Maybe someone could try weighting their GoPro to the equivalent mass of the 5d and see if that is the bulk of the difference. Mass and inertia matching would be telling. The jello issue is a rotational issue of the camera swivelling. Adding a small barbell would do far more than the equivalent lumped mass.
Denmark, Capital Region of Denmark, Copenhagen
Joined May 2010
That's pretty much what I'm testing now, for eventual sale (if it works).
It's a bit hard to visualize, but the battery tray, gear legs, and camera mount are all resting on very soft dampers when in flight. The extra mass definitely helps. When not in flight, the weight of the copter rests on the top of the gear legs, so it doesn't put too much strain on the dampers. The tilt/roll is a very basic ServoCity unit, and subject to all the issues we know and love from direct drive. I've got a bag of gears to play with as well, but no time to finish it all right now. Cheers, Rusty |
Joined May 2010
Joined Dec 2005
It works at least at distances of 200m, I haven't specifically tested it for range though. Keep in mind that the antenna is directional, so just any position will not give you an optimum range. I've noticed some connectivity issues at distances greater than 60-70 meters, if the BT module is not parallel to the ground.
Andrey and Simon, both very nice videos, thanks for sharing. In reply to OMM's post, I too have been fighting the dreaded jello effect in GoPro videos. I think I might be on the right track to eliminate it by suspending the camera mount on 8 silicone tubes. I already have some test footage that looks promising. However, there is some unwanted swing effect now during descent and aggressive flying. This is because the rig is no longer firmly attached to the MK and allows for some movement. The key I think is to find the right length for the suspension tubes. Too short - no swing, but jello, too long - some swing, but no jello. What also creates jello effect is the work of the tilt and roll servos (I am using MK GoPro mount with direct-drive servos). I haven't found a good way to deal with this yet. Adding a small resin disks (cut from eraser) on each axis to create some friction helps a bit. How are you guys dealing with this issue? Cheers, Nick |
Better try different props... The movie before was made with gws hd8040. This one with Gaui 8", i wont use them anymore.
LOOKS familiar Rusty I have done the exact thing. I have been putting the camera with the battery mass... it helps alot. I even used the same servo city things too... work ok but too much play from what I found.
Steve ps adding mass to the makes a huge difference in jello and or vibrations if you use a telescoping lens on your fixed camera Quote:
Philippines
Joined Dec 2010
Jello festival on mine. I'm also in the process of trying to eliminate or minimize Jello Effect on my vids. I think that there's no commercially available mount out there that wouldn't need a considerable amount of tweaking to get good videos. This vid is from my stock hexa2 with hi-sight mount.
| Thread Tools | |
| Discussion Mikrokopter Okto 2 build | Roger_IIT | Multirotor Talk | 6 | Feb 03, 2011 08:22 AM |
| Discussion Mikrokopter ME 2.0 Okto Build | robin4 | Multirotor Talk | 16 | Jan 12, 2011 02:07 PM |
| Discussion Mikrokopter / UAVP / quadrocopter / quadrotor build | Arthur P. | Multirotor Talk | 16696 | Nov 10, 2010 04:49 PM |
| Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion PART 2 | tend2it | Multirotor Talk | 2203 | Nov 08, 2008 08:23 PM |
