Old Nov 10, 2010, 02:50 PM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
18dbi Circular Polarized Patch ?
Hi guys, ive come across this antenna :
http://www.interprojekt.com.pl/iapt-...tenn-p-71.html
The H15 model is really a 12dbi as we use linear vtx antennas, the H18 is really a 15 on a linear vtx.
They would appear to look to me like yagi`s enclosed more than patch antennas
The price though is appealling, 27 degrees beamwidth
Either way, if they are what they clain to be thats double the range possible over a 8dbi CP Patch that we currently use now
Any thoughts ?
Coyote64 is offline Find More Posts by Coyote64
Old Nov 10, 2010, 03:59 PM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
It'll be a helical antenna.
Make one for yourself...
http://helix.remco.tk/
Nigel.
Devonboy is offline Find More Posts by Devonboy
Old Nov 10, 2010, 04:44 PM
Coyote64 is offline
Coyote64's Avatar
Joined Dec 2007
I suppose it could be that one.
I wonder what they are really like for FPV purposes ?
Old Nov 10, 2010, 04:59 PM
Devonboy is offline
SW England
Joined Aug 2009
Same as a CP patch/panel antenna, but more 'reach' to it and tighter beamwidth, so not as forgiving in where you point it.
When it's 'on target' the received signal strength will be better than the patch given the same circumstance.
With a good tracker/spotter it should be fine, no different than using a long/high gain Yagi - although the helical will be 3db down compared to a similar spec Yagi when polarisation is the same at both ends.
Multipath problems will be improved with the helical over a Yagi.
Nigel.
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 09:54 AM
Discussion Flytron Circular Patch Reviews? atckirk FPV Talk 5 Aug 20, 2010 01:39 AM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 05:00 PM
Discussion Advantage of a Circular Polarized Patch Ant? Mach61 FPV Talk 2 May 01, 2009 10:53 PM
