Old Nov 10, 2010, 04:30 AM
buho29 is offline
Find More Posts by buho29
rcmanager in android
hi
I do not know really where to post this :?
RCmanager was a project I did a year ago to take control of my lipos, I programmed in another project and I also releasing this project
manage models Radio control and battery life
a battery can be assigned to multiple models
you can register the broken pieces (with autocompletion)
statistics of the model and battery
2 types of alarms
- a battery alarm linked to model <-> lipo
- another that can have stacked alarm (2 type) on a model
gère ces modèle de Radio Contrôle et la vie des batterie
ont peux assigné une batterie a plusieurs modèle
ont peux enregistré des pièce cassé (avec autocompletion)
statistique du modèle et de la lipo
2 type de alarme
- batterie sur une liaison modèle<->lipo
- ont peux empilé des alarme(2 type) sur un modèle
gestione sus modelos de Radio control y la vida de las baterías
asigne una batería a varios modelos
registre las piezas rotas (con autocompletion)
estadísticas de el modelo y de la batería
2 tipos de alarmas
- una alarma enlazada a modelo<->lipo
market://search?q=pname:com.buho29.rcmanager
buho29 is offline Find More Posts by buho29
Old Nov 10, 2010, 07:15 AM
blackmoon is offline
Find More Posts by blackmoon
flying beam
blackmoon's Avatar
through the Looking Glass
Joined Apr 2008
Salut Bubule
Content de te revoir parmis nous
Long time no see...
Life is strange sometimes...
I just bought an android smartphone, and was thinking "it would be nice if I had Buho's software for batteries control and more...", was about to PM you on helimag.
And voilà you're here...
Like I said life is strange...
Thanks mate.
Paulo.
blackmoon is offline Find More Posts by blackmoon
Old Nov 10, 2010, 07:20 AM
RazielSerafine is offline
Find More Posts by RazielSerafine
Deutschland, Nordrhein-Westfalen, Münster
Joined Jan 2009
Looks nice, just installed it, will try it out over the next days
RazielSerafine is offline Find More Posts by RazielSerafine
Old Nov 10, 2010, 11:16 AM
buho29 is offline
Originally Posted by blackmoon View Post
Salut Bubule
Long time no see...
Thanks mate.
Paulo.
oui je me suis légèrement déconnecté , toujours un plaisir de te parlé
content que tu soit androide xD
tanks
if you found a bug and/or spelling, do not hesitate ...
rcmanager is available in 3 languages (en/es/fr) if there are others interested, I publish the xml
Old Nov 10, 2010, 11:53 AM
Joined Jan 2009
tanks
Would be interested in german.
Old Nov 10, 2010, 03:31 PM
buho29 is offline
ok , this is the xml to be translated
Code:
<?xml version="1.0" encoding="utf-8"?>
<resources>
	<string name="app_name">RCManager</string>
	<string name="emptyMessage">Create a new! (menu)</string>
	<!-- general -->
	<string name="name">Name</string>
	<string name="description">Description</string>
	<string name="date">Date</string>
	<string name="saved">Saved</string>
	<string name="New">New</string>
	<string name="delete">Delete</string>
	<string name="edit">Edit</string>
	<string name="created">Created</string>
	<string name="cancel">Cancel</string>
	<string name="ok">Ok</string>
	<string name="save">Save</string>
	<string name="update">Update</string>
	<string name="d">Days</string>
	<string name="h">Hours</string>
	<string name="m">Minutes</string>
	<string name="s">Seconds</string>
	<!-- edit main-->
	<string name="emptyModel">Model not found</string>
	<string name="emptyModelMessage">you want to do ?</string>
	<string name="loadDemo">Load Demo</string>
	<!-- edit model-->
	<string name="power_type">Type</string>
	<string-array name="power_type_ar">
        <item>Electric</item>
        <item>Thermic</item>
    </string-array>
    <!-- modelView -->
	<string name="power">Power</string>
	<!-- edit powerView-->
	<string name="deletePower">Delete from this model</string>
	<string name="deletePowerItem">Delete permanently</string>
	<string name="all">ALL</string>
	<string name="find">Find</string>
	<!-- edit chronoview-->
	<string name="addManual">Insert chrono</string>
	<string name="start">Start</string>
	<string name="pause">Pause</string>
	<string name="reset">Reset</string>
	<string name="notification_chrono">Alarm time elapsed </string>
	<string name="help_cero_seconds">No saved fly (time is 0)</string>
	<string name="accident">Accident</string>
	<string name="addAccident">Add accident ?</string>
	<string name="delete_last_drive">Delete last drive</string>
	<string name="remenber">Remember ?</string>
	<!-- edit damageview-->
	<string name="cause">cause</string>
	<string name="price">price</string>
	<string name="newDamage">New damage</string>
	<string name="editDamage">Edit damage</string>
	<string name="n">n°</string>
	<string name="damage">Damage</string>
	<string-array name="damage_type_ar">
        <item>Usury</item>
        <item>Accident</item>
    </string-array>
    <!-- edit alarmview-->
	<string name="help_alarm_1">Display the alarm if drived x hours</string>
	<string name="help_alarm_2">Display the alarm if days is elapsed</string>
	<string name="alarm">Alarm</string>
	<string name="newAlarm">New alarm</string>
	<string name="editAlarm">Edit alarm</string>
	<string name="timeLeft">Time left</string>
	<string name="note">Note</string>
	<string name="type">Type</string>
	<string-array name="alarm_type_ar">
        <item>Time used</item>
        <item>Date elapsed</item>
    </string-array>
	<!-- statistic -->
	<string name="models">Models</string>
	<string name="average">Average</string>
	<string name="total">Total</string>
	<string name="drive">Drive</string>
	<string name="min">Min</string>
	<string name="max">Max</string>
	<string name="time">Time</string>
	<string name="helpEmptyFly">&quot;you didn't drive!&quot;</string>
	<!-- main <string name=""></string>-->
	<string name="statistic">Statistic</string>
	<string name="preference">Preference</string>
	<string name="view">View</string>
	<!-- preference -->
	<string name="title_ringtone">Select Ringtone</string>
	<string name="title_sound_enabled">Enable sound</string>
	<string name="summary_sound_enabled">Activated the sound for notification</string>
	<string name="title_vibrator_enabled">Enable vibrator</string>
	<string name="summary_vibrator_enabled">Activated vibrator for notification</string>
	<string name="title_vibrator_dia_text">ex: 0 100 500 200 200 </string>
	<string name="summary_vibrator_text">Times to turn the vibrator off/on in msg</string>
	<string name="title_vibrator_text">Pattern</string>
</resources>
<string name="not_touch">german tranlation</string>
Old Nov 10, 2010, 08:34 PM
Ceros007 is offline
Find More Posts by Ceros007
Ceros007's Avatar
Montreal, Québec, Canada
Joined Apr 2010
Awww j'echangerais mon iPhone contre un Android n'importe quand!
Ceros007 is offline Find More Posts by Ceros007
Old Nov 11, 2010, 12:43 AM
Joined Jan 2009
Here we go, german translation, hopefully correct. Didn't understand the meaning of usury in the accident part. Changed it to "testrun" and the other option to "crash"
Code:
<resources>
	<string name="emptyMessage">Neu erstellen (Menü)</string>
	<!-- general -->
	<string name="description">Beschreibung</string>
	<string name="date">Datum</string>
	<string name="saved">Gespeichert</string>
	<string name="New">Neu</string>
	<string name="delete">Löschen</string>
	<string name="edit">Bearbeiten</string>
	<string name="created">Erstellt</string>
	<string name="cancel">Abbrechen</string>
	<string name="ok">OK</string>
	<string name="save">Speichern</string>
	<string name="update">Aktualisieren</string>
	<string name="d">Tage</string>
	<string name="h">Stunden</string>
	<string name="m">Minuten</string>
	<string name="s">Sekunden</string>
	<!-- edit main-->
	<string name="emptyModel">Modell nicht gefunden</string>
	<string name="emptyModelMessage">Was soll gemacht werden?</string>
	<string name="loadDemo">Demo Laden</string>
	<!-- edit model-->
	<string name="power_type">Antrieb</string>
        <item>Elektrisch</item>
        <item>Thermisch</item>
    </string-array>
    <!-- modelView -->
	<string name="power">Akku</string>
	<string name="deletePower">Aus diesem Modell entfernen</string>
	<string name="deletePowerItem">löschen</string>
	<string name="all">Alle</string>
	<string name="find">Suchen</string>
	<string name="addManual">Zeit eingeben</string>
	<string name="reset">Zurücksetzen</string>
	<string name="notification_chrono">Alarmzeit abgelaufen</string>
	<string name="help_cero_seconds">kein gespeicherter Flug (Zeit ist 0)</string>
	<string name="accident">Schaden</string>
	<string name="addAccident">Schaden hinzufügen?</string>
	<string name="delete_last_drive">Letzte Nutzung löschen</string>
	<string name="remenber">Merken?</string>
	<string name="cause">Ursache</string>
	<string name="price">Preis</string>
	<string name="newDamage">Neuer Schaden</string>
	<string name="editDamage">Schaden bearbeiten</string>
	<string name="n">Anzahl</string>
	<string name="damage">Schaden</string>
        <item>Übung</item>
        <item>Absturz</item>
    </string-array>
	<string name="help_alarm_1">Alarm anzeigen wenn x Std gelaufen</string>
	<string name="help_alarm_2">Alarm nach Ablauf von Tagen anzeigen</string>
	<string name="newAlarm">Neuer Alarm</string>
	<string name="editAlarm">Alarm bearbeiten</string>
	<string name="timeLeft">Zeit verbleibend</string>
	<string name="note">Notiz</string>
	<string name="type">Art</string>
        <item>Zeit in Gebrauch</item>
        <item>Zeit vergangen</item>
    </string-array>
	<!-- statistic -->
	<string name="models">Modelle</string>
	<string name="average">Durchschnitt</string>
	<string name="drive">Nutzung</string>
	<string name="time">Zeit</string>
	<string name="helpEmptyFly">&quot;Wurde nicht genutzt!&quot;</string>
	<string name="statistic">Statistik</string>
	<string name="preference">Einstellungen</string>
	<string name="view">Anzeigen</string>
	<!-- preference -->
	<string name="title_ringtone">Alarmton wählen</string>
	<string name="title_sound_enabled">Ton einstellen</string>
	<string name="summary_sound_enabled">Ton für Alarm gewählt</string>
	<string name="title_vibrator_enabled">Vibration einstellen</string>
	<string name="summary_vibrator_enabled">Vibration für Alarm gewählt</string>
	<string name="summary_vibrator_text">Ein/Ausschaltzeit für die Vibration</string>
	<string name="title_vibrator_text">Muster</string>
</resources>
Could you provide the apk as I would like to check the translation before putting it into the market.
Love the app so far, didn't find any bugs yet and it saves a lot of paper to me
Old Nov 11, 2010, 01:48 AM
guy1a is offline
Find More Posts by guy1a
FPV! and nothing else matters.
guy1a's Avatar
Israel, Haifa
Joined Aug 2010
XML translation to Hebrew ... if any one needs it.
b.t.w. - i own iPhone, will you make a version for that too ?
guy1a is offline Find More Posts by guy1a
Old Nov 11, 2010, 05:50 PM
buho29 is offline
"usury" seems to be only used in a financial context, I was referring to mechanical wear (use wear?)
replace "accident" to "crash" no?
http://buho29.net/img/android/rcmana...Manager_de.apk
p.s: my English is really bad, sorry
thanks for the translation into Hebrew
the problem I'm not sure the Android support the Hebrew (not mine), I looked at the source and not find Hebrew
documentation if it appears that refers to, but as I'm not sure of anything ... unless someone has a Hebrew Android
no sorry, no iPhone version
Old Nov 12, 2010, 04:39 AM
Joined Jan 2009
Wear is fine, makes much more sense to me Would be "Abnutzung" in German, if you would be so kind to change it.
Absturz can be changed to Crash in German too, every Pilot will understand
Your english isn't worse than mine Tanks for the apk, will take a look right now.
Old Nov 12, 2010, 05:33 AM
Joined Jan 2009
Okay, tested.
<item>Übung</item>
</string-array>
Change "Übung" to "Verschleiß" and "Absturz" to "Crash"
Rest is fine and ready for release
Great work, great app
If you need a german translation for the description in the market, contact me
Old Nov 12, 2010, 05:53 AM
wuselfuzz is offline
Find More Posts by wuselfuzz
Joined Feb 2010
Neat, I have to try this later, forgot my phone at home.
Here's an idea/feature request: It's pretty simple to use zxing from your own application to scan barcodes. It would be cool if you could print QR or barcodes for all your helis and lipos, then just scan the code on the heli and battery pack when you fly a pack and scan the code on your charger and the lipo if you charge a pack. BEEEEP.
wuselfuzz is offline Find More Posts by wuselfuzz
Old Nov 12, 2010, 12:07 PM
flying beam
blackmoon's Avatar
Joined Apr 2008
Woow this is a nice feature, bye bye pack numbers and errors, very well thought.
Old Nov 12, 2010, 04:09 PM
buho29 is offline
Okay, tested.
<item>Übung</item>
</string-array>
thanks
updated in market
in Android is possible to start application with a queryString (mailto,tel,http)
For example, this link opens one aplication I programmed
buho29://pepe/param/pito edit:he not opened (only work in app (link in textfield))
but "Barcode Scanner" of this link does a search on google instead of resolving to do in Android (it's easy implementation)
I'm going to study because it is interesting
c'est ça ... donne moi du travaille petit enfo...
Discussion New doppler speedometer application for windows and android! neonbjb Foamy EDFs 54 Nov 07, 2014 05:09 AM
Discussion Any RC heli/planes simulator for Android? Tom_1971 Simulators 5 Dec 01, 2011 03:33 PM
New Product F3 Timer for Android phones vitas Hand Launch 28 Oct 25, 2010 04:31 PM
New Product F3J timer for android vitas Multi Task F3X 5 Jan 29, 2010 02:51 PM
