Old Dec 06, 2012, 07:22 PM
United States, CO, Keystone
Joined Feb 2011
Originally Posted by FlyHighSelllow View Post
Is anybody using the reinforcement backing they give you in the kit for the wings and stabilator's ? I'm going to use the decals and I'm wondering do I really use the reinforcement backing and put the decals over top ?
Use the reinforcement paper if you're not glassing, it adds a lot of stiffness to the foam.
smccrory60 is offline Find More Posts by smccrory60
Old Dec 06, 2012, 07:46 PM
FlyHighSelllow's Avatar
United States, FL, Orlando
Joined Jul 2010
Roger that and then decals over top. Can I use the soapy water method when using the paper? What is that stuff. Never seen it before.
FlyHighSelllow is offline Find More Posts by FlyHighSelllow
Old Dec 06, 2012, 07:53 PM
Joined Jan 2011
I put the backing on my wings and tail on first build. Gives a nice smooth finish for paint. If you arent glassing the wings id use it.
stingeragents is offline Find More Posts by stingeragents
Old Dec 07, 2012, 11:51 PM
The Ayatollah of Rock & Rolla
StickHack's Avatar
United States, MO, Springfield
Joined Dec 2011
I embedded two thin carbon rods in the top of each pylon extending into the fuse about 4 inches, then encased the pylon in ply using the templates, except I added a top piece as well. I used 1/64 ply instead if 1/16, then coated the entire thing in epoxy. Its strong enough now you can grab it by the pylon and wave it around . If it breaks here before it breaks any other place I will be surprised.
Now what kind of paint sticks to epoxy? I need to paint the pylons, they stick out like crazy covered in ply.
StickHack is offline Find More Posts by StickHack
Old Dec 08, 2012, 12:19 AM
Life begins at transition
Australia, WA, Perth
Joined May 2007
um, epoxy...
Rough it up with 40 or 80 grit, and PU (gorilla) also works reasonably well.
Odysis is offline Find More Posts by Odysis
Old Dec 08, 2012, 03:22 AM
tim.fuggdesign's Avatar
Bristol UK
Joined Aug 2010
Build blog
http://www.rcgroups.com/forums/showthread.php?t=1367032
has info on reinforcing wings, balancing tailerons etc..
Also couple of not so good vids of it on stock 3 cell set up , Personally quite like it on 3 cells, super light so landings are a breeze
Good luck with the rest of the build
tim.fuggdesign is offline Find More Posts by tim.fuggdesign
Old Dec 08, 2012, 09:01 AM
Joined Jan 2011
Flyhigh, the paper are just stickers.they pull right off and stick on. As for my 2nd build, i just finished up glassing last night. Top, vertical stab, tailerons already painted. Just gotta paint the bottom, attach the tailerons and will be ready to fly. Ill post some pics once i get bottom painted. I ended up putting about 3 overlapping layers of fg on the pylons. Between that, the ply, and cf rod it will be a rock
Old Dec 08, 2012, 11:29 AM
StickHack's Avatar
Joined Dec 2011
Originally Posted by Odysis View Post
um, epoxy...
I meant paint, I was sleepy.
Old Dec 08, 2012, 08:17 PM
Joined May 2007
I'm yet to find a paint that doesn't stick to epoxy.
Sand with up to 400grit, degrease and you'll be golden.
Old Dec 08, 2012, 08:55 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
untill you guys get it in your head ...all that c/f and ply wood does'nt change where the twisting is snaping off the tail ,you need to add the inner bushing .you can save a lot of weight just by using the inner bushings the inner bushing stops most of the twisting ....think about it .ok im done off my soap box ,enjoy your F-16's .....while they last
AIR SALLY is online now Find More Posts by AIR SALLY
Old Dec 08, 2012, 08:58 PM
Joined Jan 2011
lol. I'm doing the inner bushing as well, just haven't done it yet.
Old Dec 09, 2012, 12:30 AM
Joined Feb 2011
Originally Posted by air sally View Post
untill you guys get it in your head ...all that c/f and ply wood does'nt change where the twisting is snaping off the tail ,you need to add the inner bushing .you can save a lot of weight just by using the inner bushings the inner bushing stops most of the twisting ....think about it .ok im done off my soap box ,enjoy your f-16's .....while they last
^+1
Old Dec 09, 2012, 03:28 AM
efflux RC's Avatar
Valencia, CA. USA
Joined Aug 2009
+2
"Boxing" the pylons with 1/32 aircraft ply and the inner bushings is plenty good enough. Don't coat it with epoxy. Your just adding weight.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old Dec 10, 2012, 01:52 PM
Joined Jan 2011
Heres my 2nd one fully glassed.
Old Dec 10, 2012, 08:13 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
nice it looks like it going so fast it is heating up like the space shuttle doing mach 25
Help! Phase 3 Hobbypeople F16- build tips? Smokescreen38 Foamy EDFs 87 Feb 22, 2011 08:01 AM
Discussion Phase 3 - Hobbypeople F16 UPGRADES (cont.) Flying Beagle Foamy EDFs 13 Nov 10, 2010 02:54 AM
Discussion Phase 3 - Hobbypeople F16 UPGRADES ducatirdr Foamy EDFs 11482 Nov 09, 2010 10:05 PM
Wanted Phase 3 F16 body dmize Aircraft - Electric - Jets (FS/W) 0 Oct 01, 2010 10:36 PM
Sold Phase 3 f16 arf NorCal Hobbies Aircraft - Electric - Jets (FS/W) 1 Sep 02, 2010 07:30 PM
