Old Jun 05, 2012, 12:58 AM
seadog985 is offline
Find More Posts by seadog985
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
Any good ideas on securing the hatch? If it is in this thread please point me in the direction of the post number.
seadog985 is offline Find More Posts by seadog985
Old Jun 05, 2012, 06:41 AM
T-spin is offline
Find More Posts by T-spin
Joined Mar 2005
If you are talking about the canopy make a tongue in the front and a sliding latch in the back. If you are talking about the hatch at the bottom rear I used small screws and epoxy small pieces of wood inside for some thing to bite to.
Tony
T-spin is offline Find More Posts by T-spin
Old Jun 05, 2012, 06:54 AM
ysolomon is offline
Find More Posts by ysolomon
Another one on the way...
ysolomon's Avatar
Plano, Texas
Joined Feb 2009
any good ideas on securing the hatch? If it is in this thread please point me in the direction of the post number.
620, 976, 1080
ysolomon is offline Find More Posts by ysolomon
Old Jun 05, 2012, 10:47 AM
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
Thanks guys. Yeah I was talking about the canopy............brain fart.
Old Jun 07, 2012, 10:05 PM
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
Queston on wing fences. I have seen them placed near the end of the wing and I believe I have seen them placed in the middle of the wing. Which area is best and would 2 on each wing be better?
Old Jun 08, 2012, 04:24 AM
MrBlobby is offline
Find More Posts by MrBlobby
Nederland, NB, Waalwijk
Joined Sep 2006
Originally Posted by DaveBC View Post
Thanks for the compliments.TBH With reflex and 60% flap. This bird is EXTREMELY easy to grease. Hence the dissapointment with the bounce issue. It spoiled a perfect landing every time....
Hi Dave, very nice landing indeed. I am building the BEA Hawk and would like to know how much deflection is 60% flaps (mm movement at the TE), and also the same distance for the reflex you are using. That will give me a good starting point. I will be flying of grass and must bleed off as much speed as possible.
How much throw are you using on your control surfaces? I may have missed the post if you already mentioned this. This tread is just becoming tooo long ;-)
MrBlobby is offline Find More Posts by MrBlobby
Old Jun 12, 2012, 10:11 AM
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
Ok, getting ready to set CG. I've seen a few different numbers here. What is the final consensus and from where do I measure it?
Old Jun 12, 2012, 05:53 PM
DaveBC is offline
Find More Posts by DaveBC
Obessive Compulsive
Visalia, California
Joined Mar 2010
60% is equal to about 9/16 inch (1.4mm) and reflex is about 1/8 inch (3.175 mm)alerion crow.
DaveBC is offline Find More Posts by DaveBC
Old Jun 12, 2012, 05:54 PM
DaveBC is offline
Obessive Compulsive
Visalia, California
Joined Mar 2010
105mm
Old Jun 13, 2012, 08:37 AM
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
Thanks Dave. Do you measure from the forward wing joint?
Old Jun 14, 2012, 04:55 AM
Hixxer is offline
Find More Posts by Hixxer
United Kingdom, England, Nantwich
Joined Jan 2012
Aww man!!
My T-45 was delivered today, the box was in a bad condiditon and so is the fus. One of the inner balsa formers is broke, there's a few cracks on the intake covers and worse of all the side of the fus where the intakes are has been crushed and is creased resulting in cracks in the paint. I'm not happy at all
Is there anyway to reshape fiberglass like warming it up? If not I may as well have chucked 150 in the bin Please help!
Hixxer is offline Find More Posts by Hixxer
Old Jun 14, 2012, 07:24 AM
MrBlobby is offline
Joined Sep 2006
Thanks for the info Dave. 9/16 inch is 14.29mm actually.
When are you going to go metric? Its so much simpler and easier to calculate with.
Old Jun 14, 2012, 08:19 AM
bossmanx5 is offline
Find More Posts by bossmanx5
bossmanx5's Avatar
United States, NY, Patchogue
Joined Oct 2008
Don't bother trying to repair the damaged plane. Instead call their tech dept and send them pictures of the damage. Mine was "modified" by the shipper too. My first set of main wings were broken at the spar, they sent me new ones, second set had the same problem and they finally managed to get a set delivered in 1 piece on try #3. They won't make you ship the fuselage back to them if you email pictures of the damage. It will take longer to get the plane in the air but its worth it in the end...
bossmanx5 is offline Find More Posts by bossmanx5
Old Jun 14, 2012, 08:43 AM
Tin Can Sailor
seadog985's Avatar
Alabama, USA
Joined Feb 2009
That stinks Hixxer. Been there, done that. Hope it works out for you. Got my wing fences on and painted. Now I need to build a nest for the 6S battery.
Old Jun 14, 2012, 11:59 AM
Hixxer is offline
Joined Jan 2012
It does stink, I'm totally gutted. The box and packing were woefully inadequate for overseas shipping. I have been onto RCaerodyne and CMP about replacement parts (even paid for ones) hopefully one of them can sort me out
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Sold Ultrafly T-45 Hawk Pusher NIB mgroves Aircraft - Electric - Jets (FS/W) 0 Sep 15, 2010 03:08 PM
Sold Ultrafly T-45 BAE Hawk Pusher mgroves Aircraft - Electric - Airplanes (FS/W) 0 Sep 15, 2010 03:06 PM
