Pentium 40a ESC w/BEC
A Universal Battery Elimination Circuit (UBEC) is a 'switch mode' DC regulator that takes the high voltage (up to 26 volts) of the main battery pack and converts it to a consistant and safe 5 or 6 volts (selectable) for your receiver and servos. A UBEC is needed if the Electronic Speed Control (ESC) being used for the motor does not have a built in Battery Elimination Circuit (BEC), or if the BEC of the ESC is inadequate to power the number and/or size of servos being used.
Using this UBEC is a safer way to go on large models for the following reasons: 1. Most built-in BEC circuits are 1 to 2 amp 'linear mode' circuits which are only useful for 2 or possibly 3 standard size servos when using a 3 cell Lipo battery. If you use more servos, or a higher voltage battery pack, you will almost certainly overload the BEC, causing a crashed model. 2. In an ESC with a built-in BEC, excessive heat generated in the ESC by the current draw of the motor and/or BEC can cause total loss of power to the receiver/servos, resulting in a crashed model. The chance of total loss of power is greatly reduced when a separate receiver battery pack or UBEC is used. If the ESC overheats and shuts down (no power to the motor), you will still have power to the receiver/servos, and will be able to maintain control of the model. Available at ValueHobby.com Pentium 40A ESC Manual |
| Thread Tools | |
| Discussion North Indianapolis indoor season begins 11/13 with 15 scheduled fly-in dates! | racin06 | Electric Flight Events | 42 | Apr 07, 2011 01:21 PM |
| Discussion F3F Sat. 11-13-10 | danfield | Multi Task F3X | 26 | Nov 14, 2010 10:09 PM |
| Discussion Sábado 13/11 - Aerobello | Uruguaio | Brazil | 20 | Nov 12, 2010 02:48 PM |
| 9/11, 10/12, 11/13?? | jrb | Life, The Universe, and Politics | 4 | Oct 23, 2003 02:22 PM |
