Seattle
Joined Sep 2007
I'm using this one. It comes with banana plugs, which I wanted to retain so I could use it with my PL8. To work with my Cellpro 4s I created a banana plug to FMA adapter using binding posts and an FMA 5 pin node adapter.
![]() Here's another option. You would still need adapt it the FMA plug style using either an adapter, or by cutting off the end and adding a FMA plug such as the CPBP7. http://www.progressiverc.com/index.p...emart&Itemid=1 ![]() On the FMA plug, wiring is simple, black to black, red to red. Inside pins are not used and can be removed. |
We have these in stock: CP125ADP Cellpro Multi4 adapter for small single cell lipos Charge adapter for single cell lipos. Designed for the micro and indoor market, this adapter permits you to charge up to 3 single cell lipos simultaneously with the Cellpro Multi4 charger. The adapter supports the 125MM connector found on the popular line of indoor models sold under the Park Zone brand. To purchase this adapter in a Multi 4 combo package. Click here to view the instruction sheet for the CP125ADP. This adapter will not work with the Cellpro 4S or 10S chargers. Although those chargers are designed to charge single cells, the smallest capacity cells you may safely charge are 350 mAh. $9.95 IN STOCK http://www.fmadirect.com/products.htm?cat=20&nid=71 |
Seattle
Joined Sep 2007
![]() Cool Howard! Didn't know FMA had that solution. That's way more convienient than my Hyperion HP-LGUM6PADAP to banana plug adapter to JST-Xh to FMA adapter solution that I cobbled together. Nico, I got mine from AlleRc. Just checked thier web site and I don't see it any more. Here's more info on the unit. http://media.hyperion.hk/dn/g3lipo/lgum6p.htm |
Actually, this isn't really so much of a safety issue as it is a limitation of the earlier chargers. Since they can not go below around 250 mA on the output current, they don't really finish the charge off properly. This requires something like the Multi4 or the PL8 which will go down to the C/10 rate levels required to properly finalize the charge on very small capacity LiPo's. |
| Thread Tools | |
| Sold 1S 3.7V 138mah (get your batteries here) | Full Spool | Aircraft - Electric - Micro & Indoor Airplanes | 27 | Nov 09, 2010 07:08 AM |
| Question Charging 1s Batteries | thinman | Batteries and Chargers | 2 | Oct 23, 2010 02:23 PM |
| For Sale 3 unbranded MCX 1s 138mah & E-flite 2s 800mah lipos | Tubeheadz | Aircraft - Electric - Batteries & Chargers (FS/W) | 4 | Dec 16, 2009 09:52 PM |
| Question Charging 1S 138MAh on Triton | Assassin-8 | Batteries and Chargers | 1 | Jun 15, 2009 03:17 PM |
| For Sale 1S 3.7v Batteries, mCX, Vapor Cessna 138mAH (FLIGHTMAX) | truraza | Aircraft - Electric - Batteries & Chargers (FS/W) | 4 | May 20, 2009 02:18 PM |
