Old Nov 14, 2010, 09:47 AM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Hey Marv have you fitted the ducts completely? I tried a dry run for fit and the short tube us too small (diameter) and I'm going to have to split it and tape it. The exit tube is perfect. But that short tube would no way no how fit either the fan or the the inlets.
rvincent is online now Find More Posts by rvincent
Old Nov 14, 2010, 09:56 AM
ripping is offline
Find More Posts by ripping
usa
Joined Nov 2008
Originally Posted by FlyBoyTha1 View Post
I did it myself from going to Tam's so often i learn his tricks by seeing everything thats going on in the shop
And i painted the rims white
Al,
I figure the Nue 1415 1.5Y would be a good choice same setup as my "JTM" Hawk, but it's 9lbs and it flys good on that setup on 4200mAH 35c's.
Marvin,
Wow nice, what servo's did you use?
ripping is offline Find More Posts by ripping
Old Nov 14, 2010, 10:25 AM
FlyBoyTha1 is offline
Find More Posts by FlyBoyTha1
FlyBoyTha1's Avatar
The Greater Bay Area
Joined Sep 2008
Mine's is actually too long, but the fan fits perfect. Haven't fitted them completly yet. Just need the motor, calling Tam up today for one
FlyBoyTha1 is offline Find More Posts by FlyBoyTha1
Old Nov 14, 2010, 10:32 AM
FlyBoyTha1's Avatar
Joined Sep 2008
Originally Posted by ripping View Post
Marvin,
Aileron's & Flaps Hitec 125mg's Elevators Hitec HS82mg's.
I started off with the Hitec 225's cause I've had bad luck with HS82's way to many times .
Old Nov 14, 2010, 11:49 AM
ripping is offline
usa
Joined Nov 2008
Thanks I should be getting mine on Thursday, looking forward to your maiden flight.
Old Nov 14, 2010, 11:51 AM
ripping is offline
usa
Joined Nov 2008
Did you use the tam servo mounts?
Old Nov 14, 2010, 12:07 PM
rvincent's Avatar
Joined Jul 2004
Oh I see what you did You put the slotted part INSIDE the inlets rather than over the top of them. I didn't try that.
Old Nov 14, 2010, 12:32 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Doesn`t look like the ducts are fitted well at all. If they are run like that, they will loose a bunch of power due to all of the turbulance. The plane might as well be run with out intake ducts and just use the wemo intake lip on the fan instead, if they aren`t going to be fitted any better than that.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Nov 14, 2010, 12:36 PM
rvincent's Avatar
Joined Jul 2004
That's why I said I would split the short duct and fit over the top of the inlets. The inlets are actually Ok buit the fitting of the short tube from inlets to fan is not great. Easy fix though! I'll post pics as I go. If it doesn't work like I want, Air Sally will make all our dreams come true
FlyBoyTha1's Avatar
Joined Sep 2008
No
Old Nov 14, 2010, 12:39 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Yep, I`m sure someone who has basic modeling skills and knows what they are doing can make them work. Others, not so much I guess.
Old Nov 14, 2010, 12:40 PM
FlyBoyTha1's Avatar
Joined Sep 2008
You got it .
When i install the fan i'll let you know with pictures
These duct are just like the F-4 was nothing should be sealed up until everythings fitted. Then the intakes will be sealed " some talk but don't have the actual plane to see for there self whats going on" if you know what i'm saying
To many know it all's
Old Nov 14, 2010, 01:55 PM
rvincent's Avatar
Joined Jul 2004
Looking forward to it Marvin! I will be ripping on mine staring tomorrow night I expect it will be a VERY fast build. An I'm staring to believe that it will indeed be less than 8lbs
Old Nov 14, 2010, 01:56 PM
rvincent's Avatar
Joined Jul 2004
Hey Marv how is the size of this Hawk to your more expensive one? You said it was 9lbs?
Old Nov 14, 2010, 05:53 PM
FlyBoyTha1's Avatar
Joined Sep 2008
I hate to say it, but the freak'n same size, but composite wings
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Sold Ultrafly T-45 Hawk Pusher NIB mgroves Aircraft - Electric - Jets (FS/W) 0 Sep 15, 2010 03:08 PM
Sold Ultrafly T-45 BAE Hawk Pusher mgroves Aircraft - Electric - Airplanes (FS/W) 0 Sep 15, 2010 03:06 PM
