the backlight (linked above in his post)
Download RCDeskpilot Add-on Planes In Post #1 UPDATED MARCH 7 2011 Wilfor Simulators 207 Nov 27, 2015 12:21 AM
Sold RealFlight G3.5 With Controller and Vol. 3 Add-On Rob02Aggie Aircraft - General - Miscellaneous (FS/W) 3 Nov 13, 2010 02:13 PM
Question Searching RC Car with transmitter having the pots NOT soldered directly on the board Nase Electric Power Cars 0 Nov 07, 2010 08:46 AM
Discussion Built-in-Balancer: Replace a 14.4 nihm pack with 5S LiFE leveraging original charger? coreyfro DIY Electronics 0 Nov 05, 2010 09:33 AM
