Old Apr 28, 2011, 12:02 PM
WimH is online now
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
I applied the fixes already, tried plugging in/out, no difference...
When using the -F parameter as suggested, I get this:
Started AVRDUDE
/usr/bin/avrdude -c usbasp -p m64 -F -P avrdoper -U eeprom:r:/tmp/temp.hex:i
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x000000
avrdude: Yikes! Invalid device signature.
avrdude: Expected signature for ATMEGA64 is 1E 96 02
avrdude done. Thank you.
AVRDUDE done - exit code 1
WimH is online now Find More Posts by WimH
Old Apr 28, 2011, 01:05 PM
gohsthb is offline
Find More Posts by gohsthb
Naperville, IL
Joined Mar 2009
Ok sounds like the board needs to be reseated or something. I left the relevant error line above. As it says it does not think the target is communicating. This means that the software can contact the programmer just fine. But the programmer cannot contact the atmega64. S_mack somewhere has directions or tips on what to look for. I know some of them were:
1. try reseating the board. i.e. loosen the screws and wiggle it then tighten the screws back down.
2. make sure the screws are tight and the board is all the way down.
3. check that the pogo pins are straight
4. check for plastic caps on the ends of the pogo pins
5. clean the pads on the atmega board. Some boards seem to have a coating applied to them.
gohsthb is offline Find More Posts by gohsthb
Old Apr 28, 2011, 01:10 PM
s_mack is offline
Find More Posts by s_mack
Registered Loser
Canada, BC, Central Okanagan H
Joined Jun 2010
That about covers it. Just caution that screws shouldn't be over-tightened. Gently press down on the board near the screws... if the board moves (ie. a gap is formed between the board and the screw head) then tighten it to take up the slack.
s_mack is offline Find More Posts by s_mack
Old Apr 28, 2011, 04:03 PM
WimH is online now
WimH's Avatar
Joined Dec 2001
Yeah, that seems to make sense. Board is tight with no slack, pins were straight, so cleaning seems to be the only option...Hope that will help.
Old Apr 28, 2011, 05:41 PM
BillyP52 is offline
Find More Posts by BillyP52
BillyP52's Avatar
United States, CA, Arcadia
Joined Jul 2010
EL Backlight not working
Hi all
I got my programmer board installed Monday night, flashed the firmware with no problem and reinstalled the original just to make sure I could. Everything works flawlessly except for the Backlight...it does not want to work. I have done the following:
Turned on light in er9x to use throttle switch, then rudder switch, and then turned on auto with 10 sec delay
Unplugged and replugged into the programmer board with the plug up and down (I know it does not matter, but it was one more thing I can rule out)
Uninstalled and reinstalled the programmer board and backlight - both white side up (towards foam) and white side down (towards glass).
Can anyone direct me on what to do next....I love the programmer and this is just a little annoyance I can live with if I have too
Bill P
BillyP52 is offline Find More Posts by BillyP52
Old Apr 28, 2011, 07:36 PM
donglass is offline
Find More Posts by donglass
Joined Jul 2005
BillyP52
I had the same problem, s_mack sent me a fault-isolation procedure with pics (Steven - might be a good idea to post it, maybe here, or on your website, if it's not already posted?) My problem was a pin wasn't quite seated perfectly, or it was dirty. Cleaning the pins & re-seating the board solved the problem. The particular pin/pad is pretty small so I think it's easy to get misaligned. Try it (might take a couple more tries?), and I'll bet it'll start working.
Don
donglass is offline Find More Posts by donglass
Old Apr 29, 2011, 12:23 PM
s_mack is offline
Registered Loser
Joined Jun 2010
You're right... I should post it. I've answered the same question so many times lol.
I'll get on that. I'll write up a new blog entry specific to troubleshooting the EL and I'll post a link here when I'm finished.
- Steven
Old Apr 30, 2011, 12:44 AM
s_mack is offline
Registered Loser
Joined Jun 2010
Whew! OK, finished with the EL troubleshooting guide.
- Steven
Old Apr 30, 2011, 07:20 AM
Firefox675 is offline
Find More Posts by Firefox675
Firefox
Firefox675's Avatar
USA, KS
Joined Oct 2005
Originally Posted by s_mack View Post
What you're going to be doing is using your chosen software (I recommend eePe) to backup your firmware via my hardware. Make sense?
- Steven
Yes it does.
thanks
Firefox675 is offline Find More Posts by Firefox675
Old May 07, 2011, 02:15 AM
ciulinm is offline
Find More Posts by ciulinm
Romania, Ilfov, Corbeanca
Joined Mar 2011
Hi Steven,
What is the ETA of your new batch.
Thx
Mircea
ciulinm is offline Find More Posts by ciulinm
Old May 07, 2011, 03:35 AM
s_mack is offline
Registered Loser
Joined Jun 2010
should be around the 15th
Old May 08, 2011, 10:00 AM
showmaster is offline
Find More Posts by showmaster
showmaster's Avatar
Joined Aug 2006
- Steven
Steven, something to add to the
"Uh-oh: its my EL panel" section!
Both of my recent (2) board orders had EL panel intermittent connections after installation and er9x flash. I narrowed it down to the EL panel connector connections on the[
panel wires. In my case the wires are attached by forcing them into the connector groves, telephone punch down style, not soldered. The symptoms gave the illusion that the wires may be bad at the EL panel "pads" but because of the wire stiffness and being short, it was not the case. The fix for both was simple and effective once I diagnosed it I just pulled the wires out of the connector, cut off 1/16 of an inch and pushed them back into the connector slots/groves with the tip of a small thin bladed screwdriver (carefully). Now both panels are rock solid and working again! I suspect that just installing them may be enough to cause this condition for some?
I hope this will help others before they get too deep into trouble shooting their panel not lighting.
Showmaster
showmaster is offline Find More Posts by showmaster
Old May 08, 2011, 02:33 PM
s_mack is offline
Registered Loser
Joined Jun 2010
I did test each one, but overall I don't think that IDC connector was a very good choice. The next batch is getting a different connector entirely and hopefully it works more reliably. Thanks for the feedback.
Old May 08, 2011, 04:19 PM
ScottSails is offline
Find More Posts by ScottSails
Balsa addiction since age 3
ScottSails's Avatar
Upstate NY
Joined May 2005
I have to provide input on this firmware....
It is amazing... I fly a lot of converted sailplanes to electric. Almost all of these have a huge pitch up motion under full throttle (can only put in so much down thrust). With the ability to mix in down elevator to throttle to a curve of MY liking, it makes these so easy to control. The second thing is that the controls become sensitive while under power, having triple rates that vary with throttle position (I use something like 40, 75 pct) condition again makes this so nice. My original intent was to change the firmware to put in variable rates (as a function of throttle) - but I really don't need to as a result of this. Also, the expo (assign to each rate) really makes this just so nice.
I will say the EEPE is awesome and makes the visualization so much better. I have only used this transmitter on my test mule so far, but really like what I see. Too bad the quality of the 9x is a little rocky (really poor interconnect soldering) or I would recommend this to more people without hesitation.
I have also done the trustfire 2400mah li-ion (protected cell) mod (2 cells as I use Fly Dream) and the radio is just so light compared to my other transmitter (Hitec with 8 cell nicad). For those interested, I get over 11 hours of actual transmit runtime (with backlight on, I stopped it at 7.1V, so there is more runtime).
I suspect I will provide more feedback as I attempt to wear this unit out this summer
Really nice job Erazz!
And I would be remiss if I didn't thank s_mack as that board made it SO easy to install the firmware.
ScottSails is offline Find More Posts by ScottSails
Old May 08, 2011, 05:43 PM
wallaguest1 is offline
Find More Posts by wallaguest1
wallaguest1's Avatar
Joined Nov 2006
what is the power consumption of the backlight when on ?
wallaguest1 is offline Find More Posts by wallaguest1
Download RCDeskpilot Add-on Planes In Post #1 UPDATED MARCH 7 2011 Wilfor Simulators 207 Nov 27, 2015 12:21 AM
Sold RealFlight G3.5 With Controller and Vol. 3 Add-On Rob02Aggie Aircraft - General - Miscellaneous (FS/W) 3 Nov 13, 2010 02:13 PM
Question Searching RC Car with transmitter having the pots NOT soldered directly on the board Nase Electric Power Cars 0 Nov 07, 2010 08:46 AM
Discussion Built-in-Balancer: Replace a 14.4 nihm pack with 5S LiFE leveraging original charger? coreyfro DIY Electronics 0 Nov 05, 2010 09:33 AM
