Old Jul 14, 2003, 05:52 AM
spithungry is offline
Find More Posts by spithungry
no strings attached
spithungry's Avatar
the great white north
Joined Jul 2003
props n power for gws spit
hi all, been reading and reading and reading and learning and learning and learning, all at the EZONE.
i am eagerly awaiting the arrival of my gws spit and have a few
questions, if you don't mind.
the spitfire on the bus right now is the prepainted green model,
i'm not sure if this is the 350 or the 300 motor.
i plan to run this bird on two sony ( 2 cell per pack ) 1350 mah lithium ion batteries. will this be enough juice ? will i need to go
with 3 cells per pack ?
i also have some NiMh batteries that came out of an aerobird.
they are a funny size, fatter than aa's, but about 2/3rds the length. they are 7 cell, 900 mah, 3x3x1 configuration.
i have been flying a pico stick for fun with these 1350 sonys
with flight times of 45 minutes. i noticed that by changing from
the stock 10X47 gws prop to an APC 10X7 prop the performance
was oustanding, and the flight times were actually longer.
my friend and i have been combatting with the sticks and having
an absolute blast. lost mine yesterday after he cut my tail feathers off. pretty spectacular crash ! there is NOTHING left.
i would like to use an APC on the spit, now i'm wondering which one will be the best match. or is the GWS prop pretty good ?
i think the GWS prop that comes with the spit is a 10X7 ??
i am thinking that the same 10X7 apc will be a better performer
but wanted your experience to know before i crash due to under
powering, or cooking an esc, or motor.
i've been admiring the other spits on here, well done everybody !
sounds like this one may be a tuff one to balance ?
i'll be flying 3 channel, no rudder. any advice here ?
thanks in advance, i can't wait !
spithungry is offline Find More Posts by spithungry
Brushlees power for gws beaver MAKO-6 Foamies (Kits) 4 Sep 17, 2005 07:56 PM
EPS 400 power for GWS Corsair? Brownwood Power Systems 2 Jul 28, 2005 05:40 PM
Batts for the GWS Spit Auger Din Parkflyers 0 Aug 19, 2003 08:23 AM
props n power for GWS spit ? spithungry Parkflyers 44 Jul 27, 2003 02:56 PM
Nicad power for GWS Zero Zeroaltitude Foamies (Kits) 8 Oct 06, 2002 04:33 AM
