Espritmodel.com Heli Air
Old Jun 25, 2012, 12:38 PM
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
Was a lot of luck I think, but for sure made you pucker up.
seadog985 is offline Find More Posts by seadog985
Old Jun 27, 2012, 10:40 PM
High Voltage
dhf23's Avatar
United States, GA, Kennesaw
Joined Oct 2011
I just wanted to share a couple of pics of my T-45 flying. One of the pics is on take off. Im running a not so tipical set up. Het 700 series fan with a het 2610kv, 150amp esc 6s 5300 mah 50c. This set up is wicked,,
dhf23 is offline Find More Posts by dhf23
Old Jun 27, 2012, 11:07 PM
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
Nice pics. What landing gear are you using and how are they holding up on the grass runway?
Old Jun 28, 2012, 07:49 AM
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Dear lord, 2610kv I was getting 90A with an 1850kv motor in that fan, you must be pulling pretty hard from the packs.
scatsob is offline Find More Posts by scatsob
Old Jun 28, 2012, 08:34 AM
Joined Nov 2005
The amps would be well over 150...around 10lbs of push....would love to see some vids of this thing in the air no doubt
erh7771 is offline Find More Posts by erh7771
Old Jun 28, 2012, 10:07 AM
United States, TN, Jackson
Joined Mar 2007
I'm running an 1850kv motor on 8S with an HET fan...Batts I run are rated @ either 40C or 45C with 5000mAh capacity...On 8S the fan is spinning around 55k...If 8S proves to be too much then I can always drop down a cell to 7S...On 8S this combo has a little over 3100 watts...Amperage was measured @ 105 amps..
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Jun 28, 2012, 11:38 AM
High Voltage
dhf23's Avatar
Joined Oct 2011
Your are right its pushing 10.3lbs but my amp draw hovers at around 118amps. Indeed this is a hot set up. I beefed up the esc wiring to 10-8g. With 150amp esc and about 4min flight time my batteries are barely warm. I have ran higher mah batteries 6000 6s,2x3000 6s in series and it flies with authority still. To me this plane needs power to fly it succesfully and on take off. I will try to post vid soon..
Old Jun 28, 2012, 12:31 PM
Joined Nov 2005
That's pretty good, you're getting over 10lbs of thrust on only 2500 watts if the volts are settled at 22.3 or something around it...
Did you do a bench test on this before flight?
What's your AUW?
Cool,...
Old Jun 28, 2012, 12:52 PM
High Voltage
dhf23's Avatar
Joined Oct 2011
What's your AUW?
Cool,...
Yes I did with fear and this thing screams! Auw is around 2400w
Old Jun 28, 2012, 01:03 PM
guyst's Avatar
Joined Feb 2010
Which retracts and landing gear are you using?
guyst is offline Find More Posts by guyst
Old Jun 28, 2012, 01:09 PM
High Voltage
dhf23's Avatar
Joined Oct 2011
Thats funny you ask. I fabricated the same replicas of the tam struts with the spring.
These are the wheels I used and they are perfect;
http://parkrcmodels.com/product_info...oducts_id=1089
Old Jun 28, 2012, 05:31 PM
Joined Mar 2007
That funny that you ask. I fabricated the same replicas of the tam struts with the spring.
Those wheels are da BOMB!!!...I have a set on my A-10...
About the struts---Can you post pics of how you made these???...Or post some pics of the finished product???...
Kevin
Old Jun 28, 2012, 06:14 PM
High Voltage
dhf23's Avatar
Joined Oct 2011
Kevin
Sure will but they are the prototype not the finish product . I will post the pic later tonight..
Old Jun 28, 2012, 07:46 PM
High Voltage
dhf23's Avatar
Joined Oct 2011
Kevin
Here is the actual main strut prototype Ive flown the T-45 with. I will smooth things up on the finished strut and use different screws as well.
Old Jun 28, 2012, 08:41 PM
Joined Mar 2007
That looks great!!!...Did you fabricate the upper portion of the strut as well or did you use an off the shelf unit???
Kevin
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Sold Ultrafly T-45 Hawk Pusher NIB mgroves Aircraft - Electric - Jets (FS/W) 0 Sep 15, 2010 03:08 PM
Sold Ultrafly T-45 BAE Hawk Pusher mgroves Aircraft - Electric - Airplanes (FS/W) 0 Sep 15, 2010 03:06 PM
