Old Dec 24, 2012, 07:33 PM
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Joined Mar 2006
Originally Posted by Great_Goose View Post
Holly crap that F-16 is fast. Aren't you suppose to be recovering from your mountain bike accident?
I am but I cant twiddle my thumbs all day long, am giving myself 30 mins online in the morning just to catch up, would go stir crazy otherwise.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Dec 25, 2012, 12:58 AM
efflux RC's Avatar
Valencia, CA. USA
Joined Aug 2009
Here's another.
It's not 4s
it's not a 70mm
it's not efficient like a Honda
It is heavy, hard to fly, and it is a hand launched Phase 3 F-16.......
173 mph Phase 3, F 16 (0 min 44 sec)
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Dec 25, 2012, 03:01 AM
The Ayatollah of Rock & Rolla
StickHack's Avatar
United States, MO, Springfield
Joined Dec 2011
Originally Posted by SteveC68 View Post
Is the light on the receiver blinking when you land?
No blinking lights, and the antenna on the TX is straight.
StickHack is offline Find More Posts by StickHack
Old Dec 25, 2012, 04:31 AM
norstaroption's Avatar
Pacifica, CA USA
Joined May 2009
I just picked up 2 of these jets, any 3s setup recommendation. I'm doing some thread searching right now.
norstaroption is offline Find More Posts by norstaroption
Old Dec 25, 2012, 06:02 AM
FlyHighSelllow's Avatar
United States, FL, Orlando
Joined Jul 2010
Seems like I remember seeing it mentioned but cant find it but whats the solution for losing altitude in turns ? It seems like im losing more than I should etc.
Still getting used to tailerons only but man she is quick.
FlyHighSelllow is offline Find More Posts by FlyHighSelllow
Old Dec 25, 2012, 06:11 AM
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
Don's WickedRC is definitely an option to consider.
See post #2 in this thread or contact him directly
http://www.rcgroups.com/forums/showthread.php?t=1673281
http://donsrc.com/cart/
ltc is offline Find More Posts by ltc
Old Dec 25, 2012, 08:48 AM
United States, CO, Keystone
Joined Feb 2011
Up elevator
smccrory60 is online now Find More Posts by smccrory60
Old Dec 25, 2012, 09:54 AM
Pacifica, CA USA
Joined May 2009
Old Dec 25, 2012, 10:06 AM
Joined Jul 2010
Originally Posted by smccrory60 View Post
Up elevator
Yeh yeh yeh. I knew id get it so now that we have that out of the way
Is it still nose heavy or is it mixing or ?
Old Dec 25, 2012, 10:30 PM
Gnfghtr's Avatar
United States, CO, Eagle
Joined Oct 2010
I picked up the MM esc fairing for my jet. I notice that the fairing will run right up to where I am installing the fan, but does not sit flush with the top of the fuselage. The fan shroud will sit flush and I was wondering if that disruption in the airflow where the shroud and the fairing meet will cause a problem? It appears that the fan will be pulling air from both sides of the esc fairing.
Also, how flush does the esc fairing have to sit up against the front? If I slide it from front to back, do I stop when the nose lays down flat? Or do I need to force it a little farther forward?
Gnfghtr is offline Find More Posts by Gnfghtr
Old Dec 25, 2012, 10:54 PM
Extreme_RC's Avatar
Joined Mar 2006
Its not efficient like a honda... LOL thats funny, actually no its not, must be the concussion playing tricks with my head
Goose: My 2W20 powered F16 was not 'that' fast, 200k is about the enjoyable limit for me when it comes to constant WOT flying with small models, I like to enjoy watching the model for more than 1.76 nanoseconds Give me a large model and 250k is no issue.
The 2W18 and wemo fan was the nicest 4s balance of all, 800w and 135mph so light and nimble, really flies like a jet, bank and yank, doesnt drop in turns unless you are really slow.
norstaroption: One of the old trusted 3s setups is the HET 2W motor, 4700Kv, running in the 6904 fan. Or a little milder in the Minifan. 50-55A in the 6904 fan and scoots along nicely.
Old Dec 26, 2012, 01:51 AM
Pacifica, CA USA
Joined May 2009
Ok thanks, I was going to order the EDF combo electronics from hobbypartz at cheap price but wasn't sure whether to get the 64mm or the 70mm.
I'll check your recommendation also. I fly 90% helis but would like to fly a jet when the sky is crowded so I'm not planning to put a lot of cash in it.
Old Dec 26, 2012, 02:05 AM
that's gonna leave a scar
KCinNC's Avatar
Marina Village, NC
Joined Aug 2007
hey man...this thread gets way out of human conception if you don't keep up! not sure if you got the basic kit version....no electrics at all....
or RTF all electric needs reciever ???
KCinNC is offline Find More Posts by KCinNC
Old Dec 26, 2012, 09:06 AM
Pacifica, CA USA
Joined May 2009
Basic kit only and electronics.
Old Dec 26, 2012, 09:32 AM
kelloggair's Avatar
centennial/aurora colorado
Joined Mar 2008
ok, so i can now officially start on my f-16, i am planning on running the 70mm rc lander 5 blade fan setup with a 60 amp esc and a 3500 4s battery. i have box sheeted the pylons in 1/64 bass wood with epoxy in addition to the reinforcement suplements the kit included. i have hogged the canopy to acomidate my battery and reinforced with some flat carbon rod. i am thinking of glassing the battery compartment along with adding some arrow shaft carbon to the wing joins. i have fitted the lander fan unit into the duct at the recomended location the supplement suggests for 70mm 4 s setups. i will check cg once i am ready to officialy setup the fan unit. i am thinking of glassing the entire airframe but am unsure and may just wbpu rather then glass? i have the esc fairing kit and landing skid kit from morgan mills that i will be useing. im planning on metal or nylon gear servos, metal gear being the prime option but most expensive. if i do not glass my airframe should i put a carbon arrow shaft lengthwise in the fuse or could that be considered overkill for my setup? more to come
kelloggair is offline Find More Posts by kelloggair
Help! Phase 3 Hobbypeople F16- build tips? Smokescreen38 Foamy EDFs 87 Feb 22, 2011 08:01 AM
Discussion Phase 3 - Hobbypeople F16 UPGRADES (cont.) Flying Beagle Foamy EDFs 13 Nov 10, 2010 02:54 AM
Discussion Phase 3 - Hobbypeople F16 UPGRADES ducatirdr Foamy EDFs 11482 Nov 09, 2010 10:05 PM
Wanted Phase 3 F16 body dmize Aircraft - Electric - Jets (FS/W) 0 Oct 01, 2010 10:36 PM
Sold Phase 3 f16 arf NorCal Hobbies Aircraft - Electric - Jets (FS/W) 1 Sep 02, 2010 07:30 PM
