Old Nov 30, 2011, 09:49 AM
mattyhawk is offline
Find More Posts by mattyhawk
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Oh baby this is a nice model for the price, just got the Nitroplanes deal too, $139 w/ free shipping. It will take me some time to get started on it, but $140 shipped was too good to pass up.
Question about fan choice.
I was thinking about my power system for it. I have settled on the Midi Pro on 10S and 1300kv 3674. I'm guessing this will consume around 70A peak.
Does this sound about right?
Think I might over RPM the fan? I have read they are very robust, but I never used one before.
mattyhawk is offline Find More Posts by mattyhawk
Old Nov 30, 2011, 11:04 AM
T-spin is offline
Find More Posts by T-spin
Joined Mar 2005
Just received my T-45 yesterday unpacked it today. In very good shape slight paint chip on rt intake thats it. The markings on the intakes line up something that was off on the first few rounds . I think CMP and Nitro got it right this time. Will use 8s system and RC Landers retracts. I hope HK get there problems fixed with the BAE Hawk I want one of them too.
Tony
T-spin is offline Find More Posts by T-spin
Old Nov 30, 2011, 11:09 AM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
If it's a true Wemotec MIDI Pro, then you are fine. That is going to be a nice setup. Just keep the weight in check.
Steph280 is offline Find More Posts by Steph280
Old Nov 30, 2011, 11:11 AM
therealhiphop is offline
Find More Posts by therealhiphop
therealhiphop's Avatar
USA, UT, Springville
Joined Dec 2005
Got mine on Monday. Unpacked it and was very impressed. I haven't checked the paint job on the fuse, but everything else looked top-notch.
I've been wanting the HK Hawk, but from what I've read, those that got it are missing parts and have had a few QC problems already. Too bad, because it's a beautiful bird, but given that this is the same airframe, albeit better QC, and considering the HUGE difference in price (taking shipping into account), I am quite happy.
I've ordered a Tacon 90mm 1700KV motor and the CS 12-blade 90mm fan (I have the 70mm 10-blade version and the sound is B-E-A-U-TEEFUL)
Will probably go 6S initially and then 8S.
therealhiphop is offline Find More Posts by therealhiphop
Old Nov 30, 2011, 11:14 AM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Thanks for the confirmation. I am going to use 2 x 4000mah 35c 5S batts, so while it won't be light, it should be manageable.
Old Nov 30, 2011, 11:37 AM
Kaw1000 is online now
Find More Posts by Kaw1000
They call me Crash!
Kaw1000's Avatar
Ohio
Joined Jun 2006
Where are you fellsa getting your ESCs? I'm going to run a 8s set up and need 120 amp esc....everything either sold out or on back order
Kaw1000 is online now Find More Posts by Kaw1000
Old Nov 30, 2011, 11:42 AM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
I can't speak on other esc brands, but you can get the hobbywing 120a hv on eBay and a few places around.
Old Nov 30, 2011, 12:09 PM
They call me Crash!
Kaw1000's Avatar
Ohio
Joined Jun 2006
Thanks..looked everywhere but Ebay...I'll give it a try!
Old Nov 30, 2011, 01:14 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Just got mine, NP has some of the best composite plane deals out there now and this is one of them.
Also was reading through thread and saw cockpit from HK and it's a must have upgrade, going to fly mine on 12s also and try to keep it under 6lbs....
12s 2250mah 65c batts that is, using a hoaye 7 blade rotor, an 810kv inrunner and a castle 45 amp ESC. Should net me around 7lbs of thrust but not pull more than 50 amps WOT, been flying with high C batteries...gotta use a timer when amps are low cause knee is very sharp.
Waiting on corona servos to come in now.
Question, anyone else running theres without intake ducting? If so is it affecting anything, thrust etc?
Thx in advance for any input
erh7771 is offline Find More Posts by erh7771
Old Nov 30, 2011, 01:22 PM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Which corona servos were you thinking of using?
Old Nov 30, 2011, 01:35 PM
erh7771 is offline
Joined Nov 2005
These
http://www.hobbyking.com/hobbyking/s...dproduct=14459
On 6 volts, no stress on them....trying to keep it light easy.
Old Nov 30, 2011, 02:22 PM
Fill'er Up!
mattyhawk's Avatar
Joined Oct 2008
Originally Posted by erh7771 View Post
These
Ah, yes, look like good servos, was actually thinking of using them on rudder and flaps. I'm going with the Turnigy D-MG16 on elevator and aileron.
http://www.hobbyking.com/hobbyking/s...idproduct=6608
Old Nov 30, 2011, 03:31 PM
Mannyman535 is online now
Find More Posts by Mannyman535
edf flyer
Mannyman535's Avatar
United States, CA, Marina
Joined Feb 2009
These
i use those same ones, i just ordered another one after a lock out and all the servos survived
Mannyman535 is online now Find More Posts by Mannyman535
Old Nov 30, 2011, 03:34 PM
edf flyer
Joined Feb 2009
new one on the way
after a brown out, i lost three planes at this alternative field due to brown outs
Old Nov 30, 2011, 03:43 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Manny its not the field!
F18 is getting close, you commin out this weekend? or are you going to Buttonwillow
jcdfrd is offline Find More Posts by jcdfrd
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Sold Ultrafly T-45 Hawk Pusher NIB mgroves Aircraft - Electric - Jets (FS/W) 0 Sep 15, 2010 03:08 PM
Sold Ultrafly T-45 BAE Hawk Pusher mgroves Aircraft - Electric - Airplanes (FS/W) 0 Sep 15, 2010 03:06 PM
