Old Jan 06, 2011, 11:31 AM
tim.fuggdesign is offline
Find More Posts by tim.fuggdesign
tim.fuggdesign's Avatar
Bristol UK
Joined Aug 2010
Originally Posted by T-CAT View Post
How is a thrust tube installed? This will be my first time using one that was created for me. I know it can be taped to the fan housing, but I'm confused on house the rest of the tube layes in the fuselage. Since the tube is smaller in diameter than the fuselage, how is secured in there without flopping around and making the jet act like it has thrust vectoring?
Mine is just taped to the fan unit, the exit diameter is exactly the same size as the exit diameter of the fuse, so the just sit the fan in and the thrust tube is held straight by the fuse as it has no room to move, I'll take a pic later to show you.
I did take mine apart and re tape it as the join wasn't quite straight out of the box but I just overlapped the plastic up to the edge of the double sided tape.
tim.fuggdesign is offline Find More Posts by tim.fuggdesign
Old Jan 06, 2011, 11:33 AM
jmrust is offline
Find More Posts by jmrust
Once-ler
United States, FL, Gainesville
Joined Jul 2008
you shouldn't have a problem with the thrust tube if it's securely taped all the way around the fan and goes to the edge of the black fake exhaust tube. The fan and tt will lay against the top half of the fuse.
jmrust is offline Find More Posts by jmrust
Old Jan 06, 2011, 11:55 AM
T-CAT is offline
Find More Posts by T-CAT
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Thanks guys, I really appreciate the help. I possible, Tim, I would love to see pictures on how the tube lays in the exhaust.
Has anyone used a thrust tube mite sturdy than say the typical plastic clear projector sheets? For example, I would imagine a foam cup, or soda cup would work since it tapers at the end. Does anyone have experience with that?
T-CAT is offline Find More Posts by T-CAT
Old Jan 06, 2011, 01:01 PM
T-CAT is offline
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Also, how does the tube stayed secure in the fuselage if the thrust tube exit diameter is much smaller than the fuselage exit diameter?
Old Jan 06, 2011, 01:07 PM
jmrust is offline
Once-ler
Joined Jul 2008
It will stay in place because it's taped to the shroud and that in turn is affixed to the fuse.
Old Jan 06, 2011, 01:25 PM
T-CAT is offline
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Gotcha. Thanks jm. I'm going to have to try this out for the first time.
Old Jan 06, 2011, 07:41 PM
SKYRYDER1000 is offline
Find More Posts by SKYRYDER1000
SKYRYDER1000's Avatar
NEW JERSEY U.S.A.
Joined Mar 2010
Here ya go T-CAT!
Description:
Description:
Description:
Description:
SKYRYDER1000 is offline Find More Posts by SKYRYDER1000
Old Jan 06, 2011, 08:02 PM
T-CAT is offline
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Thanks Sky!! That looks amazing man. That is one hell of a clean install with that thrust tube.
I have a couple questions. Was material is your thrust tube made of? When you cut it to size, do you allow overlap each side of the thrust tube, because then there would be a lifted area of material wrapped inside the tube? Do you secure your thrust tube with a certain type of tape like clear box tape, or a different method?
Thanks a ton. I need to do mine like you show for sure.
Old Jan 06, 2011, 09:06 PM
istandalone is offline
Find More Posts by istandalone
life is an oyster. shuck it!
istandalone's Avatar
bennington, VT
Joined Mar 2008
overlap is needed to secure the film. you'll need a spot to glue/tape on. the little lip that's created by it causes no ill effects.
istandalone is offline Find More Posts by istandalone
Old Jan 06, 2011, 09:11 PM
T-CAT is offline
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Awesome. Thanks a lot guy's. All the information has helped tremendously. Now, I need to test some out and practice building them .
Old Jan 06, 2011, 09:13 PM
bennington, VT
Joined Mar 2008
oh, for material it's good to use "drafting mylar" or largish overhead projector sheets.
Old Jan 06, 2011, 09:22 PM
T-CAT is offline
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Good call. I picked some clear projector heats already to try it out. Have you ever tried a paper soda cup (one if the large ones from fast food places)?
Old Jan 07, 2011, 02:03 AM
dro56595@bigpo is offline
Find More Posts by dro56595@bigpo
dro56595@bigpo's Avatar
Australia, ACT, Symonston
Joined Aug 2008
Just some pics of my second EF-16.
Same paint scheme as my first, but flies much better without all the repairs
dro56595@bigpo is offline Find More Posts by dro56595@bigpo
Old Jan 07, 2011, 03:24 AM
Bristol UK
Joined Aug 2010
Aw, Skyryder you beat me to it.
Well Tcat I guess a few more pics can't help, here you go , good luck although it should be pretty straight forward
Old Jan 07, 2011, 05:58 AM
T-CAT is offline
Loves Lasagna
T-CAT's Avatar
Joined Aug 2008
Thanks Tim, your pictures help a lot. It looks likethe exhaust diameter or rear of the thrust tube is the same size as the side that attaches to the fan. I've read that between 80-100% FSA oaths standard for exit diameter of the tube. Even at 100% FSA, do you measure/feel a difference in top end speed with the tube vs. without the tube?
Thanks again. You guy's are awesome.
Help! Phase 3 Hobbypeople F16- build tips? Smokescreen38 Foamy EDFs 101 Jun 07, 2016 09:53 PM
Discussion Phase 3 - Hobbypeople F16 UPGRADES (cont.) Flying Beagle Foamy EDFs 13 Nov 10, 2010 02:54 AM
Discussion Phase 3 - Hobbypeople F16 UPGRADES ducatirdr Foamy EDFs 11482 Nov 09, 2010 10:05 PM
Wanted Phase 3 F16 body dmize Aircraft - Electric - Jets (FS/W) 0 Oct 01, 2010 10:36 PM
Sold Phase 3 f16 arf NorCal Hobbies Aircraft - Electric - Jets (FS/W) 1 Sep 02, 2010 07:30 PM
