Old Nov 12, 2010, 11:16 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Istand:i agree with what you did ...thats how mine is ..but also a "inner bushing " is another bushing mounted in the fuse Common to the exhuast area .the stab wire will poke into the fuse ...use a plastic wheel bushing or a small square of 1/8 ply with a hole drilled in the center the same size as the stab wire . now the stab is supported in the fuse and the tail plylon....it wont twist the plylon off now as it is supported in two places ...there are pics of mine somewhere in the begining of the mod thread ....like 3 yrs ago ...at least
AIR SALLY is online now Find More Posts by AIR SALLY
Old Nov 13, 2010, 03:09 AM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Not quite that old Rodger, but a wise man (or...was that a BIG man) once told me, "no one ever remembers 2nd place"
Here's a reminder.
We always have a Phase 3 -16 or two in the hangar
173 mph Phase 3, F 16 (0 min 44 sec)
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Nov 13, 2010, 09:19 AM
Tinkasochi is offline
Find More Posts by Tinkasochi
Can anybody see it?
Tinkasochi's Avatar
Baker , FL
Joined Dec 2009
I have had a squall and 3 F-16's and the F-16 is definetly faster with the same power system, but, the squall will crawl slower than the F-16 without stalling and makes for some really cool and fun high alfa flying. To each their own.
Oh, and I missed the whole rediculous priced plane deal but it was so much fun reading about it today!!!
Tinkasochi is offline Find More Posts by Tinkasochi
Old Nov 13, 2010, 09:37 AM
T-CAT is offline
Find More Posts by T-CAT
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Originally Posted by istandalone View Post
hmm, i suck at explaining things but here goes.
in the tail pylons, where the existing brass bushings are, you need to make some sort of beefier bushing to go around the existing brass one.
what i do is, remove the stock bushings (it'll come out easy, they're not glued in very well) and make a little cavity where it was.
take a strip of 1mmish cf sheet (i'm sure light ply would work too, or even lexan) cut it to about 1cm x 10cm rectangle. drill a hole in one end the same size as the OD of the stock brass bushing. carve out a channel in the tail pylon that fits this cf strip.
use 30 min epoxy to glue the cf strip into the tail pylon, making sure to put the brass bushing through it. put a little extra epoxy over the bushing (use the same batch epoxy as you did for the cf strip, you want to do this all at the same time) and spin it/turn it in place. this will pull and distribute the epoxy all around the brass bushing. while the epoxy is curing, insert a rod of some sort through both brass bushings. this will keep them true while the glue does it's job.
doing this, along with boxing in the tail and upgrading the linkages you can run as much power as you want and be ok. glass might be overkill, but i love the finish it provides. i use 1oz fg cloth and zpoxy finishing resin and after the final coat of resin, it looks almost like a gel coat job. very tight.
using this method, i've NEVER had my tail fail. my last ef16 had an arc 1t/6904 on 4s and it was damn quick. i hit a tree going around 100 and just about nothing survived....save for the tail and rear of the fuse lol.
Thanks a lot for your help guys. I'll definitely do all that was suggested when I get one of these jets. The procedure doesn't sound to hard to do. Some of the F16's people have build here are monsterous. It's gone in a blink of an eye, lol. If someone has a crazy powered one and lives in California, please PM so o can see that thing fly in person!
T-CAT is offline Find More Posts by T-CAT
Old Nov 13, 2010, 05:26 PM
SKYRYDER1000 is offline
Find More Posts by SKYRYDER1000
SKYRYDER1000's Avatar
NEW JERSEY U.S.A.
Joined Mar 2010
Hey guys just got in from my first 10 flights with my new F-16 and all I can say is WOW!!! What a fantastic flying aircraft. I had such a great time with it. I used the stock 55mm fan with a Don's 5400kv motor, Turnigy 40amp esc with bec and Turnigy 2200mah 3s 20c lipos. This gave me three minute flight times with alot of WOT. I think I am going to try to fly with 4s if I can get it to ballance. Do any of you guys fly this jet with both 3s and 4s? Another question I have is I have some excess thrust tube maybe about 2'' or so coming out of the thrust cone. If I cut this off to make it look a little better will this effect anything?
SKYRYDER1000 is offline Find More Posts by SKYRYDER1000
Old Nov 13, 2010, 09:13 PM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
If you decrease the diameter of the thrust tube on the exhaust of the jet it forces the same air to move at a higher velocity. If you cut some off the excess thrust tube off I imagine that you will increase the diameter of the thrust tube exit and will reduce the velocity of the air and reduce the top speed of your jet.
Of course there is an optimal setting for this based on many factors that I don't understand so I can't say for sure if your top speed will be affected. I guess it would reduce the load on your motor/battery and slow you down a little but someone that knows more than I will probably chime in.
Craig
cmala is offline Find More Posts by cmala
Old Nov 14, 2010, 04:14 AM
RC Accessory is offline
Find More Posts by RC Accessory
United States, FL, Tampa
Joined Jan 2004
also, i need some opinions here. i'm in the market for a new lipo charger, and i'd like this to be my last charger i ever buy (barring something breaking on the new one in a few years).
i need it to charge up to 6s lipo, lead acid 12v (nixx not important) and charge up to 10a. also it needs to be able to discharge a 4s lipo at a rate greater then .4a (like the bantam bc6 i use now....great charger but the discharger sucks balls).
does anyone make a charger that also has an on board watt meter? i need one of those too, but the ones i see for sale only go up to 100a...which is fine but in rare cases i have pwr systems that draw 120a +.
The TME Extrema XG has a built in 100 amp watt meter.
http://www.tmenet.com/products/lithi...xtrema-charger
If you need more than 100 Amps, get the Eagletree 150 amp model.
RC Accessory is offline Find More Posts by RC Accessory
Site Sponsor
Old Nov 14, 2010, 08:20 AM
Can anybody see it?
Tinkasochi's Avatar
Baker , FL
Joined Dec 2009
If you cut it off, you'll increase the low end thrust but decrease the high end velocity. In other words you'll have more power at launch and less top end. Not much difference with the stock fan but noticable. In my opinion, I'd rather loose a couple mph and make it look better.
Old Nov 14, 2010, 09:45 PM
G-Forse is offline
Find More Posts by G-Forse
Denver, CO
Joined Nov 2007
--Just flew JS1400 6904 on 5s 3200. It seems faster but the biggest thing that I noticed was how sensitive the elevator was at speed. The JS pulls about 48,000 rpm on 4s 3600 and another 9,000 rpm at 57,000 rpm on 5s. Amps on 5s were about 112 per Fluke clamp meter. It pulls about 92 amps on 4s. ----The ARC 1T pulls about 115 amps 51,000 rpm on 4s and 135 amps 60,000+ rpm on 5s. The rotor likes the JS better and is still in one piece. Gonna put the replacement ARC back in it though. It is a couple ounces lighter. --I'll doppler maybe later this week. Cool air keeps the motors cool but have to keep the batteries in the truck.
G-Forse is offline Find More Posts by G-Forse
Old Nov 15, 2010, 06:02 PM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
in my stock f16, if I used a 1800mah 3cell 30C battery, vs a 2200mah 3cell 30C, will I really notice any difference? the 1800 will push 54 amps, which is still more then the esc will put out to the motor, so going even higher to the 2200mah, I dont see any benefit, do you?
nickelbn1 is offline Find More Posts by nickelbn1
Old Nov 15, 2010, 06:07 PM
jmrust is offline
Find More Posts by jmrust
Once-ler
United States, FL, Gainesville
Joined Jul 2008
forgot about you thin, COLD air dudes
jmrust is offline Find More Posts by jmrust
Old Nov 15, 2010, 06:15 PM
jmrust is offline
Once-ler
Joined Jul 2008
check you watt output...what's the weight difference...20 grams or so?
Old Nov 15, 2010, 07:23 PM
blueapplepaste is offline
Find More Posts by blueapplepaste
blueapplepaste's Avatar
United States, TX, Keller
Joined Jul 2009
I just picked up one of these for my first EDF. Mine came with a 5-blade 70mm fan - I think from the Squall. I know this is designed for 3S, but will the motor handle 4S?
Also, I want to make the center section of my belly pan removable so I can get to the Fan/ESC. I know some have cut up their belly pan and glued the front and rear sections in place. Does anyone have pics of this?
I'd like to see how big (or small) of a center section people made removable and what and how they hold the base in place. Thanks in advance!
blueapplepaste is offline Find More Posts by blueapplepaste
Old Nov 15, 2010, 07:32 PM
Can anybody see it?
Tinkasochi's Avatar
Baker , FL
Joined Dec 2009
My center section is removable.........with a hobby knife, two razor blades, a coping saw, a hacksaw blade, a butane torch with rope melting attachment, two different flat head screwdrivers, some sort of putty knife thing, a red hot coat hangar, elbow grease, and a bottle of goo gone.
Old Nov 15, 2010, 07:43 PM
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
I am a simple flyer, I dont have a watt meter, sorry.
Help! Phase 3 Hobbypeople F16- build tips? Smokescreen38 Foamy EDFs 101 Jun 07, 2016 09:53 PM
Discussion Phase 3 - Hobbypeople F16 UPGRADES (cont.) Flying Beagle Foamy EDFs 13 Nov 10, 2010 02:54 AM
Discussion Phase 3 - Hobbypeople F16 UPGRADES ducatirdr Foamy EDFs 11482 Nov 09, 2010 10:05 PM
Wanted Phase 3 F16 body dmize Aircraft - Electric - Jets (FS/W) 0 Oct 01, 2010 10:36 PM
Sold Phase 3 f16 arf NorCal Hobbies Aircraft - Electric - Jets (FS/W) 1 Sep 02, 2010 07:30 PM
