Nov 01, 2012, 09:58 AM
United States, MD, Salisbury
Joined Mar 2011
Joe: Very nice, and very professional. A lot of different locations, you sure have been busy!
Cinestar 6 is back in the air! I only had to replace an arm and a leg, but I spent the better part of the afternoon checking over everything,
and making sure things were fine in MKTools. Did a test without props, then tied down with weight and props. No problems found. Idle seems a bit fast. I still have no clue why my CS6 took off as soon as it was armed. It took off back and to the right, just like I had the stick.... The Graupner log showed the throttle as off or zero. Might not ever figure it out but it flew PERFECT today!
Can motor idle be adjusted to be a bit slower? I did notice an increase in motor speed when I disarmed, must be because of the yaw? Probably was there before but I was as cognizant.
