Old Jan 14, 2011, 01:17 PM
erazz is offline
Find More Posts by erazz
erazz's Avatar
United States, NJ
Joined Jun 2004
What happens when you try reading the eeprom with eePe? Can you post the output?
What's in the "AVRDUDE Location" line in the burn->configure dialog?
erazz is offline Find More Posts by erazz
Old Jan 14, 2011, 01:26 PM
draconis is offline
Find More Posts by draconis
USA, IA, Altoona
Joined Oct 2009
That was it!
the AVRDUDE Location was the problem. it seems that it changes with opening an eeprom file from another folder... seems to change default directory when re-launched
thanks erazz!
draconis is offline Find More Posts by draconis
Old Jan 14, 2011, 02:34 PM
erazz is offline
erazz's Avatar
United States, NJ
Joined Jun 2004
Errrm no... It really shouldn't change.
It's on a different value.
But I'm happy it works now!
Old Jan 14, 2011, 05:42 PM
draconis is offline
USA, IA, Altoona
Joined Oct 2009
Originally Posted by Pisces View Post
... I have the FrSky RF telemetry module. So also hoping that the telemetry serial link can get status information integrated onto the 9x LCD. I'm flying planes and gliders and have started to get into FPV.
...Lindsay
Can the FrSky telemetry connector attach to the 9x addon board? USB?
Seems like a great way to get the data in to the unit...
Old Jan 14, 2011, 05:44 PM
s_mack is offline
Find More Posts by s_mack
Registered Loser
Canada, BC, Central Okanagan H
Joined Jun 2010
[Post deleted... I didn't realize there was another page of posts and you got it sorted out]
s_mack is offline Find More Posts by s_mack
Old Jan 15, 2011, 06:40 AM
rcpaintworks is offline
Find More Posts by rcpaintworks
The art of airbrush
Österreich
Joined Jul 2010
Postman brought a little box from Canadian Steve. Loaded SW from erazz, plugged in the board, flashed my 2 TX9's and....
15min later - all perfect, as hoped. Thanks a lot for your hard work guys!!
Only downside: HK seems to never get a positive stock level on these super (cheap) transmitters in a foreseeable future....
rcpaintworks is offline Find More Posts by rcpaintworks
Old Jan 15, 2011, 07:01 AM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Just put in a back order for this item alone. That will get you in the queue. As long as demand exceeds supply, this is the only way to buy one from HK.
Right now they are showing -118 as stock level for the mode 1 version. Add the Tx to your wish list and you will thereby be able to track the exact level as it changes.
By the way, it's an easy job to convert mode 1 to mode 2 or vice versa.
Daedalus66 is offline Find More Posts by Daedalus66
Old Jan 15, 2011, 08:23 AM
The art of airbrush
Österreich
Joined Jul 2010
Thanks for the kind suggestions: That's nearly exactly what I did. Got a Mode 2 after backordering it. Was one with the dead flash. Got mail in the morning some time later for Mode 1 in stock. Orderd 1 and converted to mode 2. Now with progger both become perfect.
Old Jan 15, 2011, 04:32 PM
wheelspinner20 is offline
Find More Posts by wheelspinner20
wheelspinner20's Avatar
S.E.Michigan
Joined Jul 2010
Captain, what did you mean by this? You mean it did not work at all? as delivered by HK??
Or it sort of worked but not correctly?
Just curious.
Pat
wheelspinner20 is offline Find More Posts by wheelspinner20
Old Jan 15, 2011, 05:27 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Just curious.
Pat
There was a batch a while ago that produced a faulty display. The cure was to replace the firmware. He now has the ability to do that.
Old Jan 16, 2011, 04:57 AM
Daniel N is offline
Find More Posts by Daniel N
Joined Jan 2011
hello everybody,
first, excuse my bad english, i´m german.
I have a fix for every EL, that doesn´t work.
just put a piece of Shrink-tubing over the contacts, where the cables are soldered (see red circle here):
Sry for bad quality, its just my old mobile phone cam
With this fix, i got 2 bad ELs working
I think, these contacts don´t connect rightly between the wires and the EL.
and inr more question to erazz:
which lipo do you use in yout transmitter? In the first post it looks like a small 2S-Lipo from HK, but which exactly?
Greetings from Germany,
Daniel
Daniel N is offline Find More Posts by Daniel N
Old Jan 16, 2011, 05:20 AM
erazz is offline
erazz's Avatar
United States, NJ
Joined Jun 2004
I use a 2S 1300mah Turnigy pack. NOT RECOMMENDED! It doesn't fit properly.
There are better packs out there - worth researching.
Old Jan 16, 2011, 07:43 AM
draconis is offline
USA, IA, Altoona
Joined Oct 2009
Speaking of lipo batteries... I just happen to reverse the bat connector and bam, blew up the processor board I already (back)ordered a new one, but does anyone know if there is a source for replacement board for a HK turnigy 9x?
or do i now have spare parts
Old Jan 16, 2011, 09:42 AM
erazz is offline
erazz's Avatar
United States, NJ
Joined Jun 2004
When you do that you usually blow the 7805 and a capacitor. The replacement is really simple.
Use a voltmeter to check the voltage across your 7805. If it's zero then it's blown. Just replace it with a normal one.
Old Jan 16, 2011, 01:25 PM
electro_heli is offline
Find More Posts by electro_heli
CALIFORNIA
Joined Jan 2005
Hi All,
Installed EL back-lit kit and er9x firmware.
Everything seems to be working as expected and I am playing with the new firmware.
Meantime the usb header came off the small board. I tried to solder it back on and in the process I think I burned the trace on the board. And it is not communicating.
Question @s_mack
Is it possible to order usb board (with the 4 pin connector) separately?
Thanks for your help
electro_heli is offline Find More Posts by electro_heli
Download RCDeskpilot Add-on Planes In Post #1 UPDATED MARCH 7 2011 Wilfor Simulators 207 Nov 27, 2015 12:21 AM
Sold RealFlight G3.5 With Controller and Vol. 3 Add-On Rob02Aggie Aircraft - General - Miscellaneous (FS/W) 3 Nov 13, 2010 02:13 PM
Question Searching RC Car with transmitter having the pots NOT soldered directly on the board Nase Electric Power Cars 0 Nov 07, 2010 08:46 AM
Discussion Built-in-Balancer: Replace a 14.4 nihm pack with 5S LiFE leveraging original charger? coreyfro DIY Electronics 0 Nov 05, 2010 09:33 AM
