Old Feb 10, 2011, 11:41 PM
Double E is offline
Find More Posts by Double E
Double E's Avatar
Atlanta, GA
Joined Mar 2009
Hey Guys,
I have the JTM L-39 and T-45 and I stongly recommend the Bohetec C21 retracts over any others on the market at this time. The RCLanders won't handle the weight of the almost 10lb JTM planes and the JTM retracts have quite a bit of play and the side rails won't hold up to anything but greased landings on paved runways. I have about a dozen flights on the L-39 with the JTM retracts and I have had to order the Bohetec retracts to replace my bent up JTM's. My only other recommendation would be to go to the other extreme and wedge in some Eflite 60-120 electric retracts that should handle plenty of rough landings on a 10lb plane.
Double E is offline Find More Posts by Double E
Old Feb 11, 2011, 12:08 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
SpringAirs would be another tough choice, am about to talk to them about a set that will take the struts, hopefully they can put something together that everyone can access.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Feb 11, 2011, 04:25 AM
gjmjoe017 is offline
Find More Posts by gjmjoe017
My Lipo is Bigger than Yours!
gjmjoe017's Avatar
Chesterfield,Missouri
Joined Sep 2003
Just googled Bohetec retracts and got nothing.Where do you get them?
gjmjoe017 is offline Find More Posts by gjmjoe017
Old Feb 11, 2011, 04:28 AM
-PaX- is offline
Find More Posts by -PaX-
EDF addict
-PaX-'s Avatar
Friedrichshafen, Germany
Joined Jan 2005
Try spelling it Behotec
-PaX- is offline Find More Posts by -PaX-
Old Feb 11, 2011, 04:35 AM
gjmjoe017's Avatar
Joined Sep 2003
Thanks -pax-!!Way to early in the morning,my fingers and brain just can't get in sink!!!!
Old Feb 11, 2011, 01:07 PM
Steph280 is online now
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Do you guys think the elevator's covering-type hinge is strong enough?
Steph280 is online now Find More Posts by Steph280
Old Feb 11, 2011, 06:37 PM
mpope1 is offline
Find More Posts by mpope1
mpope1's Avatar
gilbert,az
Joined Dec 2005
Just got back from Desert Storm Jet rally, got 2 flights on the t-45 today. Lots of people comment on how nice the plane is, was able to mix it up with the big turbines no problem!
mpope1 is offline Find More Posts by mpope1
Old Feb 11, 2011, 09:06 PM
Double E is offline
Double E's Avatar
Atlanta, GA
Joined Mar 2009
Altecare rc out of Canada has the behotec or bohetec retracts. The C21s are the ticket for a 90mm jet
Old Feb 11, 2011, 09:16 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Is there clearance on the behotecs for a real strut? It's hard to explain but the Springair 602's can only use a wire strut because of the location of the hole on the trunion. When in the "up" position, an 8mm dia strut will hit the pneumatic cylinder and not allow them to retract all the way.
chalmrast is offline Find More Posts by chalmrast
Old Feb 12, 2011, 01:37 AM
sikky is offline
Find More Posts by sikky
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
be out there in the am
sikky is offline Find More Posts by sikky
Old Feb 12, 2011, 11:38 AM
jet-ster is offline
Find More Posts by jet-ster
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
Here is my final gear option. The rclanders are just way to heavy. SO i'm gona use the freewing 4mm retracts with the CMP struts. Less work to drop them in to.
Danny
jet-ster is offline Find More Posts by jet-ster
Old Feb 12, 2011, 11:50 AM
gjmjoe017's Avatar
Joined Sep 2003
Danny,I weighed the Jet Teng retracts that I got for my Jet Teng T-45 and with all the components came out to about 12oz.I believe that's what your weight test showed on the RC Lander electrics.I sent my Jet Tengs back,because I just have decided that eletric is going to be so much more reliable.I guess my question is,for a 9-10lb plane,I think it will take retractsthat are probably in this 12oz weight catergory,don't you think?I have the RC Landers on the way and I am going with those,because they are about the same weight as the Jet Tengs I was going to use,but electric and I think will be more reliable.
Old Feb 12, 2011, 12:06 PM
jet-ster is offline
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
these are lighter but for sure not as tuff as the rclanders. Mike is having a blast with his eflites so I though I give these a shot since they are 4mm. Pretty much "a drop in". Lets see how they handle before doing the rclanders. Installing the rclanders takes some butchering.
Old Feb 12, 2011, 12:16 PM
gjmjoe017's Avatar
Joined Sep 2003
Good luck,hope they work out.I am hoping the RC Landers will fit easily in my JTM,we shall see!!!
Old Feb 12, 2011, 03:41 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
Got the t-45 cockpit and pilots from hobby king today. Almost a perfect fit, just a little dremeling and it looks great!
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Sold Ultrafly T-45 Hawk Pusher NIB mgroves Aircraft - Electric - Jets (FS/W) 0 Sep 15, 2010 03:08 PM
Sold Ultrafly T-45 BAE Hawk Pusher mgroves Aircraft - Electric - Airplanes (FS/W) 0 Sep 15, 2010 03:06 PM
