Old Dec 20, 2012, 03:36 PM
FlyHighSelllow is offline
Find More Posts by FlyHighSelllow
Champagne Supernova
FlyHighSelllow's Avatar
United States, FL, Orlando
Joined Jul 2010
Originally Posted by PAPE View Post
33oz will hand launch and fly fine as long as the CG is correct. I have flown f-16s from 20oz to 32oz and they will all fly perfect. At 33oz if its to nose heavy (big lipo) the nose will tend to drop on turns. So just get the CG correctly.
So where do you suggest the CG be ? Set per manual or ?????
FlyHighSelllow is offline Find More Posts by FlyHighSelllow
Old Dec 20, 2012, 08:13 PM
smccrory60 is offline
Find More Posts by smccrory60
United States, CO, Keystone
Joined Feb 2011
I've balanced all of mine at the front edge of the cheater holes which is whithin the recomended range.
smccrory60 is offline Find More Posts by smccrory60
Old Dec 21, 2012, 01:49 PM
Champagne Supernova
Joined Jul 2010
Roger that. Thats about where mine is ending up maybe a little forward of that. Might be a little nose heavy...............
Old Dec 21, 2012, 03:11 PM
PAPE is offline
Find More Posts by PAPE
Joined Jun 2012
thats were I balance them also.
PAPE is offline Find More Posts by PAPE
Old Dec 21, 2012, 05:30 PM
voxel is offline
Find More Posts by voxel
United States, FL, Altamonte Springs
Joined Jun 2012
I built a new EF-16 and noticed that blue thread locker EATS through the EPS foam. I used it on the taileron pivots - which explains why my last EF-16 had loose tailerons (also spilled BTL but localized around the bushings).
voxel is offline Find More Posts by voxel
Old Dec 21, 2012, 08:58 PM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Blue thread locker will also eat plastic, so be careful where you put it...
Sammy70 is offline Find More Posts by Sammy70
Old Dec 23, 2012, 12:48 PM
jnail is offline
Find More Posts by jnail
United States, MN, Bemidji
Joined Jun 2011
Didn't know if anyone posted this/noticed this or not, But Hobby people has the kit version on sale for $29.99 right now. So I ordered one.
The number of pages on the threads for this plane are pretty overwhelming, so I am going to ask if someone can post a good recipe for motor/fan combination. I already have some 4s 2650 mah lipos for my HK vampire, so I would probably use those. I would like to make this jet fairly quick, but I don't want to dump a fortune into it, or get into the whole glassing thing.
jnail is offline Find More Posts by jnail
Old Dec 23, 2012, 02:18 PM
nom is offline
nom
Find More Posts by nom
nom
nom's Avatar
United States, ID, Boise
Joined Mar 2011
Can't go wrong with dons wicked motors...
nom is offline Find More Posts by nom
Old Dec 23, 2012, 02:43 PM
topher is offline
Find More Posts by topher
denver colorado
Joined Jan 2004
Het 2w/20 6904 fan. Will work perfect with your batts. Solid 120 mph.
topher is offline Find More Posts by topher
Old Dec 23, 2012, 03:25 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
As mentioned above, the HET 2W-20 and 6904 EDF is a great (light) 4s combo good for 120mph. Your 2650 mAh lipos are perfect. You'll need a 60A ESC.
Use a soup can with some 80 grit sandpaper to enlarge the fan mounting area diametrically. Mount the Fan 2" farther aft than the stock position, to compensate for the added weight of the bigger batts and ESC.
We can assemble the EDF and dynamically balance the EDF for you don't want to do it.
HP F-16s are great. We have setups from 750-2400W
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Dec 24, 2012, 02:03 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Early video of the F16 with 2W20/6904 combo, very affordable setup that works well in the F16, with 2600 45c packs a little down the track it was an easy 125mph.
Extreme RC F16 with HET fan & 2W20 motor (1 min 34 sec)
Extreme_RC is offline Find More Posts by Extreme_RC
Old Dec 24, 2012, 02:52 AM
StickHack is offline
Find More Posts by StickHack
The Ayatollah of Rock & Rolla
StickHack's Avatar
United States, MO, Springfield
Joined Dec 2011
I have the cheap Detrum 70mm setup in my first EF16. I have almost lost it twice due to signal failure / glitching on my DX7 and an Orange RX with Satellite. I swapped in an A6000 and had the same thing. Could it be vibration from the fan? I tried to remove the rotor but cannot get the screw lose on it. I have the 2w20 6904 for the next build. I like this plane, just scared to fly it due to the glitching, almost plowed it in last time up. It was very close, got it back at the last second just inches off the deck. Any input? I have a AR6200 with sat I can toss in it. Im to the point of sending my radio in for an update just to be sure.
StickHack is offline Find More Posts by StickHack
Old Dec 24, 2012, 03:14 AM
Great_Goose is offline
Find More Posts by Great_Goose
Flying from Vic Park
Great_Goose's Avatar
Australia, SA, Adelaide
Joined May 2011
http://www.youtube.com/watch?v=AIHoIZpt22Y
Holly crap that F-16 is fast. Aren't you suppose to be recovering from your mountain bike accident?
Great_Goose is offline Find More Posts by Great_Goose
Old Dec 24, 2012, 07:17 AM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Is the light on the receiver blinking when you land?
SteveC68 is offline Find More Posts by SteveC68
Old Dec 24, 2012, 07:52 AM
onefastxp is offline
Find More Posts by onefastxp
crashing build's character.
United States, AL, Dora
Joined Mar 2008
are you keeping your ant bent on your tx. i had trouble with mine when i kept the ant straight.
onefastxp is offline Find More Posts by onefastxp
Help! Phase 3 Hobbypeople F16- build tips? Smokescreen38 Foamy EDFs 101 Jun 07, 2016 09:53 PM
Discussion Phase 3 - Hobbypeople F16 UPGRADES (cont.) Flying Beagle Foamy EDFs 13 Nov 10, 2010 02:54 AM
Discussion Phase 3 - Hobbypeople F16 UPGRADES ducatirdr Foamy EDFs 11482 Nov 09, 2010 10:05 PM
Wanted Phase 3 F16 body dmize Aircraft - Electric - Jets (FS/W) 0 Oct 01, 2010 10:36 PM
Sold Phase 3 f16 arf NorCal Hobbies Aircraft - Electric - Jets (FS/W) 1 Sep 02, 2010 07:30 PM
