Old Nov 15, 2010, 10:51 AM
buho29 is offline
Find More Posts by buho29
Originally Posted by RNAF View Post
I'd need to see it in the application to provide a real proper translation.
For example: "Drive" is that not "Flight"? If so change "Rit" to "Vlucht".
If I can be of further help regarding this I'd love to help you out.
sorry I forgot to answer you
yes drive is flight, but I guess it can also be of interest to car ... I use "flight"?
thank you for the translation, I include it in the next version
buho29 is offline Find More Posts by buho29
Old Nov 16, 2010, 06:12 AM
blackmoon is online now
Find More Posts by blackmoon
flying beam
blackmoon's Avatar
through the Looking Glass
Joined Apr 2008
I would use "Run", since it could be used for Cars, planes, helicopters, boats...
By the way, just installed the latest version from the market (and also the latest version for Barcode Scanner), all is going well.
Barcode generation : OK
Barcode Reading: OK
And thanks for the language change in the preferences menu, nice touch.
This is going to be a nice and useful app
Thank you Buho for taking the time (I know you are very busy) to implement all the changes.
I'll try to translate to Portuguese, this weekend.
blackmoon is online now Find More Posts by blackmoon
Old Nov 16, 2010, 04:24 PM
RazielSerafine is offline
Find More Posts by RazielSerafine
Deutschland, Nordrhein-Westfalen, Münster
Joined Jan 2009
So, after adding all of my micros I got a little question. You have the option to enter a description when creating a model. Where can you look up this description afterwards?
Then another point, would it be possible to make the model selection different? Would prefer scrolling up an down instead of left and right AND would love to change the order of the models.
RazielSerafine is offline Find More Posts by RazielSerafine
Old Nov 20, 2010, 09:48 PM
buho29 is offline
Barcode Reading: OK
I'm glad it is finally working
- when edit the model have can see the description?? . (Now have can see in "view model" screen
- the widget "gallery" not support vertical scrolling , or I lock paisage orientation, or I use the widget" listview" the render is different ...
- to change the order of the model is necessary that I add a column to the database and make another "activity" to change the order
the problem is that my other project is my priority, I would but I do not know when
update:
- added Dutch (Nederlands) (thanks RNAF)
- added ListView in portrait orientation
- fix bug in editing model (erase current image)
Old Nov 23, 2010, 05:22 AM
Joined Jan 2009
Thanks for the update Lovin' it
Old Jan 15, 2011, 01:52 AM
GeorgesH is offline
Find More Posts by GeorgesH
Joined Jan 2011
Bonjour et merci pour cette tres belle application.
Je voudrais savoir s'il y a un moyen que l'ecran de mon HTC Desire reste alume pendant que je me sert de RC Mananger ?
Je ne trouve pas une fonction dans le setup pour y arriver.
Merci pour votre aide
GeorgesH is offline Find More Posts by GeorgesH
Old Apr 30, 2011, 05:40 PM
fatalsync is offline
Find More Posts by fatalsync
The New Guy
fatalsync's Avatar
USA, TX, College Station
Joined Oct 2010
Just found this gem today. Awesome application. Nice touch with the QR codes for the batteries!
fatalsync is offline Find More Posts by fatalsync
Old May 18, 2011, 04:10 AM
Hyvok is offline
Find More Posts by Hyvok
Joined May 2010
This looks like an AWESOME app EXCEPT it doesn't have ability to mark "charged mAh" to the batteries which makes it almost useless... Way more important to know how much you charged the battery for than how long you flew it for (I wouldn't even want to keep track of that, rather the charged mAh). Developer please add support for this!
QR code generation was a bit weird, because you couldn't generate it when creating the battery (menu option is inactive), you had to create the battery and then go edit the battery (took me a while to figure out how to edit the battery, you need to "hold" the battery in the menu for a couple of seconds for the menu).
Hyvok is offline Find More Posts by Hyvok
Old Jul 04, 2011, 10:10 PM
buho29 is offline
Hi Sorry for the delay
In my defense, I would say that my charger says only if it is loaded (I just received an Imax B6AC)
indeed the "QR code generation" is not easy to find ... I have to relocate
if I become absent and someone wants to retake, I released the source code: http://rcmanager.googlecode.com (which I will update)
I'm currently thinking about how to take advantage of these types of chargers
if you discharge and then charge the battery we know the total capacity of the battery
but as this is not recommended, just do so occasionally or when there is suspicion?, but there could make a chart and should see the degradation
similar a this :
next match this interface / designer (really awful)
Old Jul 05, 2011, 09:50 AM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
Thanks for the aPP! I was dying for one!
Park_aviator is offline Find More Posts by Park_aviator
Old Jul 16, 2011, 06:05 AM
buho29 is offline
I had completely forgotten that it is the horrible UI of android
and skinned it's a nightmare, it is necesaire put his nose in the source code of android
I had to do a lot of image, icon, and xml configuracion, ect ...
I hope that is visually aceptable (I need three days to choose one color )
first run:
Old Jul 24, 2011, 11:39 AM
buho29 is offline
hi
news :
- now use the achartengine http://code.google.com/p/achartengine/ for drawing chart
- added new table 'charge' in database
- added new colonne 'constant_discharge' in table 'powerItem'
diagram the database
the achartengine provide multouch-zom, drag and inteactive action
is possible overlap chart with differente value but the chart is filled in 100%
(dashed line is mAh)
(note: the values is fictitious)
the screen flow after scanning QR code in one batery
choice between charge or drive
click in button chrono :
if the battery is used by many models
(otherwise directly on the screen "chrono")
click in button charge (the form is filled with the last recorded value):
the entry value 'discharged' is to create the checkpoint to measure the actual capacity (see the table 'charged' (capacity series)), this value is given for our battery charger with discharge program
note: when used the 'discharge' value, the entry 'charge' is the actual capacity of the battery
charge saved and result :
Old Jul 29, 2011, 03:12 AM
buho29 is offline
added charts in model
Old Jul 29, 2011, 03:55 AM
deeh_46 is offline
Find More Posts by deeh_46
deeh_46's Avatar
Joined Sep 2006
Hi,
Thanks for the app, like it!!
How do I update for the newest? I didn't see your app update in 'my apps'
deeh_46 is offline Find More Posts by deeh_46
Old Jul 29, 2011, 08:35 AM
buho29 is offline
Originally Posted by deeh_46 View Post
Hi,
Before updating, I have to thoroughly test, to avoid bugs (at least the big )
http://buho29.net/img/android/rcmana...ager_alpha.apk
Discussion New doppler speedometer application for windows and android! neonbjb Foamy EDFs 54 Nov 07, 2014 05:09 AM
Discussion Any RC heli/planes simulator for Android? Tom_1971 Simulators 5 Dec 01, 2011 03:33 PM
New Product F3 Timer for Android phones vitas Hand Launch 28 Oct 25, 2010 04:31 PM
New Product F3J timer for android vitas Multi Task F3X 5 Jan 29, 2010 02:51 PM
