Old Nov 14, 2010, 05:59 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Same size, composite wings, and it's heavier? This plane is loking better by the minute
rvincent is online now Find More Posts by rvincent
Old Nov 14, 2010, 06:05 PM
FL62 is offline
Find More Posts by FL62
Average Joe 2 Semi-Pro n Back!
FL62's Avatar
United States, AZ, Queen Creek
Joined Feb 2004
Just got one of these in front of me.
Close to the same size, although wing and stabs are smaller chord than the JTM.
This has built up wings and stabs, and does not have a full flying stab arrangement.
Not too bad for $200 bucks, although the canopy could be better - that thing is as flimsy as a piece of bare monokote!
Wouldn't trust that ductiing for much more than 2kw... but it will be a sweet 6s setup for cheap!
FL62 is offline Find More Posts by FL62
Old Nov 14, 2010, 08:28 PM
FlyBoyTha1 is offline
Find More Posts by FlyBoyTha1
FlyBoyTha1's Avatar
The Greater Bay Area
Joined Sep 2008
One thing about the "JTM" all the little works done for ya just add servo's and gear edf unit.
FlyBoyTha1 is offline Find More Posts by FlyBoyTha1
Old Nov 14, 2010, 11:32 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
I am at the point of purchasing a power system for this. I realize nobody has flown one yet, but what do you guys think? Debating between ARC 36-75-1 on 8s-3300, or ARC 36-65-1 on 6s-5000. Will be using a MIDIfan. Any suggestions?
Steph280 is offline Find More Posts by Steph280
Old Nov 14, 2010, 11:44 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
marv, looking good! that setup will make for some short flights though. expect 4 min max. that system pulls 85-90A depending on packs.
cant wait to hear how it goes!
should have LOTS of power as that setup makes about 8 lbs of thrust.
Originally Posted by FlyBoyTha1 View Post
Sorry guys, but i just can't stand those cheap plastic wheels and the wire look .
I'll be using A Nue 1415 1.5y and Midi fan 8's ice 100 esc and some Hyperion 45c 3300mAH packs i already have with only 2 flights on them. No need to go to a Nue 15xx size eats up the packs faster from my experience in my bigger jets.
Weight of plane with everything plus packs - minus motor esc & fan 5.2lbs.
Working on the gear door next and making better wheel covers for the mains, more closer to the real T-45's gear doors.
Oh yea for pilots I will be using world models 1/7 scale pilots ordered them yesterday.
corsair nut is offline Find More Posts by corsair nut
Old Nov 15, 2010, 12:44 AM
gal is offline
gal
Find More Posts by gal
gal
Joined Sep 2009
will it be ok for me
will it be good as a first composit edf ? after all its a replica of a triner
i dont know if to bay this model or the sapec t45
gal is offline Find More Posts by gal
Old Nov 15, 2010, 03:56 AM
FlyBoyTha1's Avatar
Joined Sep 2008
Yeah ,
I Think i can get 4 minutes with good throtle mangement, I'm not to hard on the sticks, on the "JTM" Hawk I was only pulling 2600 to 2900mAH out 4200mAH packs. And never hit 3000mAh of usage out all the flights. One reason why i chose the 1415 doesn't kill the batterys like the 15xx series does.
In the video i takeoff at 1 minute into the video and land a little after 5 1/2 minutes .
Rc-Warbirds 90MM "JTM" Full Composite Black Bae Hawk "With SkyCam" (6 min 12 sec)
Old Nov 15, 2010, 11:33 AM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
nice vid and pics of the install ...man you got a lot of water around your field
AIR SALLY is online now Find More Posts by AIR SALLY
Old Nov 15, 2010, 12:32 PM
FlyBoyTha1's Avatar
Joined Sep 2008
That why i really don't fly there much atleast not my big jets if it goes in the salt water it's over
Old Nov 15, 2010, 12:36 PM
FlyBoyTha1's Avatar
Joined Sep 2008
2500 watts at 3/4 throttle
Nitroplanes CMP 90MM T-45 Hawk (1 min 30 sec)
Old Nov 15, 2010, 12:42 PM
balistc1000 is offline
Find More Posts by balistc1000
balistc1000's Avatar
Chandler, AZ
Joined Nov 2008
Sweet! Looks good.
balistc1000 is offline Find More Posts by balistc1000
Old Nov 15, 2010, 12:45 PM
delperena is offline
Find More Posts by delperena
Joined Feb 2006
Old and Inexperienced (O & I)
8
(O & I) - that's me with the CMPro T-45 arriving soon. As you said, this is a "Replica Trainer" - it implies to me that I will need a "Replica Instructor". You bet, someone will fly it for me, until I got "trained".
At a wing loading of 108 to 116 grams/dm^2 (per spec), this plane has to fly fast- The wing is small.
But what the heck, it will be a good "build - experience".
Marv - you are Marv-elous. Thanks. One thought I am considering: Full flying tailerons. Here is why - my first edf plane was a Freewing F-15 64mm EDF. After the vendor replaced the motor and esc, it started to fly until the impeller blades detached from the hub. A floater, it was not difficult to land. After repair, it flew but with a strong tendency to pitch up. I cut the horizontal stab and reduced the incidence angle. If it were a full flying stab, I think incidenc angle adjustment would be an easier fix. Besides, taileron may be configured "balanced" for less load on the servo.
Your thoughts, gentlemen.
Del
delperena is offline Find More Posts by delperena
Old Nov 15, 2010, 12:48 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Wow Marvin that was some serious build up to the maiden
coming soon to a theater near you
looks nice, hope it flies well for you
Ron101 is offline Find More Posts by Ron101
Old Nov 15, 2010, 01:05 PM
FlyBoyTha1's Avatar
Joined Sep 2008
Right on Ron,
I was at Tam's yesterday evening and the ducts are just about done
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Sold Ultrafly T-45 Hawk Pusher NIB mgroves Aircraft - Electric - Jets (FS/W) 0 Sep 15, 2010 03:08 PM
Sold Ultrafly T-45 BAE Hawk Pusher mgroves Aircraft - Electric - Airplanes (FS/W) 0 Sep 15, 2010 03:06 PM
