Old Nov 29, 2010, 09:31 PM
sikky is offline
Find More Posts by sikky
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Dam I'll fly mine in 2 days after it gets here for a $100 bucks!!
We don't need no fights guys.
sikky is offline Find More Posts by sikky
Old Nov 29, 2010, 09:33 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Yep I was told my A-4 would be a boat anchor too I was told My CMP 120 Spitfire was too heavy at 11lbs but it flies like a kite! Right now I have 4 planes on my work bench. My Falcon 120, my Starfire (actually its at the painter's), my new 120 Spitfire, and this 90mm Hawk. I put this Hawk way out ahead of the others in the build que but for one reason or another I have yet to get her done because of travel, yard work, Christmas decorations this past weekend. But I will get it done ASAP. It won't be any heavier than anyone elses on 8 or 10 cells. Maybe lighter cause of Tam's retracts, Stu's fan, wire struts (for now).
rvincent is offline Find More Posts by rvincent
Old Nov 29, 2010, 09:39 PM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
OH Sikky, wer're not fighting. Just a friendly one way wager, Bob has nothing to loose and if I was with him right now, we both would be smiling ear to ear.
SCALEFAN is offline Find More Posts by SCALEFAN
rvincent is offline
rvincent's Avatar
Joined Jul 2004
Anyway I love ya Al And I'm not the least bit afraid to fly this plane. Just need time to finish it I had no room to bring it with me on this trip. And that stinks cause here I am sitting in a hotel room watching TV when I could have been at home building...
Old Nov 29, 2010, 09:47 PM
sikky is offline
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
I just find it really hard to believe not 1 flight report!!!
Not 1!
Old Nov 29, 2010, 09:49 PM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
Me too actually. As many in this thread alone I thought at least one "Epoxy Cowboy" would have galloped it down the runway by now
Old Nov 29, 2010, 10:03 PM
SCALEFAN is offline
Done it all
Joined Feb 2006
I really think that the intention of the manufacturer was to have this plane flown with a 4S to 6S 3300mah battery and very high KV motor. In other words, similar to a foamy with slightly more weight.
I am comparing this T-45 with my Nitroplanes Starfire, 7lbs, 6S battery, Midi Pro 90mm fan with ARC motor. Even with all that the Starfire is not a rocket ship with retracts and the wing area is much much larger than this T-45 that is going to weigh much more.
I say, keep it light, keep it cheap, test fly it before installing retracts. Use the on-line CG computer to verify a ball park reading for the CG. Garbage in will produce garbage out, but another opinion on CG will help. If the leading edge of the wing is straight, do not measure as with a swept wing. A tapered wing is not a swept wing. Enter zero for the sweep.
http://adamone.rchomepage.com/cg_calc.htm
Old Nov 29, 2010, 10:05 PM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
I have 3 other Hawks to judge CG by I ain't skeered
Old Nov 29, 2010, 10:07 PM
SCALEFAN is offline
Done it all
Joined Feb 2006
One note: CG on a real plane does not have to be perfect. With a real plane, the plane can be flown safe if the computed CG is within a safe flying envelope, determined by the manufacturer. This safe envelope is in the airplane manual kept on board the plane at all times. Even commercial jets use a computer to figure if they are safe.
In this CG program the % of MAC is the envelope for an RC model. Use between 5% and 15% and the plane should fly safely.
Hope I helped.
Old Nov 29, 2010, 10:17 PM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
Hey Marvin I just watched the maiden of your F-4. It was clearly an incidence issue. Your horizontal stabs had at least a 4 degree negative attitude so it required a ton of up trim. That up trim fighting the negative incidence is causing the tail of the plane to fly in a constant stall with all that added drag. It wasn't overly nose heavy as you may have suspected because it leaped off the ground with a bump and didn't slam nose first, it tried to fly. I can garranty if you changed that tail plane incidence it would fly much slower and with out all that "washy" roll tendency.
Old Nov 29, 2010, 10:23 PM
FL62 is offline
Find More Posts by FL62
Average Joe 2 Semi-Pro n Back!
FL62's Avatar
United States, AZ, Queen Creek
Joined Feb 2004
Bob,
I'll throw in my .02 on the CG.
My JTM Hawk flies best at around 3.75"-4" back from the LE at the wing root, balanced upside down.
Since these hawks have similar moments, with a slightly narrower chord on the CM Pro - I'll bet a good CG will be around 3.25"-3.5" back.
FL62 is offline Find More Posts by FL62
Old Nov 29, 2010, 10:38 PM
keith b is offline
Find More Posts by keith b
Oneonta Alabama
Joined Aug 2010
Hey Mike the JTM Hawk scales out at 1/9.5 onthe Fuse and 1/8 on the wings .I wonder How this one compares to size.Oh and by the way looking forward to your gear door build.
keith b is offline Find More Posts by keith b
Old Nov 29, 2010, 10:39 PM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
I was thinking 3.25 as well to start with.
Old Nov 29, 2010, 10:47 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
I agree 100%. Mine will be approx 6.5lbs on a 6S-1900kV setup. 1700-1800 watts with a thrust tube diameter of about 72mm. I am basing the AUW from Herb's weights of his parts.
Matt Sylvester's ProDesign Mig 15 flies over 115mph on this setup and the plane is almost the exact same size and weight. Not apples-to-apples I know!! but, same overall size, weight, power, and construction.....
And Al, you can call me Chad instead of "Gilbert, AZ."
chalmrast is offline Find More Posts by chalmrast
Old Nov 29, 2010, 11:04 PM
mpope1 is offline
Find More Posts by mpope1
mpope1's Avatar
gilbert,az
Joined Dec 2005
Chad, I am gonna order the same system as you and Matt. Matt proved that its solid, fly's his Mig real nice and also your L-39! You have a link where I can get it at?
mpope1 is offline Find More Posts by mpope1
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Sold Ultrafly T-45 Hawk Pusher NIB mgroves Aircraft - Electric - Jets (FS/W) 0 Sep 15, 2010 03:08 PM
Sold Ultrafly T-45 BAE Hawk Pusher mgroves Aircraft - Electric - Airplanes (FS/W) 0 Sep 15, 2010 03:06 PM
