Old Nov 11, 2010, 07:43 PM
norstaroption is online now
Find More Posts by norstaroption
norstaroption's Avatar
Pacifica, CA USA
Joined May 2009
ICharger 208B and 6S JST-XH Balance Cable for Parallel Charging
I planning to purchase an ICharger 208B to charge 6S 5000mah batteries. I'm not sure if I can use this 6S parallel balance cable with it. Not sure if I should just purchase the 206B one.
Thanks in advance.
norstaroption is online now Find More Posts by norstaroption
Old Nov 11, 2010, 09:00 PM
KC is offline
KC
Find More Posts by KC
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
Which 6S parallel balance cable are you referring to? Do you have a picture of it or a link?
KC is offline Find More Posts by KC
Old Nov 11, 2010, 09:13 PM
Pacifica, CA USA
Joined May 2009
http://epbuddy.com/index.php?main_pa...products_id=59
Will the plug fit in the chargers balance port?
Old Nov 11, 2010, 09:33 PM
KC is offline
KC
KC
KC's Avatar
Joined Sep 2006
That harness has the 6S tap. The 208B's balance port is a 9 pin port for 8S.
This is the one you want with the following 8S to 6S adapter. It costs more, but the 6 parallel discharge connectors are included in a nice neat package.
http://epbuddy.com/index.php?main_pa...products_id=84
http://epbuddy.com/index.php?main_pa...products_id=88
KC
Old Nov 11, 2010, 09:50 PM
propnut07 is offline
Find More Posts by propnut07
United States, FL, Palm Harbor
Joined Feb 2007
delete this one.
propnut07 is offline Find More Posts by propnut07
Old Nov 12, 2010, 06:25 AM
Hughes500Bob is offline
Find More Posts by Hughes500Bob
Retired CFI Helicopter
Hughes500Bob's Avatar
Southeast PA
Joined Jun 2007
The iCharger 208B has a single 8S (9 pin) JST-XH port and uses adapter boards with a cable interface.
ANY 2S - 7S JST-XH plug can be swapped with an 8S (9 pin) plug (ALWAYS STARTING AT THE GROUND END) and plugged directly into the 8S port (with unused pin sockets) without the need for the cabled adapter board.
Digi-Key P/N 455-2217-ND 10 each for $1.27 plus shipping
Example - Customer's Parallel 2S rig for 2 each JST-XH and 2 each Thunder Power which plugs directly into the 208B (and a SERIES power harness for his Traxxas vehicle).
Bob
http://rcsales.shutterfly.com
Hughes500Bob is offline Find More Posts by Hughes500Bob
Old Nov 12, 2010, 09:00 AM
Pacifica, CA USA
Joined May 2009
Thanks, I went ahead and purchased a 208B and paraboard.
Old Oct 22, 2011, 03:03 PM
bbyamaha is offline
Find More Posts by bbyamaha
Joined Jan 2010
Sorry to bring up a dead thread from a year ago but I have a question which 3 shops have had not had an answer for nor could they even point me in the right direction. Needless to say I have 1k worth of crap since I have not been able to charge the batteries nor even hook them up. This thread is the closets to answers I have been to date since purchasing my car well over a year ago.
I bought the 208b charger and power supply brand new. I also bought 2 hyperion vx g3 lipo power packs. They are 3s/11.1v 35c discharge 5500mah.
What do I need to do to charge them seperately or at the same time. Will the above setup work in my case or not... Any help would be appreciated!
bbyamaha is offline Find More Posts by bbyamaha
Old Oct 23, 2011, 05:47 PM
KC is offline
KC
KC
KC's Avatar
Joined Sep 2006
You'll need this 208B balance tap adapter for the Paraboard.
And the Paraboard for the HP with your lipo's discharge connector.
http://epbuddy.com/index.php?main_pa...teft239abcep46
Discussion JST-XH to TP 5S balance connector callen Batteries and Chargers 4 Apr 01, 2011 07:26 PM
Sold ThunderPower ADAPTER: Balance Plug Adapter | Male JST-XH to Female ThunderPower KellenR Aircraft - Electric - Batteries & Chargers (FS/W) 1 Nov 04, 2010 12:14 AM
Sold ThunderPower ADAPTER: Balance Plug Adapter | Male JST-XH to Female ThunderPower KellenR Aircraft - General - Miscellaneous (FS/W) 3 Nov 03, 2010 09:08 PM
Sold Hyperion 720i Balance Adapter for JST,XH KSteinick Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 13, 2010 12:53 PM
Found 6S jst-XH to TP balance tap adapter cables.... GunnyGlow Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 03, 2010 08:47 PM
