Old Jan 31, 2013, 07:42 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^Possibly, but the helical antenna has side lobes that could be problematic. It would be better to use a crosshair due to lack of sidelobes.
IBCrazy is offline Find More Posts by IBCrazy
Old Jan 31, 2013, 09:06 AM
Pukin_Dog is offline
Find More Posts by Pukin_Dog
Åtvidaberg, Sweden
Joined Jul 2008
Ok. Perhaps it's time to solder some components and test then. Just a bump if it doesn't.
Pukin_Dog is offline Find More Posts by Pukin_Dog
Old Feb 03, 2013, 07:42 AM
A914freak is offline
Find More Posts by A914freak
GoThe Distance
United States, NJ, Moorestown
Joined Feb 2012
ok it tracks east and west, but what about north and south??? If you have an antenna with a beam of say 30 degrees you are going to have to pan up and down at some point
A914freak is offline Find More Posts by A914freak
Old Feb 03, 2013, 09:02 AM
Åtvidaberg, Sweden
Joined Jul 2008
If it tracks east and west it will also cover north and south with just pan. I don't understand what you mean here? It can't track up and down at the same time since the lowest RSSI value is the preferable antenna.
Originally Posted by A914freak View Post
"ok it tracks east and west, but what about north and south???"
Old Feb 18, 2013, 07:18 AM
Leszek_K is offline
Find More Posts by Leszek_K
Leszek_K's Avatar
United Arab Emirates, Dubai, Dubai
Joined Jul 2007
Did the first successful flight with my tracker. Video on 5.8GHz, 3 x 5 turns helical antennas. Tracking antennas set at about 30 degrees angle. All controlled by PIC16F688. It compares RSSI from 2 305 modules and drives a servo. Servo with removed stops, pot disconnected from a drive and set to center. So - pulse shorter then 1.5ms moves it to the right, loner - to the left, no pulse = no movement. Very simple circuit, very little wiring, all intelligence in a software.
Downside of using A/D converters - as modules are always slightly different and RSSI drifts with temperature, rx modules need to be left on for about 20 minutes till RSSI stabilizes and system can be calibrated. But - it tracks perfectly up to the very end of video range. It looses a track with model nearly overhead, as expected.
Leszek_K is offline Find More Posts by Leszek_K
Old Feb 24, 2013, 01:08 PM
GroundAttack is offline
Find More Posts by GroundAttack
Ground successfully attacked!
GroundAttack's Avatar
Spain, AL, Lucainena de las Torres
Joined Sep 2011
Would this work
Firstly, thank you Alex for sharing this and all the antenna information so freely with everyone.
I am considering making something similar for 5.8G but basing it on Arduino, reading the RSSI from two crosshairs and using a helical for the video central channel, maybe even expanding with two more antennas for up/down.
I am hoping to use these modules as they are so cheap. Any advice welcome.
GroundAttack is offline Find More Posts by GroundAttack
Old Feb 25, 2013, 12:06 AM
Åtvidaberg, Sweden
Joined Jul 2008
Wow, those are cheap! Perhaps it's time to build one now when the Rx is in that price range!
I'm interesting in how the tilt will work for you "GroundAttack"
Old Mar 13, 2013, 02:19 PM
renegagnon is offline
Find More Posts by renegagnon
Joined Mar 2013
Q: Will you build one for me?
A: No. But I will sell you all of the parts
how mutch for all the parts:
1 – Standard size servo (the slower and deeper gearing, the better)
2 – standard RX units 900 mgz
2 – 1N4148 Diode
1 – TO-220 heatsink
1 - uA 7805 voltage regulator
1 – LM393 voltage comparator
1 – LM358 OpAmp
2 – 555 timer (NE555N or similar – Optionally, you can use a single 556 timer as well)
1 – 1 MegOhm potentiometer
could you send it to me please?
renegagnon is offline Find More Posts by renegagnon
Old Mar 14, 2013, 11:06 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^I don't have the servos or the receivers, but I do have the rest of the parts. PM me with your address.
-Alex
Old Mar 23, 2013, 02:43 PM
polarizadmax is offline
Find More Posts by polarizadmax
Joined Mar 2013
@IBcrazy
I am actually through your all the design information for this tracker(its really awesome) .Finally i decided to use your design for my academic project purpose to track an 900MHz frequency via rectenna as input instead of any Rx modeule.
But I have a lot query .hope you will answer
1) In modifying servo you mention to connect/solder the extra wire to center pin of servo.(whats that center pin actually ) even after removing the POT the original center wire is as it is then where this extra center wire going to connect.
as the motor inside servo having three pin do i need to connect that voltage position control pin to one of those wire. (pls explain this point well)
2) why you are using two 555 is that to form H- bridge.
3)Please explain how the servo move bidirectional as i am not getting it well.
thnx
polarizadmax is offline Find More Posts by polarizadmax
Old Mar 25, 2013, 10:12 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I'm not using the 555's as an H-brige. I am using them to set a pulse for the tracker to adjust. The servo needs a PWM input. I used two 555's because it was easy. They are set at different pulse widths to tell the servo which way to move according to the RSSI numbers.
The center pin of the servo is the position indicator. Inside the servo is an A/D converter that converts this to a position. In removing the POT, the servo losses position. The resistors tell the servo that it is always centered and thus, when the pulse comse in to move one way or another, the servo simply moves that direction. Since there is no direct connected center, the servo instead moves indefinitely until the tracker is centered when the RSSI numbers match. The second 555 is to control oscillation since the tracker tends to overshoot.
Old Mar 26, 2013, 03:13 PM
Joined Mar 2013
Thanx for your reply,
Now i actually understand :
The first 555 is triggering second at interval adjusted by pot while the second 555 is generating PWM.
Fine.
Again when i trace the output of the second 555 in circuit i found that at default its giving ON time og nearly 0.4msec while OFF time of 5ms made servo move anticlock wise.
So if the servo moves with varying PULSE WIDTH then how it controlling servo direction by extra pin attached to center of removed POT from an servo ?
I am actually not able to control (move servo bi-directionally) servo by applying 0-10 V (varied) at modified PIN (before using any comparator output)?
Now could you pls explain or tell how to made it work ?
Old Mar 26, 2013, 03:36 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
^You aren't varying the pulse width. You are varying the location of center position. The pulse you are giving it tells the servo to go to center. The RSSI numbers fed into the system tell it where center is.
-Alex
Old Mar 26, 2013, 11:32 PM
Joined Mar 2013
I am actually confused too much now.If possible will you please give me some reference/link that i can easily understand the way you are using PWM IN YOUR TRACKER.
THNX
Old Mar 27, 2013, 04:05 AM
empeabee is offline
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
THNX
I hope this is not too simple for you.
To control the position of a servo, you need to apply a PWM signal to the servo.
This signal should be approximately between 0.5 mSec and 1.5 mSec long centered on 1 mSec. The "normal" repetition rate is 60 per second.
When it is 1 mSec the servo will be in the centre, 0.5 mSec fully 'one' way, 1.5 mSec fully 'the other way'. Normally he servo compares thie width of the signal to the position of it's built in potentiometer, and stops moving when it has achieved a balance.
As I understand IBC's tracker, the potentiometer is removed, and the motion of the servo is controlled by his electronics, removing the need for horrible mechanical linkages.
I hope this helps, because this reply is "off the top", it is some time since I actually looked at his circuts and I might have it very wrong.
(just too lazy to re-read it all from the start again ).
empeabee is offline Find More Posts by empeabee
Mini-HowTo Fast Patch - IBCrazy's easy DIY patch antenna IBCrazy FPV Talk 357 Dec 10, 2015 06:40 AM
Discussion DIY UHF GPS tracker / beacon Fred. FPV Talk 35 Feb 08, 2013 06:18 AM
Build Log IBCrazy's homebrew antenna tracker IBCrazy FPV Talk 48 Oct 25, 2012 06:07 PM
Wanted Need a 1.2GHz patch antenna and an antenna tracker ChrisS Aircraft - General - Miscellaneous (FS/W) 1 Jun 17, 2011 07:07 AM
Discussion Plans to build a DIY antenna tracker mount? Matt Halton FPV Talk 2 Aug 17, 2010 05:31 AM
