Old Jan 30, 2011, 06:59 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
2S A123 straight into the receiver for every plane I own.
chalmrast is offline Find More Posts by chalmrast
Old Jan 30, 2011, 07:06 PM
mpope1 is offline
Find More Posts by mpope1
mpope1's Avatar
gilbert,az
Joined Dec 2005
I use a cc bec at 6v regulating a 500 mah 2 cell lipo, I use the cc bec in most of planes and never had any issues. Here is a couple of pix from the aef, thanx Chad!
mpope1 is offline Find More Posts by mpope1
Old Jan 30, 2011, 07:21 PM
BILLYDSRC is offline
Find More Posts by BILLYDSRC
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
Me too!! A123 on all my planes.. On my big stuff I use 2-A123 packs with 2-sw. I had a CC-bec kill a plane before.
BILLYDSRC is offline Find More Posts by BILLYDSRC
Old Jan 30, 2011, 07:32 PM
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
I have to say... this little jet received ALOT of attention at the AZ Electric Festival these past 4 days. Many of the big EDF guys could not believe how well this plane looked and flew for the price of the airframe and power plant.
Of course Mike's skills at the sticks didn't hurt either
They couldn't believe it cost less than $175.00, they couldn't believe the fan & motor combo was only $70.00, they couldn't believe the performance & sound on 6S, and they were amazed that the E-flite retracts are plenty strong for this setup!
Great Job Mike!! Only wish I had mine and we could have had them up in the air together.
Old Jan 30, 2011, 08:09 PM
mpope1 is offline
mpope1's Avatar
gilbert,az
Joined Dec 2005
we will!!
Old Jan 30, 2011, 08:28 PM
stmbike is offline
Find More Posts by stmbike
United States, CA, Palm Desert
Joined Jan 2009
cc pro bec
Thanks for all the info guys. If I do use the pro bec can I input it into 2 channels via y-harnesses so I can still use those 2 channels for flight control? I I ran out of channels on my Futaba 8 channel receiver and I wanted to separate the rudder from nose wheel, for obvious reasons to have better set up. I like the nose wheel having much less throw. Maxx Products makes a great reverse y-harness that has a small digital pod. Because I can't get to the hardware on the rudder, I use the y-harness to have adjustment to the rudder after the nose wheel is dialed in. The small pod is in on the inside of the fuse under the canopy. It's not like using sub-trim in the radio, but it's not bad. Stephan
stmbike is offline Find More Posts by stmbike
Old Jan 30, 2011, 09:10 PM
jet-ster is offline
Find More Posts by jet-ster
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
http://rc-castle.com/shop/product_in...oducts_id=1744
Rclander and CMP struts $186.....
jet-ster is offline Find More Posts by jet-ster
Old Jan 30, 2011, 09:18 PM
jet-ster is offline
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
I not sure if you can, but just shoot an email to CC and they can help. They're pretty good at it from what I have seen.
Old Jan 30, 2011, 10:01 PM
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
At the AZ Electrc Fest XPS had sets of Shulman Aviation electric retracts that would be a great fit for this bird. They are basically the smaller RC Lander housings with struts I've never seen. The struts are trailing link. They were selling them for $129.00 total at the show price.
They are probably not on their website but it would be worth calling them if interested. They are rated for up to 8lbs!
Old Feb 03, 2011, 12:46 AM
takiss is offline
Find More Posts by takiss
Patras, Greece
Joined May 2007
Subscribed.
takiss is offline Find More Posts by takiss
Old Feb 03, 2011, 12:48 AM
stmbike is offline
Joined Jan 2009
rc lander 90mm dps fan
I'm using the new dps rclander 90mm fan. It has a removable lip which I believe needs to come off to get the ducting on it. However, how do you actually mount it to the frame in the jet. It has no flanges to. I was thinking zip ties, but is this a good method? thanks for any info. Stephan
Old Feb 03, 2011, 08:52 AM
gjmjoe017 is offline
Find More Posts by gjmjoe017
My Lipo is Bigger than Yours!
gjmjoe017's Avatar
Chesterfield,Missouri
Joined Sep 2003
Originally Posted by jet-ster View Post
Do you have these and if so how well do they work,thinking about them for my JTM T-45.
gjmjoe017 is offline Find More Posts by gjmjoe017
Old Feb 03, 2011, 01:12 PM
jet-ster is offline
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
I did order a set of the rclander/cmp retracts. I also ordeedr a set of freewing 90mm F-18 retracts. I buddy of mine has them and said they pretty darn stout for 69 bucks. Also he said they use a 4mm instead of like most others 3mm shaft. That'll be a very good drop in and save ALOT of weight.
Old Feb 03, 2011, 02:53 PM
besthobbie is offline
Find More Posts by besthobbie
Cheektowaga NY
where did you order them from for the cmp t45?
besthobbie is offline Find More Posts by besthobbie
Old Feb 03, 2011, 02:56 PM
jet-ster is offline
Watts Up?
jet-ster's Avatar
USA, TX, Arlington
Joined Jun 2006
http://rc-castle.com/shop/product_in...oducts_id=1704
here
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Sold Ultrafly T-45 Hawk Pusher NIB mgroves Aircraft - Electric - Jets (FS/W) 0 Sep 15, 2010 03:08 PM
Sold Ultrafly T-45 BAE Hawk Pusher mgroves Aircraft - Electric - Airplanes (FS/W) 0 Sep 15, 2010 03:06 PM
