Old Jun 14, 2012, 12:35 PM
nerv is offline
Find More Posts by nerv
nerv's Avatar
Joined Jan 2007
Does any one here has a new or used main wing which they want to sell? Plz PM me, thanks.
nerv is offline Find More Posts by nerv
Old Jun 14, 2012, 03:31 PM
Hixxer is offline
Find More Posts by Hixxer
United Kingdom, England, Nantwich
Joined Jan 2012
If I end up buying another kit so I get a fus I will sell you the wing
Hixxer is offline Find More Posts by Hixxer
Old Jun 16, 2012, 01:54 PM
guyst is offline
Find More Posts by guyst
guyst's Avatar
Joined Feb 2010
Does anyone here has a new kit that they want to sell?
It out of stock at Nitroplanes and I can't find elsewhere I can buy it.
guyst is offline Find More Posts by guyst
Old Jun 16, 2012, 02:01 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
how about this one, better looking and in the usa. I believe they are identical models just diff paint scheme
http://www.hobbyking.com/hobbyking/s...arehouse_.html
jcdfrd is offline Find More Posts by jcdfrd
Old Jun 16, 2012, 02:45 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
I do. Where are you located?
scatsob is offline Find More Posts by scatsob
Old Jun 16, 2012, 04:44 PM
dhf23 is offline
Find More Posts by dhf23
High Voltage
dhf23's Avatar
United States, GA, Kennesaw
Joined Oct 2011
I bought mine from here and they are in stock;
http://www.scaleflying.com/T-45-Duct...MM_p_1808.html
dhf23 is offline Find More Posts by dhf23
Old Jun 17, 2012, 01:36 AM
Hixxer is offline
Joined Jan 2012
That's where I got mine from, delivered in pieces hoping they will sort me out with replacement parts
Old Jun 17, 2012, 04:51 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Hello, does anyone know where to get another canopy or fix the one I have...had a spill from a counter top the other day..
Thank you in advance for any input
erh7771 is offline Find More Posts by erh7771
Old Jun 17, 2012, 04:37 PM
guyst is offline
guyst's Avatar
Joined Feb 2010
PM Sent
Old Jun 20, 2012, 01:33 PM
seadog985 is offline
Find More Posts by seadog985
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
Getting close to finishing my T-45. Powered it up and WOW! A 64mm being the largest thing I have flown this thing has a lot of power. Still need to position the battery for a cg of 105mm and make a nest for it. Then I'll get a weight on her.
seadog985 is offline Find More Posts by seadog985
Old Jun 21, 2012, 05:16 AM
guyst is offline
guyst's Avatar
Joined Feb 2010
Have anyone tried the following setup from HK?
Alloy DPS Series 90mm EDF unit with 1280kv Motor - 2400watt (8s)
Alloy DPS-2 Series 90mm EDF unit with 1300kv Motor - 3400watt (10s)
Old Jun 21, 2012, 10:11 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
I'm thinking that those motors are a little low in kv to get decent performance from this plane for the weights of the batts needed to get good performance...(Needing 10S to get over 3000 watts)...I'm running an 1865kv motor on 8S...My setup produces on paper a little over 3000 watts and 55K RPM with an HET 9305 fan....This puppy performs like a jet is supposed to!!!!...Yes, I am running slightly over 100 amps but using 45C 5000mAh batts vs about 85 amps given the 8S HK setup...
All in all---I think that you can do better than to go with this fan/motor combo...
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Jun 24, 2012, 10:05 AM
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
Successful maiden yesterday. Our runway is mostly grass but we do have a small fabric runway. Its about 15' wide and 150' long. Was afraid it would be too short for take off and too narrow to hit on landing. I let a friend with much more experiance take her up. He was just able to get her wheels up at the end of the runway and kept it low to get some speed before pulling up. She flew well and just a few clicks here and there for trim. CG at 105 seemed good. Flew about 3.5 minutes I guess. The landing on the grass was a bit rough on the nose gear, ripping the stearing servo linkages out (easy fix). ESC was cool and battery still had 57% charge. Sure looked nice in the air. Sorry no pics.
Old Jun 25, 2012, 12:23 PM
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
Someone did get some pics of my T-45 maiden. The 1st is a series of photos of the 1st aborted takeoff. The plane was leveled out but was heading toward the bushes to the left of the runway. Without enough speed to clear the bushes the plane was set down. The second photo is of the successfull maiden.
Old Jun 25, 2012, 12:35 PM
heychas is offline
Find More Posts by heychas
"My grandma wants to fly jets"
heychas's Avatar
Richmond, VA
Joined Feb 2008
Holy crap! You must have some power underneath the hood. I can't believe you didn't tip stall during the 85 degree angle of bank turn off the runway!
Those extra obstacles around the field always keep things interesting
heychas is offline Find More Posts by heychas
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Sold Ultrafly T-45 Hawk Pusher NIB mgroves Aircraft - Electric - Jets (FS/W) 0 Sep 15, 2010 03:08 PM
Sold Ultrafly T-45 BAE Hawk Pusher mgroves Aircraft - Electric - Airplanes (FS/W) 0 Sep 15, 2010 03:06 PM
