Old Mar 06, 2012, 02:37 PM
siim227 is offline
Find More Posts by siim227
World's fastest crashes
siim227's Avatar
Estonia
Joined Feb 2010
On the way to work. I had 10 minutes ...
Log House building (2 min 38 sec)
siim227 is offline Find More Posts by siim227
Old Mar 06, 2012, 06:43 PM
simonjardine is offline
Find More Posts by simonjardine
MultiRotor Jedi
simonjardine's Avatar
Australia
Joined Apr 2008
Originally Posted by htran View Post
@SimonJardine
Nice videos Simon. What do you think of the Cinestar frames? You don't like Droidworx frames anymore? What do you think of the Cinestar gimbal? Do you get any jitter?
Both machines are very nice, the Cinestar is a little larger and has less flex than the Droidworx machines. Due to the size of the booms.
The camera mount also works very well, if you were buying a Cinestar, then you should also buy the cinestar mount, it goes hand in hand :-)
Simon
simonjardine is offline Find More Posts by simonjardine
Old Mar 06, 2012, 09:28 PM
learnedinuk is offline
Find More Posts by learnedinuk
learnedinuk's Avatar
United States, MD, Prince Frederick
Joined Oct 2006
With a Smart-OSD it has a serial port that allows a Xbee to "daisy chain" through it.
Thanks, but unfortunately I have no such ports.
learnedinuk is offline Find More Posts by learnedinuk
Old Mar 07, 2012, 09:50 AM
dragant is offline
Find More Posts by dragant
dragant's Avatar
Belgrade, Serbia
Joined May 2010
Sony new model HDR-CX760V has amazing stabilization system. As it can be seen on some YT videos this system works very good! New Balanced Optical SteadyShot technology that provides up to thirteen times better stability than the regular Optical SteadyShot, according to Sony. Starting price $1.499.
It may be a very good camera for aerial videos.
Sony Balanced Optical SteadyShot (2 min 5 sec)
Sony HDR-CX760V Hand Wave (1 min 5 sec)
dragant is offline Find More Posts by dragant
Old Mar 07, 2012, 11:04 AM
nikivan is offline
Find More Posts by nikivan
Joined Dec 2005
Originally Posted by mitmit View Post
reel from snowy Russia.
looks better in HD
cheers
dimitri
Nice and smooth video, Dimitri. Can you tell us a bit more about your post-processing workflow? In particular, I see less pronounced stroboscopic effect in pan shots, and also less warping.
Nick
nikivan is offline Find More Posts by nikivan
Old Mar 07, 2012, 02:11 PM
mitmit is offline
Find More Posts by mitmit
Moscow
Joined Jul 2006
thanks Nick,
I mostly shot in 50p so that could be a reason for less strobe I suppose. even when converted to 30 or 25fps.
cheers )
Originally Posted by Old Man Mike View Post
What are you using for the copter and camera?
OMM
thanks Mike)
filmed with nex5 and hx9, as for platform - it depends, I have several different setups - y6, large octo and also some mid-sized quads.
mitmit is offline Find More Posts by mitmit
Old Mar 07, 2012, 06:32 PM
dragant is offline
dragant's Avatar
Belgrade, Serbia
Joined May 2010
Wind rose sea resort in Montenegro
Wind Rose (3 min 5 sec)
Old Mar 07, 2012, 07:20 PM
dmsgodeep is offline
Find More Posts by dmsgodeep
Austin, Texas
Joined Apr 2009
Panasonic GH2 questions
I am needing a new camera to shoot better stills and 1080p60fps video. I'm considering the Panasonic GH2 even thought it's a bit heavier than I had hoped.
I like the Sony Nex but don't want to pay that much.
Anyway...I have a couple of questions for those who use the GH2.
How do you trip the shutter? Can you just put it into burst mode and hold the shutter down? This is what I do with my Lumix fx35 and it works great.
Also...any issues with live video out while shooting video or stills?
If anyone has any other suggestions on cameras I should consider...I would appreciate it. I would like to stay below $1000. I have just found that most of the options out there don't have live video out during shooting.
Brent
dmsgodeep is offline Find More Posts by dmsgodeep
Old Mar 08, 2012, 03:03 AM
Nettraptor is offline
Find More Posts by Nettraptor
MK Addict
Nettraptor's Avatar
Hellas
Joined Jun 2009
NEX-5N Firmware Version 1.01 Update Released
Sony NEX-5N Focus Speed Comparison: Firmware 1.01 vs. 1.00 (3 min 42 sec)
more info
http://sonyalphanex.blogspot.com/201...01-update.html
Nettraptor is offline Find More Posts by Nettraptor
Old Mar 08, 2012, 03:31 AM
mitmit is offline
Moscow
Joined Jul 2006
Thanks Nett!
Old Mar 08, 2012, 03:51 AM
MK Addict
Nettraptor's Avatar
Hellas
Joined Jun 2009
Thanks Nett!
Your' welcome!!
here is the official SONY links
NEX-5N Firmware upgrade (Windows)
NEX-5N Firmware upgrade (Macintosh)
Old Mar 08, 2012, 09:21 AM
htran is offline
Find More Posts by htran
Joined Jan 2011
What do you think is better, the Cinestar gimbal or the AV200?
I've seen someone mount a Cinestar gimbal on a Droidworx frame.
Simon
htran is offline Find More Posts by htran
Old Mar 08, 2012, 12:42 PM
Old Man Mike is offline
Find More Posts by Old Man Mike
Old Man Mike's Avatar
Joined Sep 2007
http://vimeo.com/33452394
Very impressive video! It seems like professional level quality video postings are becoming the norm in this thread.
Which kopterworx system are you running?
OMM
Old Man Mike is offline Find More Posts by Old Man Mike
Old Mar 08, 2012, 12:48 PM
Panama TJ is offline
Find More Posts by Panama TJ
AD6-HL, MK3638, Pro Mount-200
Panama TJ's Avatar
Panama
Joined Oct 2011
Has anybody tested the AXi 2814/22 Droidworx Edition??
Technical Details For AXi 2814/22 Droidworx Edition
No. of cells (LiPo) 3-6
RPM/V 765 Kv
Max. Efficiency 85%
No load current 0.5A
Maximum Load 22.0A
Internal Resistance 0.168Ω
Diameter 35.00mm (1.38")
Length 37.00mm (1.46")
Shaft Diameter 4.00mm (0.16")
Max. Efficiency Current 8-19A
Glow Equivalent N/A
Weight 106.0g (3.7oz.)
http://www.electricwingman.com/axi-d...422-motor.aspx
Panama TJ is offline Find More Posts by Panama TJ
Old Mar 08, 2012, 03:11 PM
MultiRotor Jedi
Australia
Joined Apr 2008
They are exactly the same as the AXi 2814/22's except black with a little Droidworx sticker... They run best on 4 cell with 12 inch slow flyers.
Simon
Discussion Mikrokopter Okto 2 build Roger_IIT Multirotor Talk 6 Feb 03, 2011 08:22 AM
Discussion Mikrokopter ME 2.0 Okto Build robin4 Multirotor Talk 16 Jan 12, 2011 02:07 PM
Discussion Mikrokopter / UAVP / quadrocopter / quadrotor build Arthur P. Multirotor Talk 16696 Nov 10, 2010 04:49 PM
Discussion X-3D Brushless Quadrocopter, general quadrocopter, x-ufo discussion PART 2 tend2it Multirotor Talk 2203 Nov 08, 2008 08:23 PM
