Old Nov 12, 2010, 12:38 PM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
Question
Will increasing antenna wire Lenght increase RC-Rx range?
Hello,
I have a Futaba PCM reciever (168DP),
1. will adding another 39" of wire to the existing
reciever antenna wire increase range?
I'm afraid if I go out too far, my servos' will lock out....
(I don't have OSD)
rclab1 is offline Find More Posts by rclab1
Old Nov 12, 2010, 01:22 PM
Megafluffy is offline
Find More Posts by Megafluffy
Norway, Hordaland, Bergen
Joined Feb 2009
Yes, most likely.
See chart, this is rssi voltage vs distance(meters), from a 35MHz Futaba PCM receiver (don't remember model).
Blue line is original antenna length, the other is longer.
Megafluffy
Megafluffy is offline Find More Posts by Megafluffy
Old Nov 12, 2010, 02:05 PM
rclab1 is offline
USA
Joined May 2010
I have 72mhz.....
is it the same for 35mhz?
Old Nov 12, 2010, 02:16 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Generally yes. In theory there are certain specific lengths that could reduce the
range, but in practice, longer seems to almost always be better.
ian
Daemon is online now Find More Posts by Daemon
Old Nov 12, 2010, 02:52 PM
rclab1 is offline
USA
Joined May 2010
Daemon,
I don't want to reduce range....
will the doubling the original length the perfect solution?
Old Nov 12, 2010, 03:15 PM
CoolBudz is offline
Find More Posts by CoolBudz
RCPlaye
United States, CT, East Hartford
Joined Aug 2009
suscribed
CoolBudz is offline Find More Posts by CoolBudz
Old Nov 12, 2010, 03:19 PM
Capt. Crunch is offline
Find More Posts by Capt. Crunch
It's all fun till Crunch!
Capt. Crunch's Avatar
InSane Diego
Joined Jan 2002
Mega,
Do you have the lengths as a % of the original?
It looks like the Black line is about optimum.
Capt. Crunch is offline Find More Posts by Capt. Crunch
Old Nov 13, 2010, 03:25 AM
Joined Feb 2009
Hi all,
Yes doubling the length will be good.
On 35MHz original length is 1/8. I have also tested 1/2(pink) 5/8(yellow) 3/4(green) 1/1(black), I haven't tested 1/4 yet.
The red one is 1/2 that was a bit to long.
But as you can see, doubling from 1/2 to 1/1 is not worth it, minimal signal increase, but big weight and drag increase (at least on 35MHz, ant is about 8m).
Megafluffy
Old Nov 13, 2010, 04:32 AM
Guntars is offline
Find More Posts by Guntars
Latvia
Joined Oct 2006
Can you test 1/4 length?
Guntars is offline Find More Posts by Guntars
Old Nov 13, 2010, 05:19 AM
srnet is online now
Find More Posts by srnet
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Originally Posted by Megafluffy View Post
Hi all,
Well most RXs seem to use 1M/39" as a handy length, there is no reason for it to be deliberatly 1/8th Wavelength. In any case 1/8th wavelength at 35.2mhz is 1.125M. Plus I have a 40MHZ Corona, it has a 1M antenna also, figure that out.
The graph is very good info, but I suspect you would have had the same progression (some lengths better than others) if you had ignored wavelength and teseted, 1M, 1.5M, 2M etc.
srnet is online now Find More Posts by srnet
Old Nov 13, 2010, 06:21 AM
Cir2kuk is offline
Find More Posts by Cir2kuk
Chris R
United Kingdom
Joined Dec 2009
Cutting off a old antenna wire and solering to my antenna on corona receiver double my range with transmitter antenna down.
Cir2kuk is offline Find More Posts by Cir2kuk
Old Nov 13, 2010, 06:46 AM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
The problem with increasing the lengths is that the receivers dont use a tuned antenna and they have coils on the input og the rx. This means as the antenna length increases the impedance goes too far out loosing performance instead of gaining it
Coyote64 is offline Find More Posts by Coyote64
Old Nov 13, 2010, 01:37 PM
Joined Feb 2009
Hi,
Sorry but it will not happen anytime soon... I have the same enemy as everybody... TIME... Wont let me do everything I want, and have to do.
But I guess it would be just below 3/4.. Good improvement, but not as good as 1/2. But this is just my guess.
Megafluffy
Old Nov 13, 2010, 01:42 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Prove it.
Every actual test I've ever seen (and people have been doing them for decades now)
shows increased signal strength and longer range with longer antennas on
72Mhz and 35Mhz Rxs. I've never seen one actual lose performance, although
it is theoretically possible.
ian
Old Nov 13, 2010, 02:01 PM
Joined Feb 2009
Hi,
I know this is true for transmitters. But for receivers, good match is not so important. This you can see in my tests, where the antennas with the highest impedance, has the best results (1/2 and 1/1).
Maybe the input impedance for the receivers is higher than the the antenna they are supplied with?
All antenna length tests has an average of 6-10 inputs for each distance.
(because of this, it takes long time to do this tests)
Megafluffy
Discussion Rx FM antenna lenght vigli Slope 19 Oct 20, 2010 12:59 PM
Discussion replacement antenna wire for optima 7 rx firehopper Hitec/Multiplex USA 3 Sep 13, 2010 02:15 PM
Question Increase 36mhz range with 1/2 wave RX antenna?? chancesAU Radios 2 Jun 09, 2009 03:59 PM
Discussion Increasing range with longer RX antenna? rob10000 Radios 26 Jun 07, 2007 01:55 PM
deans antenna wire lenght at receiver? wiley Electric Heli Talk 3 Feb 18, 2002 10:54 AM
