Espritmodel.com Heli Air
This thread is privately moderated by Sandancer, who may elect to delete unwanted replies.
Old Nov 14, 2010, 01:20 AM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
F4U Corsair: 1-Piece Wing
Now that the flaps are done, the servo sockets cut, the wiring ran for the Nav lights, and the holes cut for the Ma Duece guns, it's was time to glue the 2 wings together and make them a 1-Piece unit.
Because of the gull wing configuration, I picked to spots, one aft and one forward (as illustrated in thumb #1). I utilize (2) .3940" O.D. CF Tubing for spars, (1) 4" long for the aft location and (1) 8" for the LE location. To line up the holes on both halves I cut 2 pieces of 3/8" X 1/2" brass tubing and pressed them in the chosen location on one of the wings. I then lined the other wing up and squeezed the two together to leave an indexed impression in both wings. Knowing I was going to be using Gorilla glue with it's expansion properties, drilling the (4) 3/8" holes in the two wing halves didn't have to be in perfect alignment, but I did manage to get that process done to my satisfaction.
I then cut a 1/8" ply plate 2 1/2" X 3 5/8" to go in the base of the box for additional reinforcement and to serve as a foundation for the velcro I would use to secure the electronics I plan to mount in there.
After applying the GG in the spar channels and wing mating surfaces I secured the wings back on the fuse to insure a perfect alignment. To help corral the GG I ran some tape down the seams of the wings to subdue the GG expansion, and also put a strip of tape on the fuse to prevent any glue expansion from seeping out and sticking the two together.
I then did the proverbial 2 hour wait for the glue to dry. Once the glue was dry enough I removed the wings and applied the 1/8" X 2 1/2" X 3 5/8" plate in the base of the box on the inside of the wings.
I used 2 SS Socket Head Cap Screws 4-40 x 3" in the two front wing clamps, and 2 SS Socket Head Cap Screws 4-40 x 2" in the aft clamps.
This was a relatively easy mod to do, and will alleviate the stress of trying to transport the Corsair in the back seat!
Sandancer is offline Find More Posts by Sandancer
Old Nov 15, 2010, 09:13 AM
Hink64's Avatar
Cape Coral, Fl
Joined Jan 2010
Gear covers
Hey Gary,
I had these templates that may or may not be a cool addition to your Corsair - thought I would pass these on.
Tom
Hink64 is offline Find More Posts by Hink64
Old Nov 16, 2010, 12:35 AM
"Auntie Samantha"
Sandancer's Avatar
USA, MO, Clever
Joined Dec 2009
Originally Posted by Hink64 View Post
Hey Gary,
Tom
Thanks Tom! I am nuts about detail so I might find a use for those.
Old Nov 20, 2011, 10:45 AM
struggleforlife's Avatar
Nederland, GE, Nijmegen
Joined Feb 2011
wrong thread. sorry.
struggleforlife is offline Find More Posts by struggleforlife
Wanted Parkzone F4U Corsair wing Sniperone Aircraft - Electric - Airplanes (FS/W) 0 Oct 13, 2010 12:09 AM
Found wanted top flite f4u corsair wing kit .60 size spud nut Aircraft - Fuel - Airplanes (FS/W) 4 Sep 15, 2010 08:37 AM
Found NICK ZIROLI F4U-1 Corsair Wing or Wing Plans DaOldGuy Aircraft - Fuel - Airplanes (FS/W) 1 May 24, 2010 08:58 AM
Found NICK ZIROLI F4U-1 Corsair Wing or Wing Plans DaOldGuy Aircraft - Fuel - Airplanes (FS/W) 0 May 19, 2010 10:53 AM
