Old Nov 11, 2010, 01:43 PM
Lithonion is offline
Find More Posts by Lithonion
Have you seen my nut?
Lithonion's Avatar
Omaha, Nebraska
Joined Mar 2006
Originally Posted by CryHavoc View Post
Which E-flights? The 15-25 size? If so wont they be at the limits of what this plane will end up at?
Some predictions on the other thread put the finished weight at around 8lbs.
Good point. Just an FYI to all those that don't know and you probably already all do. The 15-25 size have a max wieght rate on the airframe of 7lbs. I have a set in a plane that is 6.5lbs with battery and they are holding up fine.
Lithonion is offline Find More Posts by Lithonion
Old Nov 11, 2010, 01:54 PM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
The electrics have to be the small size, I have heard that the 120 size are way too big.
I have TamJets mini retracts on my 8lb Starfires, I have two, and these minis are severe overkill. A bad landing will just rip them right out. I also have Tam's struts attached.
Bottom line, I think Bob Vincent is on the right track, whatever retracts that will fit, but wire struts. Just bend them back after a bad landing.
Flyboytha1 will build this plane with the best stuff, but based on his past achievements, the cost will be $2500 when finished.
To each his own.
SCALEFAN is offline Find More Posts by SCALEFAN
Old Nov 11, 2010, 02:05 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
I'm using Tam's retracts with wires for now. When the struts are available, I'll get them! They come with the matching aluminum wheels
rvincent is offline Find More Posts by rvincent
Old Nov 11, 2010, 02:07 PM
Tumbler is online now
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
I have Tam's retracts in a 10.5lb plane and they work great. The wire struts are no good off grass though at that weight and bend back on take off every time. Only got worse as time went on and got softer from bending back and forth. Once I put the trailing links on it seems like the units themselves can handle any weight you throw at them.
Brian
Tumbler is online now Find More Posts by Tumbler
Old Nov 11, 2010, 02:19 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by AIR SALLY View Post
... So who has one on here to do a build thread on ????
... I posted a bunch of pictures of the CMPro T-45 I got last week here, just the plane out of the box for now.
Seems nicely made & relatively lightweight compared to other CMPro stuff
I have the fan, motor (Neu) & esc combo, the Springair 602's seem to fit just fine.
http://www.rcgroups.com/forums/showt...1336098&pp=100
Herb is offline Find More Posts by Herb
Old Nov 11, 2010, 02:39 PM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
Hi Herb,
What Neu motor are you using and how many cells?
Old Nov 11, 2010, 02:47 PM
SCALEFAN is offline
Done it all
Joined Feb 2006
You guys got me wrong,Tam mini's are great, with struts even better. However there are other other things to consider.
1. waiting time
If you are in a hurry, and want to fly this bird in two weeks or less, I have a spare set of TamJet minis with struts that I will sell at twice the normal price. LOL.... E-Flights you can get tomorrow.
Old Nov 11, 2010, 02:49 PM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
Al Been hanging with Tam and learning I see I have a set already
Old Nov 11, 2010, 03:07 PM
Tumbler's Avatar
Joined Feb 2003
Wow, this pic from Herb's blog shows it is quite a bit bigger than the Sapac Hawk. Makes me feel like now I can justify getting it even though I have the Sapac Hawk.
Old Nov 11, 2010, 03:12 PM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
Wow guys opening the box it really is VERY nice!! I like CMP stuff already as I have their 120 sized Spit converted to electric but this kit is really nice! The paint and pre-printed covering is sharp! it is an eye pleaser for sure. It's just big enough to be a really nice 90mm size plane. Should have a b it better wing loading than the SAPAC too.
Old Nov 11, 2010, 03:18 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
I have the 10-15's in a 6.5lb L-39. A little springy but holding up fine. The 15-25 are the same units, just thicker wire.
Also, I've had good luck with EPF Hobby's DSR46T units. I upgraded to the metal side plates as well. They have a new set with trailing link struts & metal sides. They will be strong enough for this plane if it is in the 8-9lb range.
http://www.southerncrossrc.com/virtu...lete-titan-set
chalmrast is offline Find More Posts by chalmrast
Old Nov 11, 2010, 03:54 PM
SCALEFAN is offline
Done it all
Joined Feb 2006
I opened the box, just had to do it. The below quote is good advice based on what I saw and felt. The main wing is thin, built up and covered with CMP thick covering. It will resist wrinkles, but there are several hollow points built into the wood to lighten it up.
Some of you guys could actually over build it into a flying brick. This baby needs to be kept light. It should be built like a heavy foamy. I'm not even sure about the Midi Pro with an ARC motor.
I gotta jump over and see what Herb is doing, for some reason the 90mm setup looks to be too big. OK I jumped over, Herb has it taped together so from basics it looks like the 90mm Midi will fit perfect, the ducts fit.
Note Herb's warning about the wings, very thin and very small. A hard landing might push the gear all the way through. There are some negatives. This plane has to be built light...
Old Nov 11, 2010, 04:02 PM
bigjohn is online now
Find More Posts by bigjohn
dare to be dull
bigjohn's Avatar
Deland, FL
Joined Jun 2002
I have no involvement with T-45's of any scale, but came across this cool photo of a new and different scheme for the hawk. Ya'll enjoy.
http://www.airliners.net/photo/USA--...awk/1811273/M/
bigjohn is online now Find More Posts by bigjohn
Old Nov 11, 2010, 04:04 PM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
Al it just needs to be landed, not dropped on the runway
Old Nov 11, 2010, 04:13 PM
tomcee is offline
Find More Posts by tomcee
Joined Aug 2010
here is the missing piece :-)
(see photo)
tomcee is offline Find More Posts by tomcee
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Sold Ultrafly T-45 Hawk Pusher NIB mgroves Aircraft - Electric - Jets (FS/W) 0 Sep 15, 2010 03:08 PM
Sold Ultrafly T-45 BAE Hawk Pusher mgroves Aircraft - Electric - Airplanes (FS/W) 0 Sep 15, 2010 03:06 PM
