Old Nov 12, 2010, 11:21 PM
nemoskull is offline
Find More Posts by nemoskull
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
built first sail boat. sub 12'' hull
just finsished my first sail boat. twin mast fore and aft rigged. it still needs lighter line but i will try it out tomorrow. i will post pics as i can.
running 27mhz toy rc tx/rx.
nemoskull is offline Find More Posts by nemoskull
Old Nov 13, 2010, 02:46 PM
nemoskull's Avatar
Joined Sep 2009
dicthed the second sail and now have just one. you tube video, sorry about the quality and the no sound, i fried my windows partition and now run ubuntu, a lot faster and do most everything i want, but still a little buggy. buy its free! BUAHA AHA AHAHAHAHAHHA!
Old Nov 13, 2010, 02:47 PM
nemoskull's Avatar
Joined Sep 2009
micro rc scratch built sail boat (0 min 24 sec)
Old Nov 13, 2010, 03:43 PM
nemoskull's Avatar
Joined Sep 2009
okay, went to the pond, learned 3 things,
1: my toy rc is tough!, it got swamped 3 times and shorted out. dumped the water and it worked like nothing ever happened! (that is about the coolest thing yet)
2: i need rudder control. first off, its inverted, left is right and right is left, and it only does left or right, no center, expecpt when you are lucky.
3: the mast is too far forward. you can see the boat try to push its bow under as it going forward.
over all i am impressed. i am not a sailor, but i got this thing back to shore. it handles nice when it listens to me, and speed was never an issue. the wind was strong, but with better sails and better helm, i think it will do all right.
nemo.
p.s. i had a video, but it got screwed up, so no vid. next time guys.
Old Nov 15, 2010, 05:55 AM
cineas is offline
Find More Posts by cineas
cineas's Avatar
Fortaleza - ceara - Brazil
Joined Sep 2007
Originally Posted by nemoskull View Post
cool !!!!!!!!!!!!!!!!!!!!!!!!!
cineas is offline Find More Posts by cineas
Old Nov 16, 2010, 07:53 PM
nemoskull's Avatar
Joined Sep 2009
thanks! i just rigged it for night running, two 'wheat' bulbs wired in series, about 40 mah draw total. kinda dim but i wanted that effect, makes it look more "real". i have moded it to have center return on the rudder and rudder is now correct. moved the sail back about an inch. have not sailed it yet.
Old Nov 19, 2010, 05:35 PM
nemoskull's Avatar
Joined Sep 2009
nine inch sail boat, first run (0 min 49 sec)
Old Nov 19, 2010, 05:41 PM
nemoskull's Avatar
Joined Sep 2009
learned a few things here.
one, the boat does not sink, even when the deck is level with the water.
two, my sails suck, they work better one way than the other, because of how i rigged it.
three, nine inch hulls are tricky. this one was loaded too much, and sank.
four, the boat heel sideways when the sails are not right, and not so much when the sail are good
pretty cool, other wise.
next vid is of the sinking, raw footage.
Old Nov 19, 2010, 05:45 PM
nemoskull's Avatar
Joined Sep 2009
nine inch sail boat, final run. (1 min 20 sec)
Old Nov 20, 2010, 11:07 AM
Amp Abuser is offline
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
Your boat did a nice beach landing with the sail functioning all the way thru. Pack it with white foam inside a ziploc bag / foam never gets wet. You can use saran rap if applied proper it should last. Add more ballast to the keel, improve your sails size shape and cup for big windy day power you should be able to fly over those humps of watah if you move your cg back its too forward you nosed in as the water consumed ; but great ol wood to the rescue! I prefer wood over any other product when scratch building.
Amp Abuser is offline Find More Posts by Amp Abuser
Old Feb 16, 2011, 09:13 PM
keven64 is offline
Find More Posts by keven64
Model Designer
keven64's Avatar
United Kingdom, England, Burnley
Joined Apr 2001
nemoskull,
Your mast may not be too far forward - as you suspect.
It is very likely that it is simply too stiff !
Look at the Footy class yachts - which should fit into a 12" x 12" x 6" box.
Due to their small size - they 'blow over' very easily - so 'new' rigs have been developed - where the mast is able to bend.
Yes - you read correctly !
A 'bendable' mast allows a rig to loose some power during a gust - and so a little model can carry on it's course without much deviation...
Keven.
keven64 is offline Find More Posts by keven64
Old Feb 17, 2011, 12:47 PM
nemoskull's Avatar
Joined Sep 2009
never thought of that...... cool. CF rod?
Discussion 'SSS' Model Boat Group... Sail & Sale Day. 785boats Dock Talk 14 Nov 21, 2010 05:10 AM
Sold Pursuit Brushless V-Hull R/C Boat 32in RxR !!!Pics Added!!! tc3wins Boats (FS/W) 1 Nov 10, 2010 12:32 PM
Discussion EC12 OZMUN SAIL BOAT on Ebay gpzy Sailboats 0 Nov 09, 2010 11:01 PM
my first sail boat submarco Sailboats 3 May 18, 2005 10:55 AM
