Old Jul 19, 2012, 10:45 AM
albertog is offline
Find More Posts by albertog
albertog's Avatar
Panama, San Miguelito
Joined Apr 2011
Compass not working
Hello friends.
Suddenly my compass has stopped working. Low hours of use.
When i connect to mktools it gives an error on the compass, navi board
seems ok.
I connect the compass directly to the mkusb and the green light
turns on but i dont see it on the mktools.
What can you recommend on this situation?
Thanks.
albertog is offline Find More Posts by albertog
Old Jul 20, 2012, 01:53 AM
Nettraptor is online now
Find More Posts by Nettraptor
MK Addict
Nettraptor's Avatar
Hellas
Joined Jun 2009
probably bad connection to navi? did you re-check?
Nettraptor is online now Find More Posts by Nettraptor
Old Jul 20, 2012, 11:00 AM
albertog is offline
albertog's Avatar
Joined Apr 2011
After connecting and disconnecting for several times i managed to flash the
firmware and get it working!
I had to flash it thru the navi since when alone it didnt flash.
Old Jul 20, 2012, 11:02 AM
albertog is offline
albertog's Avatar
Joined Apr 2011
Are the latest MK firmwares for the FC (2.1) and Navi (1.1)
working fine???
Old Jul 20, 2012, 01:08 PM
glmccready is offline
Find More Posts by glmccready
Gary
glmccready's Avatar
United States, MD, Salisbury
Joined Mar 2011
albert: I haven't had any trouble with my two MK birds with the latest firmware. I see they did update the end "letter" a few times for bugs.
glmccready is offline Find More Posts by glmccready
Old Jul 20, 2012, 02:20 PM
DroneBuilder is offline
Find More Posts by DroneBuilder
United States, TN, Brentwood
Joined Oct 2010
Coincidentally, I have a bum compass that will not accept firmware.
It does, however, power up and provide some "gibberish" in MKTools "Terminal/Firmware Update" window. Interestingly, the "gibberish" starts with MK BL 0.2 or something like that. It seems that my compass wants to be a BL when it grows up!
I have recently had great success at flashing atmel-based ESC's with SimonK's firmware by using micro-clips attached to the legs of the atmel.
Does anyone know if it work to flash the 0.23a compass firmware to the compass using this method, to try and bring it back to life?
DroneBuilder is offline Find More Posts by DroneBuilder
Old Jul 20, 2012, 10:23 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
I'm pretty sure the 10pin side connector on compass has the usual mosi/miso/etc pads breakout to it. They might be using same bootloader as BL for the compass, so that could explain the BL stuff. If you connect it directly to mktools in by 10pin cable, it should probably display compass-specific stuff, does it not?
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Jul 21, 2012, 12:35 PM
Joined Oct 2010
I tried that, TC - to no avail.
But since it was just a lousy clone Mag, I went ahead and tried the "clips on the pins" method. I was quickly reminded that this is an Atmega 168, not an Atmega 8 (as I had been programming on all of these ESC's!)
But it took the programming just fine, and did not seem to erase whatever bootloader is on the chip. (Is that possible?)
In any case, the MK3Mag shows signs of life now. It is recognized in MKtools and I no longer get the dreaded red warning light on the status screen. However, when I checked the mag values, they are all over the place. I'll mount it with a Navi and an FC later and see if the calibration process gets the values where they belong.
I'm counting this as a win - among my many prior smoke-releasing losses!
Old Jul 21, 2012, 03:29 PM
dmsgodeep is offline
Find More Posts by dmsgodeep
Austin, Texas
Joined Apr 2009
Dead flight controller?
I was trying to load the vibration test tool firmware onto my FC2.0 board like I've done many times...and it had an error towards the end. Now the FC just sends a constant tone to the buzzer and I can't connect to it via MK tools. I tried connecting directly and also tried connecting through the Navi board. When I connect to Navi board...I see "Error:3 no FC Communication".
Did my flight controller die? I was just flying it right before this happened...so I know it was working. I can't imagine that a software load failure would fry the system.
Anything I can do?
Brent
dmsgodeep is offline Find More Posts by dmsgodeep
Old Jul 21, 2012, 07:23 PM
mitmit is offline
Find More Posts by mitmit
Moscow
Joined Jul 2006
Anything I can do?
Brent
hey Brent, try to reflash FC again with original mk hex. start software update in mktools first, choose hex - ok, then power up your fc, it should start in bootloader mode.
mitmit is offline Find More Posts by mitmit
Old Jul 21, 2012, 07:30 PM
Gary
glmccready's Avatar
Joined Mar 2011
I didn't even know there was a "vibration test tool"?
Old Jul 22, 2012, 03:50 PM
Austin, Texas
Joined Apr 2009
Awesome! That worked...thanks Mitmit.
I never even thought to do it in that sequence. Appreciate it.
Brent
Old Jul 22, 2012, 03:51 PM
Austin, Texas
Joined Apr 2009
It's here.
http://www.mikrokopter.de/ucwiki/en/VibrationTest
Old Jul 22, 2012, 04:54 PM
Gary
glmccready's Avatar
Joined Mar 2011
dmsgodeep: thanks, but apparently doesn't work with FC 2.1?
"The VibrationTest works with 1.2 and 1.3 FC boards.."
Old Jul 22, 2012, 08:48 PM
timecop is offline
Joined Dec 2010
2.1 has higher acc lowpass filter caps, which take out these vibration readings.
Discussion Mikrokopter Okto 2 build Roger_IIT Multirotor Talk 6 Feb 03, 2011 09:22 AM
Discussion Mikrokopter ME 2.0 Okto Build robin4 Multirotor Talk 16 Jan 12, 2011 03:07 PM
Discussion Mikrokopter / UAVP / quadrocopter / quadrotor build Arthur P. Multirotor Talk 16696 Nov 10, 2010 05:49 PM
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion PART 2 tend2it Multirotor Talk 2203 Nov 08, 2008 09:23 PM
