Old Mar 30, 2011, 07:16 PM
jet-ster is offline
Find More Posts by jet-ster
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
oops I forgot to turn down the res on my camera, pictures are to big sorry about that.
jet-ster is offline Find More Posts by jet-ster
Old Mar 31, 2011, 12:01 AM
mpope1 is offline
Find More Posts by mpope1
mpope1's Avatar
gilbert,az
Joined Dec 2005
Originally Posted by jet-ster View Post
Thank you Mike! Your awesome! I just got to make sure I don't over screw the screws on the wings. I got a heavy hand. Thanks for the heads up on the rudder. This is what I did after what you had advised me to do. Thanks again! Now moving on to the fan/ducting. Spent a few days trying to figure what the heck I'm going to do with the front gear door. SO I called Tam up and he told me that on his P-20 setup he left it open like you did Mike.
Good job on the rudder linkage, mine is very similar and works great. I put my door back on, I had taken it off cause it wasn't closing and holding up the nose from retracting. It took me a while to realize it wasn't the door, it was the retract. I had to loosen the mounting screws, the bulkhead was binding it. When it would get close retracting it would stall, now its fine and working again. The door isn't scale but it looks good.
mpope1 is offline Find More Posts by mpope1
Old Mar 31, 2011, 08:16 AM
jet-ster is offline
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
I was think of how to install the nose door, but with a single door it would look really goofy. You'll just see a jet, gear door and the wheels. So doing a double door would be really nice, but man it's gona be tight! Those C hinges are getting it the way. So an option would be using regular hinges.
Old Mar 31, 2011, 08:18 AM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Got two more flights yesterday before sunset. This plane has great flight characteristics, no bad tendencies whatsoever. I was afraid to slow it down enough for landing, but after couple of fly-by's with flaps down, I am getting the hang of its stalling characteristics. Both motor and ESC came out at around 90F after 4 mins, and batteries were 100F. Going to try 8s-4000mah packs next to see if duration can be extended a bit.
Steph280 is offline Find More Posts by Steph280
Old Mar 31, 2011, 02:17 PM
Steph280 is offline
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Been playing around with a set of Sapac brakes. This should be a drop in fit with the E-Flite 15-25 retracts. Our club runway is very short and every bit will help.
Old Mar 31, 2011, 07:00 PM
stmbike is offline
Find More Posts by stmbike
United States, CA, Palm Desert
Joined Jan 2009
fan/motor?
Steph280 which fan/motor are using to fly on 8s? Also, the picture of the sapac brake setup. Is that a sapac strut also? thanks stm
stmbike is offline Find More Posts by stmbike
Old Mar 31, 2011, 08:18 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
I actually don't mind the single door, its only open on take off's and landings and it feels better in the air having the nose bay closed up. I guess I am used to that style door cause its similar to my other jet. Here is a vid my daughter took the other night, she only caught the landing. It was hard to see now that the sun is going down at the west end of the runway. Now I know why we were the only people there that late in the afternoon!
T-45 landing 3-22-11 (0 min 19 sec)
Old Mar 31, 2011, 10:49 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
Here is a vid I stumbled across, same front door
T45 Bae Hawk crash G.A.S. (9 min 11 sec)
Old Mar 31, 2011, 11:19 PM
Steph280 is offline
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
HET 700-68-1500 motor with HET 9305-700 fan. I followed Herbs lead on this setup and it works great. These 68mm motors are larger than standard so they dissipate heat better, only problem is the motor will not fit wemotec fans.
Those are HK struts similar to what mpope1 is using. They are identical to Sapac strut except the Sapac wheel axle are clamped instead of single set screw. Fits the Sapac brake perfectly. I have not installed them yet since the wheel well needs to be modified. Too busy flying the bird.
Old Apr 01, 2011, 11:19 AM
Jetnfast is offline
Find More Posts by Jetnfast
Jetnfast's Avatar
United States, CA, Temecula
Joined Feb 2008
Steph280 - you mentioned you got the struts from HK which are similar to SAPAC? Do you have a link to them? I have searched HK's site with no luck. Could you post a link? Thanks!
Jetnfast is offline Find More Posts by Jetnfast
Old Apr 01, 2011, 11:22 AM
Jetnfast is offline
Jetnfast's Avatar
Joined Feb 2008
I think I found them here:
http://www.hobbyking.com/hobbyking/s...dProduct=11300
Are you using the SAPAC tires, wheels and brakes with the HK struts? I think that is what it looks like in your pic above?
Old Apr 01, 2011, 12:01 PM
Steph280 is offline
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Yes SAPAC tires/wheels are needed for the SAPAC brakes to work.
However, mpope1 did not have very good luck with these struts as mains. Maybe he can chime in with his experiences.
Old Apr 01, 2011, 01:22 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
The prodesign struts are week for this size plane, good for a foamy or a lighter aiframe. I am still using the nose strut, doesn't take as much abuse.
Old Apr 01, 2011, 06:37 PM
jet-ster is offline
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
Hey do you guys have any experience with the "hifei ESC 90A opto" ESC? I found an extra one laying around. I think this was what the used for the HET super sniper manual. I don't know if I have the programing card. But what do you guys think about using this on the ARC 75-1?
http://www.hifei.com/en/News_View.asp?NewsID=55
Old Apr 03, 2011, 01:43 AM
Mannyman535 is online now
Find More Posts by Mannyman535
edf flyer
Mannyman535's Avatar
United States, CA, Marina
Joined Feb 2009
Servo
I'm wondering what size servos for the surfaces
Mannyman535 is online now Find More Posts by Mannyman535
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Sold Ultrafly T-45 Hawk Pusher NIB mgroves Aircraft - Electric - Jets (FS/W) 0 Sep 15, 2010 03:08 PM
Sold Ultrafly T-45 BAE Hawk Pusher mgroves Aircraft - Electric - Airplanes (FS/W) 0 Sep 15, 2010 03:06 PM
