Old Jul 14, 2003, 10:34 PM
maverick is offline
Find More Posts by maverick
maverick's Avatar
SF Bay Area, Ca
Joined Dec 2001
Graupner Speed 480 Race Break-In & Other Newbie Q's!
Well I posted this in the 'Training' forum, thinking that it would be the best place for newbie type questions, but obvioulsy it isn't, as I have had virtually no response. So I think I will stick to the Jets forum and tap all of the extensive knowledge that I know exists in here.
I am new to 'E' flight, but not new to RC as I have been flying glow planes for about three years now. I have always wanted to get into jets but did not want to spend the money required for Glow Ducted Fans or Turbines. So I have decided to give electric jets a go.
I am not totally new to the theory of electrics, as I was into electronics when I was younger, so know my way around a soldering iron and understand what Volts, Amps, Watts, Ohms etc. are and how they relate to each other.
Right now I have purchased an Alpha Jet EDF profile jet and all of the Hobby-Lobby recommended accessories.
So I have a Graupner 'Speed 480 Race' motor and want to know whether I should do any break-in for this motor? I have read the FAQ and see where it described break-in, but the instructions that came with the motor say no break-in is necessary. So what gives? Break-in or not? I want the best possible performance out of this thing!
Also I bought the recommended 10 Cell CP-1300 SCR Nicad Pack and it dosn't have any conectors on the leads. Do all batteries come without connectors?
I purchased a 'banana plug to Speed 400 connector' charge lead, so I can charge the pack with my Super Turbo charger, so I am guessing I should buy two sets of Speed 400 connectors to solder to the battery and the ESC leads. Is this right?
I see the ESC I purchased and which was recommended, the Jeti 18 Microprocessor ESC is rated for up to 18 Amps, I also see from my research that the Speed 400 connectors are rated to 20 Amps, so I am guessing this is the way to go. Correct?
Lastly I have decided to solder the leads on motor side of the ESC directly to the motor. Is there anything I should watch out for when doing this? When I first looked at the back of the motor it was hard to see where I should solder the leads to. But I think I have it now and can definitely see the +ve and -ve signs and I can also see where the capacitors are soldered to the motor. So I am going to solder the ESC leads direct to the same place where the capacitors are soldered, taking into consideration the polarity. Is this right?
Is there anything else I should look out for?
Sorry this has beocme so long, but I want to get this thing in the air by next weekend. Thanks.
maverick is offline Find More Posts by maverick
Old Jul 15, 2003, 12:01 AM
Daren is online now
Find More Posts by Daren
Daren's Avatar
Los Alamos, NM, USofA
Joined Nov 2000
Re: Graupner Speed 480 Race Break-In & Other Newbie Q's!
Originally posted by maverick So I think I will stick to the Jets forum and tap all of the extensive knowledge that I know exists in here.
Hmmm, for whatever that's worth.
Performance costs money no matter which one you choose. Like the old saying, "How fast do you want to go? How much money do you want to spend?"
Usually, it's best to follow the manufacturer's recommendation. You break in brushed motors to fully seat the brushes. The SP480R's brushes are mostly seated anyway, hence the requirement for a minimal break-in.
Which fan unit did you buy? I thought 8 was the maximum recommended cell count for that motor. Did HL recommend this?
Depends who you bought the battery pack from. Some do, some don't, and some ask you what kind of connector you want (if any). Most flyers have personal preferences as to what type of connector to use and why.
I'm not sure what you're referring to here. You don't want to hard wire the battery or the charger, so buy as many connectors as necessary to be able to remove the battery for charging and solder the rest.
For a lower power set up, yes. Higher power? No. I like to give myself a comfortable margin so that the equipment and wiring is rated higher than the system I'm putting it in is. In this case you should be okay. An Astro Flight Super Whattmeter is a good investment to keep the guessing to a minimum.
Try not to drop solder into the motor (but you already knew that, right? ). Just follow each manufacturer's recommended wiring scheme and you should be okay.
Be careful! You'll need to watch out that you don't get hooked and start spending some serious money!
Seriously, I would do a careful range check; both power off and power on. If there's any jitters, try to find the cause before flying the model.
Generally, try to keep the radio system as far from the power system as practical. Don't go hog-wild, but sometimes a jitter can be caused or cured by the routing of the wires.
Expect moderately short motor runs (4-6 minutes). Find out how long your run it before the first flight and set a timer. Jets don't usually glide too good (or far-- Most will glide as far as your car keys!).
Some do and some don't recommend ESCs with BEC. I'm a "don't." I agree with Dr. Jet when he says, "BECs usually turn into PECs (Plane Eliminator Circuits )." You'll have to do what your insides tells you to do.
You're welcome and good luck! And remember, don't get in a hurry. If it doesn't fly next weekend, there's always another day. It's easier to fix a minor problem and bring it back, than to have to repair a crashed model and fix the problem that caused it!
Daren
Daren is online now Find More Posts by Daren
Old Jul 15, 2003, 12:21 AM
maverick is offline
maverick's Avatar
SF Bay Area, Ca
Joined Dec 2001
Re: Re: Graupner Speed 480 Race Break-In & Other Newbie Q's!
Well when you consider a starter turbine setup is about USD$4k and a decent glow ducted fan setup about USD$2k, I am thinking if I can get good performance from a USD$1k investment I will be happy! Am I in the ball park?
OK. I understand the theory of the brushes seated on the commutator and with the flat bottom of the brushes and the curved surface of the commutator there needs to be some break-in to allow a proper fit. How much, if any break-in is already done on a new motor?
Vasafan 65/1G.
The 10-cell pack is as sold by Hobby-Lobby. I know this is a 7.2V motor and 10 cells will give me a nomnial 12V so I am guessing the life of the motor won't be too long! Right?
What I mean is I have a set of leads that have banana plugs on one end (Super Turbo) and Speed 400 connectors on the other end. I am assuming I should solder Speed 400 connectors to both the battery leads and ESC leads. This way I can disconnect the battery and plug it into the charger. Nothing will be hard wired except for the ESC to motor leads.
Well I already have an expensive Fluke Multi-Meter so I guess it will suffice. But I will check this unit anyway to see if it does anything my Fluke doesn't.
Hehe! Yeah I guess a drop of solder inside the motor wouldn't be real good!
Yeas, this is a standard practice, even with 'glow' planes. Nothing strange here, except that there will probably be more chance for radio interference due to the extra electrics.
Thanks for the tips. Good stuff to get me going.
Old Jul 15, 2003, 12:25 AM
maverick is offline
maverick's Avatar
SF Bay Area, Ca
Joined Dec 2001
Re: Re: Re: Graupner Speed 480 Race Break-In & Other Newbie Q's!
I just pulled out my Fluke multi-meter and see it only measures up to 2A which I know will not be enough. It does measure up to 1000V DC though....Hehe!
That Astro Flight Super Whattmeter does look good. Seems to have decent specs which should cover pretty much all of the intended uses.
Anybody else use one of these?
Old Jul 15, 2003, 03:58 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Whattmeter is a "must". Dont get the Super one unless you intend to spend your whole Eflight carreer on low amp/power setups. The "Super Whattmeter" is for low power checking, regular Whattmeter for "all".
a $1k EDF will give you good power, though some single unit EDF's can approach $1,5k.
10cells on the s480BB isnt a problem I think because the Vasa fan has a light load. Say the motor is good for 150W, having 10cells resulting in a 15A draw or 8cell giving 20A isnt much different. Its the total power that in most cases dictate motorlife.
As with most entry level gear you'll outgrow it quickly if you find yourself enjoying EDF's. The AlphaJet however will easily house higher powersetups when you feel the need to upgrade.
Break-in, run for a while on 3V with no prop/fan in the intended direction.
Standarize on your connectors/plugs, use gold coated ones.
Good luck!
Haldor
www.halair.com
Haldor is offline Find More Posts by Haldor
Old Jul 15, 2003, 08:52 AM
Daren is online now
Daren's Avatar
Joined Nov 2000
Huh?
Respectfully, I submit this from Astro's website:
"Super Whattmeter
Designed for speed 400 models to quarter scale. Reads battery current from 100 ma to 75 amps, voltage from 4 volts to 80 volts, power up to 5000 watts, Milli amp hours up to 9000 mahr."
They may have changed this since your last visit. I believe you're referring to the Mircometer:
"Designed for indoor models and small park flyers. Reads battery current from 10 ma to 10 amps, voltage from 4 volts to 16 volts, power up to 160 watts, Milli amp hours up to 5000 mahr."
Daren
Old Jul 15, 2003, 09:48 AM
Haldor is offline
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
I stand corrected When I got mine there was only one version and I mistakenly thought the micrometer was called "Super"...
Old Jul 15, 2003, 10:27 AM
Daren is online now
Daren's Avatar
Joined Nov 2000
I think you're correct about them changing the names. I'll have to look when I get home to see by what name they're calling the one I have.
Whatt I don't understand, is why if they're the same price, would someone buy the Micrometer when the Whattmeter does so much more. One of the mysteries of the universe I suppose.
Daren
Old Jul 15, 2003, 06:17 PM
maverick is offline
maverick's Avatar
SF Bay Area, Ca
Joined Dec 2001
Yes, I have already added this to the next 'shopping' list!
OK, so I am in the 'ball park' then. Good to know.
Makes sense, given power equals voltage x current. Higher power (10 cells) plus lower current generates the same power and thus places the same (similar) load on a motor. I have heard that these Speed 480 Race motors are only really good for about 20 or so runs though. Is this right?
I guessed this already and that is why I have also been planning on a second airframe. I have a few ideas but am waiting to see how I go with the Alpha Jet first before making the purchase.
One idea is to pickup a Projeti with a brushless setup to get some of the speed fix. Then build a more serious EDF jet after that.
This is also good to know. It is a very simple airframe so I could see it will be easy to bolt a new higher performance fan/motor/battery onto the airframe.
OK. This is easy. I will do it tonight whilst I am assembling the Vasafan. (Airframe is already done)
From my research I am considering just using Deans Ultra connectors for everything. Is there any downside to this choice? Where is the best place to buy small items like this that won't shaft me with high shipping costs?
Thanks for the tips. I appreciate it. BTW Haldor I really like your Mig-29!
Old Jul 15, 2003, 06:22 PM
maverick is offline
maverick's Avatar
SF Bay Area, Ca
Joined Dec 2001
From a quick scan of the product specs. I think the 'micro' (lower voltage etc.) has more resolution to measure smaller changes.
So if you were only interested in 'Park Flyers' and had no need to measure above 10A or 160W then you would get a more accurate reading by using the lower capacity unit.
Old Jul 16, 2003, 11:59 PM
Daren is online now
Daren's Avatar
Joined Nov 2000
Yes, you're correct. Thanks for pointing that out, I had missed that.
Daren
Old Jul 17, 2003, 11:51 PM
maverick is offline
maverick's Avatar
SF Bay Area, Ca
Joined Dec 2001
Well the motor is now broken-in! I ran it without any load on 2 'D' dry cells in series (3V) until the cells were exahusted. The brushes are now nicely seated on the commutator.
I also bought a bunch of Deans Ultra connectors and everything is soldered up nicely now. I even made up a charge lead with banana plugs on one end and Deans Ultra on the other.
Thanks for all the help. It probably won't be my last questions though!
Old Jul 18, 2003, 12:53 AM
Daren is online now
Daren's Avatar
Joined Nov 2000
You're welcome and let's hope it never is.
Daren
Sold Graupner Speed 480 Race BB motor Twmaster Aircraft - Electric - Power Systems (FS/W) 1 Jul 11, 2006 07:04 PM
Question Graupner Speed 480 Race 7,2 V : Battery Nimh or Lipo ??? figaro02 Power Systems 2 Jan 15, 2006 12:08 PM
For Sale Graupner Speed 480 Race, 7.2V #6330 Twmaster Aircraft - Electric - Airplanes (FS/W) 0 Sep 29, 2005 10:12 AM
Graupner Speed 480 Race Break-In & Other Newbie Q's! maverick Beginner Training Area (Aircraft-Electric) 1 Jul 14, 2003 05:29 PM
Help! How do I retime my 6327 Graupner Speed 480 race motor for a gearbox. Joe Elston Electric Plane Talk 6 Apr 20, 2001 12:56 PM
