Old Jul 30, 2011, 06:09 AM
RazielSerafine is offline
Find More Posts by RazielSerafine
Deutschland, Nordrhein-Westfalen, Münster
Joined Jan 2009
Looks great and thx for the alpha Will test it.
RazielSerafine is offline Find More Posts by RazielSerafine
Old Nov 30, 2011, 09:08 AM
Ezekiel Freshmen is offline
Find More Posts by Ezekiel Freshmen
I build unconventional bricks
Ezekiel Freshmen's Avatar
Singapore
Joined Apr 2011
This is undoubtedly the best looking rc app for me !
This is what i dream of, in addition to your app features to make it really valuable for me at the field and in the air. I want an app that displays messages or plays sounds (checklists) during a countdown timer. E.G, playing a sound file that says "start heading back to runway", "drop gears", "flaps down", like some TCAS or alert system on real planes.
I shall be able to set the duration of the timer, slot in sounds at chosen time intervals preferably selectable from own sound files, whichever format possible. And count the time of the flight using the countdown timer too. Its just backwards and if it overshoots just add the extra time to the original.
I can bet this be the first true field rc app when in the air and off in the hanger..
thanks, hope you'll implement it ! cuz I don't write well.
Ezekiel Freshmen is offline Find More Posts by Ezekiel Freshmen
Old Nov 30, 2011, 08:19 PM
rldeveer is offline
Find More Posts by rldeveer
rldeveer's Avatar
Big Island of Hawaii
Joined Jan 2011
Sorry I just don't understand what entries are used in the charged screen:
Voltage: Is this voltage before or after charge?
Charged: ???
Discharged(mAh): ???
Regards, RD
rldeveer is offline Find More Posts by rldeveer
Old Nov 30, 2011, 08:45 PM
Username> is offline
Find More Posts by Username>
Joined Dec 2007
Charged: ???
Regards, RD
I installed it, then uninstalled it within 5 minutes.
Most of it is completely incomprehensible to me, or maybe i'm just thick.
Is it just basically an RC diary for recording notes about accidents, as well as a countdown timer?
Username> is offline Find More Posts by Username>
Reply With Quote  (Disabled)
Old Nov 30, 2011, 08:50 PM
Singapore
Joined Apr 2011
Charged: ???
Regards, RD
That one.. It's the current voltage of the batt. As in right now. this moment.
Charged is the capacity before driving" used to update on max capacity over time. just leave it as max batt capacity,.
Discharged is how much capacity you've used on that flight which minuses from the charged value, if discharge is more than charged, final capacity will be negative.
Old Nov 30, 2011, 10:31 PM
rldeveer is offline
rldeveer's Avatar
Joined Jan 2011
Must have taken a dumb pill today, Still confused!
Lets say I have a 3.7 V batt that is 600mAh 15C (by the way, all C ratings default to 20C and will not update.)
When fully charged it reads 4.18 to 4.22. After a 5 min flight, it reads 3.68 to 3.76. Ater a 1 hour charge back at 4.21 with an input of XXX mAh.
Voltage = ??? Still not sure what V to use.
Charged = 600
Discharged mAh = XXX
RD
Old Nov 30, 2011, 11:26 PM
Singapore
Joined Apr 2011
Charged = 600
RD
first I'll use the average values just for an example.
3.7v 600mah is keyed into the batt type itself. Need only to key in once.
Then after a full charge, press charged button and put in
voltage 4.2v
Charged 600mah
Discharge 0mah
after that 5 min flight,
Voltage 3.7v
Charged 600 mah
Discharge x(amount you've used)
After charging again
voltage 4.2v
Charged 600mah
Discharge 0 zero..
done!
Old Nov 30, 2011, 11:31 PM
rldeveer is offline
rldeveer's Avatar
Joined Jan 2011
Gor it Thanks
RD
Old Nov 30, 2011, 11:50 PM
Singapore
Joined Apr 2011
Gor it Thanks
RD
The truth is, I don't even know if the timer is for the duration of the charging or the flight time. Gosh.. Cuz it works both ways
Old Dec 01, 2011, 01:09 AM
rldeveer is offline
rldeveer's Avatar
Joined Jan 2011
Ya this could really use some clarified instructions.
RD
Old Dec 02, 2011, 08:43 AM
buho29 is offline
Find More Posts by buho29
hi
I will try to better explain :
voltage it is normally when the battery is charged
explanation of charged or discharged:
a charger "modern" has 2 modes: charge and discharge
if you discharge the batteries and then you charge it, we know the total capacity of the battery
but it has to cycle every X is not good for battery life
discharged:
- You have programmed our charger in discharge mode, the number that gives you the charger when the battery is empty,
obviously after the battery must be charged
- If not used the program discharge the number is 0.
charged: this is the number that gives you the charger when the battery is full (with or without the use of discharge).
if have seen the chart "Charged", the blue line is the total capacity of the battery (it is numbers fictitious)
voltage en principe c'est quand la batterie est chargé
explication de charger ou décharger:
un chargeur "moderne" contient 2 mode : charge et décharger
si vous déchargé la batterie et ensuite vous là charger, nous savons la capacité totale de la batterie
mais c'est a faire chaque X cycle ,c'est pas bon pour la vie de la batterie
déchargé :
- il faut programmé notre chargeur en mode décharge , c'est le chiffre qui vous donne le chargeur quand la batterie est vide ,
après evidemment il faut chargé la batterie
- si on pas utilisé le programme décharge le chiffre est 0.
chargé :c'est le chiffre qui vous donne le chargeur quand la batterie est pleine (avec ou sans utilisation de décharge).
si ont observe la chart "Charged" , la ligne bleu c'est la capacité total de la batterie (c'est des chiffres fictive)
voltage normalmente es cuando la batería está cargada
explicación de la carga o descarga:
un cargador de "moderno" tiene 2 modos: carga y descarga
si descarga de la batería y luego lo carga, sabemos la capacidad total de la batería
pero se tendria que hacer cada X ciclos no es bueno para la vida de la batería
discharged:
- Se ha programado nuestro cargador en modo de descarga, es el número que te da el cargador cuando la batería está vacía,
obviamente después la batería debe ser cargada
- Si no se utiliza la descarga el número es 0.
charged: este es el número que te da el cargador cuando la batería está llena (con o sin el uso de la descarga).
si han visto el grafico de "cargados", la línea azul es la capacidad total de la batería (es un número ficticio)
tip: when there are no models, the app offers the possibility to load the demo
buho29 is offline Find More Posts by buho29
Old Dec 02, 2011, 09:19 AM
buho29 is offline
RD
thank you for the bug returns
I received by email, two other bugs
- "Bar code scanner" that planted the app (I guess the API has changed)
- It takes at least insert one chrono in order to insert a charge
This weekend I will look at all the bugs
I notice that now the RC is in pause so I not use my app
and now I'm on another project that takes all my free time
Old Dec 07, 2011, 02:27 PM
buho29 is offline
updated, if you find a bug do not hesitate to tell me
enjoy
Old Dec 07, 2011, 03:42 PM
stefan.sch is offline
Find More Posts by stefan.sch
Österreich, Vbg., Feldkirch
Joined Dec 2011
Nice work ..
And sorry to hear that you stoped RC ...
best regards,
Stefan
PS: If I had known that there is something like that out there. Maybe I would not have made: RC Lipo and Flight log. but it was fun and follows a diffrent concept.
stefan.sch is offline Find More Posts by stefan.sch
Discussion New doppler speedometer application for windows and android! neonbjb Foamy EDFs 54 Nov 07, 2014 06:09 AM
Discussion Any RC heli/planes simulator for Android? Tom_1971 Simulators 5 Dec 01, 2011 04:33 PM
New Product F3 Timer for Android phones vitas Hand Launch 28 Oct 25, 2010 05:31 PM
New Product F3J timer for android vitas Multi Task F3X 5 Jan 29, 2010 03:51 PM
