Canada, BC, Central Okanagan H
Joined Jun 2010
But let's back up anyway and define "V1" and "V2". Turnigy uses that term, but what does it really mean? They have sold V1 hardware as "V2" simply because it had an updated version of the stock firmware. No doubt, the firmware is probably on V204 or so, so there's no real correlation between the firmware version and the hardware version, which is what I think most people refer to when they say "v1" or v2". Unfortunately, you CAN'T go by what the retailers use when they sell the product! I think its safe to say that any radio purchased recently... it is V2. But the only way to tell is to open up the radio and take a look. If by "visual difference" you mean appearance from the outside... there is no difference at all. If you mean by what you see on the screen... its an impossible question to answer because that depends on the firmware which has nothing to do with the hardware version. If you mean look of the circuit board... see the link I posted on the other form (here it is again) - Steven |
So the "9x Add-on Board with built-in Programmer and EL Backlight" can be used with either version ? Oh and thanks for the link to your site. I looked at the information there and it looks like the add-on board will work on the earlier version. But will the newer firmware ? Thanks for the info |
Joined Jun 2010
For V1 with my board you have to solder a connection differently. Provided you can hook a programmer up (my board or otherwise) then it doesn't make a difference in terms of firmware. You can use any firmware on any version. |
[QUOTE=s_mack;18053167Provided you can hook a programmer up (my board or otherwise) then it doesn't make a difference in terms of firmware. You can use any firmware on any version.[/QUOTE] That's what I wasn't sure of. Thanks for the response |
================================================== =============================== Started AVRDUDE /usr/bin/avrdude -c usbasp -p m64 -U eeprom:r:/tmp/temp.hex:i ================================================== =============================== avrdude: Warning: cannot query manufacturer for device: error sending control message: Operation not permitted avrdude: error: could not find USB device "USBasp" with vid=0x16c0 pid=0x5dc ================================================== =============================== AVRDUDE done - exit code 1 ================================================== =============================== help? edit: after setting the port to USB in the config file it's a little better: ================================================== =============================== Started AVRDUDE /usr/bin/avrdude -c usbasp -p m64 -P usb -U eeprom:r:/tmp/temp.hex:i ================================================== =============================== avrdude: error: programm enable: target doesn't answer. 1 avrdude: initialization failed, rc=-1 Double check connections and try again, or use -F to override this check. avrdude done. Thank you. ================================================== =============================== AVRDUDE done - exit code 1 ================================================== =============================== so I guess the beeps mean something is wrong, but what? |
It probably says on this forum or yout web site, but I'll ask here anyway, with your system can the original FW be saved ? |
Joined Jun 2010
The beeping is normal. That's your radio's original firmware telling you that the voltage is below 9v or whatever its set to. Which it is, since USB only provides 4.7v. That's the point of this kit, to install custom firmware which, as one of its many benefits, allows you to change the alarm level and/or shut it up.
Anyway, it looks like your problem is that you haven't yet installed the drivers on your computer. Or (if you have installed drivers) that the programmer isn't being recognized (bad cable is one possibility). So let's back up. Have you installed drivers yet? And are you using Windows? What version? |
Joined Jun 2010
- Steven |
Joined Jun 2010
Right... well... Linux. OK, for that I'm going to be useless in helping you so hopefully someone else can. I don't know how hardware is recognized in Linux. From your error though, it appears your computer isn't aware that the programmer exists so you'll have to correct that.
- Steven |
Naperville, IL
Joined Mar 2009
| Thread Tools | |
| Download RCDeskpilot Add-on Planes In Post #1 UPDATED MARCH 7 2011 | Wilfor | Simulators | 164 | Apr 22, 2013 10:48 PM |
| Sold RealFlight G3.5 With Controller and Vol. 3 Add-On | Rob02Aggie | Aircraft - General - Miscellaneous (FS/W) | 3 | Nov 13, 2010 02:13 PM |
| Question Searching RC Car with transmitter having the pots NOT soldered directly on the board | Nase | Electric Power Cars | 0 | Nov 07, 2010 08:46 AM |
| Discussion Built-in-Balancer: Replace a 14.4 nihm pack with 5S LiFE leveraging original charger? | coreyfro | DIY Electronics | 0 | Nov 05, 2010 09:33 AM |
