Old Nov 10, 2010, 12:34 PM
Masterofbizaster is online now
Find More Posts by Masterofbizaster
Goneflying
Joined Jun 2010
Making a high wing a low wing
I picked up this global stick from hobbypeople & while laying out the parts I couldnt help but notice how nice it looked as a low wing plane.So now Im wondering if it would be possible to make it one.
I dont know anything about wing airfoils so I would like to know if the wing on this plane would fly well as a low wing aircraft,thankyou
http://www.hobbypeople.net/index.php...ery-hatch.html
Masterofbizaster is online now Find More Posts by Masterofbizaster
Old Nov 10, 2010, 02:04 PM
JRuggiero is offline
Find More Posts by JRuggiero
Blacksburg, VA 24060 USA
Joined Feb 2000
highflydreamer,
The wing will fly fine, either on top of the fuselage or on the bottom. It looks to me that you could turn the fuselage upside down, so that the curve of the top of the wing would fit the saddle in the fuselage. But that would also require moving the vertical fin from the top to the bottom of the fuselage. It might also be necessary to change downthrust and sidethrust angles, if there are any.
But there is not much good reason to make the change to a low-wing setup, other than the cool factor. I've changed two airplanes over from high wing to low wing configuration, but it required new fuselages to get what I wanted.
Are you an experienced pilot? Any experience modifying a model?
Jim R.
JRuggiero is offline Find More Posts by JRuggiero
Old Nov 10, 2010, 02:20 PM
Goneflying
Joined Jun 2010
Thanks jim,yes Im a experienced pilot but no I have no modeling experience.I was thinking of just tracing the outline of the wings root to the fuse & cutting it out.Then applying some plywood reinforcement where necessary but if it means building a new fuse than I wouldnt do it
Old Nov 11, 2010, 06:53 AM
low´n´slow is offline
Find More Posts by low´n´slow
Buildbuildbuild, Flyflyfly...
low´n´slow's Avatar
Copenhagen, Denmark
Joined May 2004
Once again, Mr. Woodward to the rescue Dereck did a severe kitbash of an Ultra Stick right here: http://www.rcgroups.com/forums/showt...t=dereck+stick It´s definately worth a read...
low´n´slow is offline Find More Posts by low´n´slow
Old Nov 12, 2010, 04:00 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Did I really write that? Must have been the pills post tonsilectomy...
Dreamer - chances are, your new toy's wing incidence is close to zero. If it has a symmetrical wing section, do like I did and just flip the fuselage. Looks to have a two piece wing from your photo - join with 2 degrees of dihedral each side, that'll be near enough for the configuration.
You will have to figure out putting the vertical stab on the 'new topside'. The one I 'bashed' had the tailfeathers bolted in, so that caused few issues. Checking that the tailplane incidedence comes out at zero is the tricky bit.
At risk of starting a squabble, a low wing configuration is way better than a high winged one - though there is some mileage in leaving the wing on the top and adding some anhedral, odd though this may sound. One contributor to my thread above remarked on a modeller who'd done just that. It would be quicker than my route.
I still have my modified 'Sweet'n'Lo' BARFStik, though one wing panel has 'acquired' a slight warp. To be expected with an open frame wing of that nature that's been stored in odd places too long.
If the wing is truly symmetrical in section, it will work both ways up just fine. One thing you need to check on is if there's any positive incidence angle to the wing as designed. If there is, and you flip the fuselage to put the present wing aperture on the bottom, it will become negative incidence, which ain't good.
Good luck with your project if you decide to 'bash' it. Mine flew far better after I'd reworked it.
Regards
Dereck
Dereck is offline Find More Posts by Dereck
Low wing vs. High wing Astrix Beginner Training Area (Aircraft-Electric) 6 May 03, 2005 09:02 PM
Question How does a low wing model fly compared to a high wing e-starter? pnh555 Beginner Training Area (Aircraft-Electric) 15 Feb 16, 2005 03:11 AM
the high wing/ low wing thing again robbie Modeling Science 5 Jan 21, 2005 07:08 AM
Low Wing To High Wing soejatono Modeling Science 2 Nov 04, 2004 02:52 PM
High-wing, mid-wing or low-wing? e-geezer Modeling Science 3 Oct 22, 2003 12:26 PM
