Old Aug 30, 2011, 08:29 AM
Clintstone is offline
Find More Posts by Clintstone
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Originally Posted by johnahamelv View Post
Question for Clintstone. barzaun mentioned that the BEC Pro is (in)famous for high failure rate when connected in 12S mode compared to 6S. Could you comment on this? Thanks.
I already replied to your email...
I have heard of very few failures of the BEC pro V-2...
I run mine on 6s as I like the ability to power up the FBL system first. There is also more out put available on 6s versus 12s... a FBL 700 is a power hog to start with... the servos are very demanding.
Clintstone is offline Find More Posts by Clintstone
Old Mar 09, 2013, 01:41 PM
Parakos is offline
Find More Posts by Parakos
Addicted
Parakos's Avatar
Stockholm, Sweden
Joined May 2010
Hi!
I have wired my CC 100A ESC and CC BEC Pro like shown in the diagram in the first post. Yesterday I noticed something strange when I was changing receiver. I finished the setup and noticed that I had forgotten to connect the bulled plug to the negative ESC wire. Still the ESC armed and counted 8S (2x 4S) WITH the negative wire from the ESC disconnected(?!).
Is this normal?
/Johan
Parakos is offline Find More Posts by Parakos
Old Mar 11, 2013, 08:36 PM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Originally Posted by Parakos View Post
Hi!
Is this normal?
/Johan
Sounds like the way you hooked it up you have a ground loop... I would always hook up the low negative pack first and then hook up the second pack on the positive side ... this will keep you from having this condition when connecting the packs. The purpose for the thread is to allow the CC BEC to be connected to 6s in a 12s setup so the current output will be a little higher than on the 12s setup and the RX power can power up the radio gear prior to the ESC powering up which is helpful for setup...
Sold used CC PRo BEC garrcass Aircraft - Electric - Power Systems (FS/W) 2 Oct 30, 2010 10:17 PM
Sold CC PRo BEC Version 2 falconjet50 Aircraft - Electric - Helis (FS/W) 3 Oct 30, 2010 06:56 AM
Discussion CC 10amp BEC Failure on 6s knlken Castle Creations 8 Sep 22, 2010 04:30 PM
Sold CC 85 HV with CC BEC Pro soldered on ready to go. litespeed Aircraft - Electric - Power Systems (FS/W) 1 Jun 15, 2010 11:22 PM
Discussion Trex 600 on 6s, or raptor 50 with ccpm, on 12s emoli? Nick J Electric Heli Talk 5 Oct 21, 2006 02:41 AM
