I love FPV flying, shame its totally illegal here in Australia. Although i am still working on that. What i love most about FPV, is thats its always a challenge, i learn something every time i wear my glasses. It's about time you blew the dust of the Lumix and showed the young fellows on here what its all about... ![]() Simon Shot this yesterday down at the beach, nothing fancy. I was testing the new Radian Stabilization hardware from FreeFly systems. You can read the description in the video.
Austin, Texas
Joined Apr 2009
Motors
Anyone have a source for where to get Sunnysky motors? They sound great, but I can't find them in stock.
Are there any other motor suggestions that are high quality like this and reasonably priced like the Sunnysky's. Also...I am thinking of upgrading and running 12" props from now on with my MK's. Could the 2216 motors handle 12" props or should I go with the 2814's? Also, has anybody used these Turnigy motors? Any good? Thanks, Brent |
Joined Feb 2007
Hi Brent,
Here is a discussion thread on the Sunnysky motors: http://www.rcgroups.com/forums/showthread.php?t=1609854 and another with some testing: http://www.rcgroups.com/forums/showthread.php?t=1521705 Sources: -- http://www.ebay.com/sch/i.html?_trks...nysky&_sacat=0 -- http://www.himodel.com/sort.php?sub2=FB -- http://www.foxtechfpv.com/sunnysky-2...tor-p-382.html -- http://www.goodluckbuy.com/sunnysky-...uadcopter.html -- http://www.hobby-wing.com/sunnysky-x...212-kv980.html Cheers, Jim Quadrocopter and Tricopter Info Mega Link Index Quote:
I find these to work extremely well (efficiency + power) and good bang for your buck. http://www.hobbyking.com/hobbyking/s...50kv_140w.html
Latest blog entry: Some Stuff
Austin, Texas
Joined Apr 2009
Man this thread is quiet.
Anyway..I figured out the Sunnysky motors I mentioned aren't suitable for spinning 12x3.8 props. I'm going with these. They seem very high rated and much more capable of bigger props. They appear to be just rebranded RC Timer motors. I had forgotten about Ecalc. Man that tool is amazing for analyzing motors, etc. Brent |
Gainesville GA USA
Joined Nov 2004
As a batteries internal resistance increases, it will drop voltage under load. Heat will cause it to increase also.
Was the bad battery hotter than normal when you landed? I use an iCharger, which can display the internal resistance for each cell. Record them when new, and check when your flight times drop. Rick |
It was the stock CS6 battery actually, Quadropower lipo. The odd thing is only the MK saw the battery as low, and it wasn't really low. The DX8 telemetry was reading over 16v initially, and 15v when the MK was beeping. The GPX file read 12.5v at the lowest and 12.7 on landing. When I tested the battery with my charger and my "Watts up" they both read 15.2V, not even close to 12.5v. My next 3 batteries were fine, 2 of them nano-techs.
So the battery was fine, it was the MK that read the voltage wrong at the beginning (15v), when I'm sure it was about 16.6v. It then read it lower than it actually was during the whole flight. I just didn't know it till I heard the beep alarm and read the GPX. Just weird. |
Gainesville GA USA
Joined Nov 2004
I'd be real careful flying that battery. Check the MK flight logs to see how steady the discharge is on the next few flights with it.
Checking the battery after the fact isn't a good indicator. The battery voltage drops on draw and recovers as the load is removed. If the GPX file showed 12.5v as the lowest, then that is what it was when the draw was the highest. In my experience, they don't get better by themselves. 8-) Rick |
| Thread Tools | |
| Discussion Mikrokopter Okto 2 build | Roger_IIT | Multirotor Talk | 6 | Feb 03, 2011 08:22 AM |
| Discussion Mikrokopter ME 2.0 Okto Build | robin4 | Multirotor Talk | 16 | Jan 12, 2011 02:07 PM |
| Discussion Mikrokopter / UAVP / quadrocopter / quadrotor build | Arthur P. | Multirotor Talk | 16696 | Nov 10, 2010 04:49 PM |
| Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion PART 2 | tend2it | Multirotor Talk | 2203 | Nov 08, 2008 08:23 PM |
