Old Mar 13, 2012, 06:21 AM
AxlMyk is offline
Find More Posts by AxlMyk
OldCuss
AxlMyk's Avatar
USA, MI, Hartland
Joined Aug 2008
Originally Posted by Danco1985 View Post
Even with the tail prop off the heli still spins.
Well, kinda obvious there.
AxlMyk is offline Find More Posts by AxlMyk
Old Mar 13, 2012, 10:17 AM
HSV_Noob is offline
Find More Posts by HSV_Noob
HSV_Noob's Avatar
United States, AL, Owens Cross Roads
Joined Jan 2012
Originally Posted by EQMOD View Post
when you start replacing the stock motor with a more powerful one, you basically increase the torque generated thus you also need to mount an equally more powerful tail motor to counter the increased torque;
Two options;
- Use the tail motor of the MSR. Its more powerful than the stock Solo Pro tail.
- Shaft drive tail - allows you to use a larger tail motor at the same time mounting it closer to the heli's COG
I saw this tail rotor mod on another thread. It shows the Solo Pro with a shaft drive tail. Does anyone have more info on this mod? Also is there a parts list?
This looks very cool and I would love to take it on. I have several Solo Pro's and would love to make one my project/mod heli.
Thanks!
Les
HSV_Noob is offline Find More Posts by HSV_Noob
Old Mar 13, 2012, 02:48 PM
chilaspt is offline
Find More Posts by chilaspt
Portugal, Lisbon
Joined Jan 2012
Originally Posted by hsv_noob View Post
i saw this tail rotor mod on another thread. It shows the solo pro with a shaft drive tail. Does anyone have more info on this mod? Also is there a parts list?
This looks very cool and i would love to take it on. I have several solo pro's and would love to make one my project/mod heli. :d
thanks!
Les
+1 :d
chilaspt is offline Find More Posts by chilaspt
Old Mar 13, 2012, 03:03 PM
SoloProFan is offline
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
You could try sending EQMOD a personal message. As far as I know he is the only one that tried this mod.
SoloProFan is offline Find More Posts by SoloProFan
Old Mar 13, 2012, 03:07 PM
HSV_Noob is offline
HSV_Noob's Avatar
Joined Jan 2012
Tried sending him a PM but got an error that he had exceeded his message store size. Doohhh!
Old Mar 13, 2012, 04:16 PM
HSV_Noob is offline
HSV_Noob's Avatar
Joined Jan 2012
Originally Posted by chilaspt View Post
+1 :d
I did some searching on youtube and other locations and came up with a response to the video where he is showing off this mod.
Parts from Walkera 4#3B:
tail motor
flybar linkage as shaft support
flybar as axle
2 main motor pinions
tail motor assembly with bearing
Plus MSR tail blade
I found images with precise explanations in red, saved them on disk and it was a good idea because now can't find them on the web anymore. Send message if interested or if the author does not respond.
Looking for the images now. I am going to my LHS tonight to see if they have the Walkera parts in stock or if I need to order. Pretty ingenious using a linkage as shaft guide.
More to come.
Old Mar 13, 2012, 06:02 PM
Brosol is offline
Find More Posts by Brosol
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
Thanks!
Les
EQMod's original MSR tail rotor shaft drive mod was based on Walkera 4#3B parts which was transplanted to the Solo Pro.
- Solo Pro tail rotor shaft drive mods:
Walkera 4#3 Parts: http://www.chinesejade.com/walkera4_3_A_B.htm
EQMOD: http://www.rcgroups.com/forums/showthread.php?t=1280843
EQMOD: http://i263.photobucket.com/albums/i...r_pose_008.jpg
EQMOD: http://www.rcgroups.com/forums/showp...51&postcount=2
EQMOD: http://www.rcgroups.com/forums/showthread.php?t=1278838
Walkera 4G3 Parts: http://www.chinesejade.com/walkera4G3.htm
CyLLlKA: http://img.pixs.ru/storage/7/6/6/DSC...83_1344766.jpg
CyLLlKA: http://translate.googleusercontent.c...6XXZzFhx1xOHeA
thecubist: http://www.rclineforum.de/forum/boar...-mod/?aa252e28
Krit: http://www.rcgroups.com/forums/showp...postcount=3204
Walkera 4#6 Parts: http://www.chinesejade.com/walkera4G6.htm
Krit: http://www.rcgroups.com/forums/showp...postcount=2952
Krit: http://www.rcgroups.com/forums/showt...r+mod&page=198
Brosol is offline Find More Posts by Brosol
Old Mar 14, 2012, 10:39 PM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
xxxxxxxxxxxxxxxxxxx
Jake8131 is offline Find More Posts by Jake8131
Old Mar 15, 2012, 12:46 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Originally Posted by Jake8131 View Post
Anyone have a broken nine eagles transmitter? I am in need of the charge port cover.
In understand your need for this part, but it's neither a technical issue, and you already posted the same request in the Proto Max review thread, and the regular Solo Pro thread. That could be seen as cross posting, and that is generally not appreciated by the site admins...
Old Mar 15, 2012, 02:16 AM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Sorry...will fix that.
Old Mar 15, 2012, 12:56 PM
shahram72 is online now
Find More Posts by shahram72
United States, SC, Irmo
Joined Sep 2011
OK, it's been a while since I posted here. I had a solo pro with what we thought was a broken elev servo. So I finally got my new RX board in and it's the same version, installed and bound it. And it worked for a few cycles, then froze. I removed and replaced the battery and tried again and got one forward back cycle before it became unresponsive. I should have just bought a whole new bird. Never again will I replace a non-mechanical part on this type of heli. So what do I check next? Maybe my old board is OK? This issue occured shortly after installing metal parts that were stiff. I removed the metal swash while installing the new board but left the metal shaft so I could keep the metal head. Everything moves free.
shahram72 is online now Find More Posts by shahram72
Old Mar 15, 2012, 01:15 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Maybe the metal parts overloaded the new board, and that wrecked the servo? By the way, what batteries were you using again? It seems more board problems are encountered when the batteries, or the battery contact strips are not ok.
Old Mar 15, 2012, 02:07 PM
Joined Sep 2011
No, I was sure to remove the metal swash before installing the new board. It still has the metal shaft and head, but that stuff spins free and does not interfere with the servo action. I remember reading somewhere about EPA adjustments? I will check and clean the battery contacts.
Old Mar 15, 2012, 07:57 PM
tonytester is offline
Find More Posts by tonytester
Yo R Wee Too Lo
United States, OH, Cleveland
Joined Oct 2011
weak batt
I've noticed that a battery that cannot put out enough current , will make you look in the wrong area for a fix, weak or dirty contact also. I learned that from these guys.
Tonytester
tonytester is offline Find More Posts by tonytester
Old Mar 16, 2012, 12:53 PM
nabit is offline
Find More Posts by nabit
wisconsin
Joined Nov 2005
my bravo pro
nabit is offline Find More Posts by nabit
Discussion Revell Proto cx and Nine Eagles Solo Free Spirit EFEX ED Coaxial Helicopters 7 Feb 10, 2013 10:20 AM
Wanted Nine Eagles Solo Pro Receiver Board or Parts. flyerjs Aircraft - Electric - Helis (FS/W) 0 Nov 11, 2010 01:56 PM
Wanted Nine (9) Eagles Solo Pro - 'copter only. emarkay Aircraft - Electric - Helis (FS/W) 3 Oct 07, 2010 11:00 AM
Discussion Revell Proto MAX RTF/Nine Eagles Solo Pro RTF $69.99 at Tower Hobbies Firehawk989 Hot Online Deals 1 Sep 29, 2010 12:16 AM
Wanted MCX, Nine Eagles Solo, Proto CX RTF k5beason Aircraft - Electric - Helis (FS/W) 0 Apr 18, 2010 08:02 PM
