Old Nov 25, 2010, 07:57 PM
bdp3822 is offline
Find More Posts by bdp3822
bdp3822's Avatar
Honolulu, HI
Joined Jun 2007
Great Idea!!
Originally Posted by Tinkasochi View Post
I would suggest putting some thin (2 or 3mm) depron over the wiring in front of the fan with a hole cut out for the esc to cool. It will make a huge difference reducing drag over the wires and hot glue. A large styrofoam cup would work well too. It's already shaped for you.
I used a plastic water bottle which I slit from bottom to top and reshaped the diameter to fit right up to the fan lip. I did not cut a hole for the ESC because I have a cooling hole in the canopy. I closed the cheaters about 90% to allow the canopy inlet to exhaust around by water bottle intake and out cheater holes.
bdp3822 is offline Find More Posts by bdp3822
Old Nov 27, 2010, 07:45 PM
lroughton is offline
Find More Posts by lroughton
Wherever you go- There you are
Rancho Cucamonga,CA
Joined Aug 2008
Ups-2
I just finished my 3rd EF-16. I used the same paint scheme as the last. I used Air Sally's inlet duct, inlet lip, nose cone, tail cone. I just want to say that everything fit like a glove. I can't say enough about his workmanship. I used my existing motor,fan, and ESC. The only damage from the previous EF-16'S crash was to the impeller, a servo wire, and of course the fuselage. I may maiden it tomorrow if the weather permits. I using the E-Flight Delta-15 fan with the recommended motor and ESC. I'm hoping for about 120mph. I will try and upload a picture.
Cheers--------Larry
lroughton is offline Find More Posts by lroughton
Old Nov 27, 2010, 08:38 PM
jriley1974 is offline
Find More Posts by jriley1974
Angry Flyer!
jriley1974's Avatar
washington state
Joined Oct 2008
wow, nice! Did you mod the tail?
jriley1974 is offline Find More Posts by jriley1974
Old Nov 27, 2010, 08:54 PM
nickelbn1 is offline
Find More Posts by nickelbn1
fly and then fly some more!
nickelbn1's Avatar
Springdale, AR
Joined Dec 2006
that is super nice Iroughton! I am tempted to pay you to do one for me! I dont think I could do one that nice. how long did it take you to do that?
nickelbn1 is offline Find More Posts by nickelbn1
Old Nov 27, 2010, 09:08 PM
Rancho Cucamonga,CA
Joined Aug 2008
jriley 1974,
Yes I did all the tail mods. I boxed it all in with plywood and balanced the tailerons with nickel inserts. I added the inside bushing to stiffen it up.
I also added 2 c/f tube spars on each wing. I did not glass the entire plane just the bottom intake hatch cover. It is epoxied on for additional strength. I also added two flat c/f strips below the battery because so much hogging out of the foam took place to fit the intake duct. If I ever need to get to the motor or esc, I will have to cut the hatch off and re-glue it on. Wish me luck on the maiden. The only reason I'm nervous is because there are no cheaters and that seems to effect different set-ups in different ways. Cheers-----------Larry
Old Nov 27, 2010, 09:58 PM
Sammy70 is offline
Find More Posts by Sammy70
PSALM 14:1
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Looks GREAT!! Just needs a pilot figure in there to be complete
Sammy70 is offline Find More Posts by Sammy70
Old Nov 28, 2010, 12:18 AM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Cheers--------Larry
That's a slick paint job. Looks Great!
Good luck on the maiden
cmala is offline Find More Posts by cmala
Old Nov 29, 2010, 04:03 AM
Si Goodchild is offline
Find More Posts by Si Goodchild
Si Goodchild's Avatar
Lincolnshire, UK
Joined Oct 2009
Cheers--------Larry
Jeez, that looks great! Is the paint job really as good as it looks in the photo? If so, perhaps you could offer a few tips for us mortals?
Si
Si Goodchild is offline Find More Posts by Si Goodchild
Old Nov 29, 2010, 05:03 AM
tim.fuggdesign is offline
Find More Posts by tim.fuggdesign
tim.fuggdesign's Avatar
Bristol UK
Joined Aug 2010
New Stock set up
Just thought this might shed some more light (or possibly not) on the 'stock set up' query.
I sent the below email to a few (UK) model shops , got one reply which i've added below. (well done rcmodel center)
Seems all is as before, maybe the 70mm was a packaging mistake, any one else found out any more on this?
'I've read on several forums that the EF16 is currently being shipped with a 70mm fan as opposed to the old 55mm units, however this isn't mentioned on either the box or the Phase 3 website.
I was just wondering if this was true, it seems that the fan unit comes with either a 4cell (3400kv) or 3 cell (3800kv) motor, but still the 30amp esc.
I'm looking to buy one of these kits from you but would like to know if I need to specify which version I would like, ie: 4 cell or 3 cell.
Kind regards
Tim Wood
This email was sent from http://www.rcmodelcentre.co.uk
Hi Tim,
Havent been told anything about this and havent got any different versions instock, so i think its just a rumor.
Warm Regards
tim.fuggdesign is offline Find More Posts by tim.fuggdesign
Old Nov 29, 2010, 07:46 AM
istandalone is offline
Find More Posts by istandalone
life is an oyster. shuck it!
istandalone's Avatar
bennington, VT
Joined Mar 2008
jesus those people are aggravating. it's not a friggin rumor lol. it's confirmed, some people did receive the 70mm fan.
istandalone is offline Find More Posts by istandalone
Old Nov 29, 2010, 08:17 AM
jmrust is offline
Find More Posts by jmrust
Once-ler
United States, FL, Gainesville
Joined Jul 2008
Fyi
I flew the squall this weekend on the 4s setup with the 70mm and it was pretty good! I would say ur are safe on the 4s motor w/ the 3s esc...barely pulls 30 amps wot static. Just a question if the esc can take 15 volts...
I'd even say the 3s motor could take 4s with the 4s esc.
Originally Posted by istandalone View Post
jesus those people are aggravating. it's not a friggin rumor lol. it's confirmed, some people did receive the 740m fan.
jmrust is offline Find More Posts by jmrust
Old Nov 29, 2010, 11:37 AM
blueapplepaste is online now
Find More Posts by blueapplepaste
blueapplepaste's Avatar
United States, TX, Keller
Joined Jul 2009
Kind regards
Tim Wood
Hi Tim,
Warm Regards
Yes they are being shipped with 70mm fans. From what I've seen some are getting the 4S 3 blade fan, others (like myself) are getting 3S 5 blade fans.
I'm assuming my motor is just 3S since the fan is for the 3S.
blueapplepaste is online now Find More Posts by blueapplepaste
Old Nov 29, 2010, 07:24 PM
sikky is offline
Find More Posts by sikky
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Rust that's on the way BTW 8:30am my time.
I think they know a 70mm fan is what we all want/need in this plane -how many are on the 55mm versus 70mm???
sikky is offline Find More Posts by sikky
Old Nov 30, 2010, 02:39 AM
Roto Rob is online now
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Mine came with the 4s motor, and 3 bladed fan. It only pulled 21.5 amps on 3 cells. But I'm at about 5700 feet altitude. I did bench run it on 4 cells, stopped advancing throttle when it got to 30 amps. Sounded nice, stock 30 amp esc got warm after a couple minutes throttled at about 20 amps. Been told the esc would burn up at 30 amps on 3 cells, and not last on 4. So thinking about upgrading the esc, since from the bench test it should really move along on 4 cells.
Roto Rob is online now Find More Posts by Roto Rob
Old Nov 30, 2010, 05:41 AM
WF Pilot is offline
Find More Posts by WF Pilot
Norway, Vestfold, Sandefjord
Joined Oct 2010
Mine came with 4s motor, and 5 bladed fan. Tested it with 2,65 nanotech`s 35C 4s from HC and got 720 watt at 48 amp. Running Het 55 amp regulator
WF Pilot is offline Find More Posts by WF Pilot
Help! Phase 3 Hobbypeople F16- build tips? Smokescreen38 Foamy EDFs 101 Jun 07, 2016 09:53 PM
Discussion Phase 3 - Hobbypeople F16 UPGRADES (cont.) Flying Beagle Foamy EDFs 13 Nov 10, 2010 02:54 AM
Discussion Phase 3 - Hobbypeople F16 UPGRADES ducatirdr Foamy EDFs 11482 Nov 09, 2010 10:05 PM
Wanted Phase 3 F16 body dmize Aircraft - Electric - Jets (FS/W) 0 Oct 01, 2010 10:36 PM
Sold Phase 3 f16 arf NorCal Hobbies Aircraft - Electric - Jets (FS/W) 1 Sep 02, 2010 07:30 PM
