Old Nov 14, 2012, 10:02 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Originally Posted by stingeragents View Post
Those all metal fans you sell look sweet. One day when i win the lotto ill order one. Unless u wanna hook a fellow rcgrouper up
Sure. I love to hook you up. $238+ shipping.
Until then, Here's what I'm putting into my Habu2 foamy.
Wemo rotor
Skyworld housing
Velocity-RC 3200kv motor
Caslte ICE 100 ESC
2550+watts.
For 1500 watts or less, the plastic housing is fine. The Alum housing and heat sink is for the motor's sake.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Latest blog entry: Updated blog Oct 2014
Old Nov 15, 2012, 01:53 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Hmm 2550 watts for 64,600rpm? Thats a fair whack of watts wasted there, Wemo and HET 1W40 runs 64K rpm at 2080 watts with full size intake lip, the 1W40 would appear to be a pretty awesome motor.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Nov 16, 2012, 04:11 PM
stingeragents is offline
Find More Posts by stingeragents
Joined Jan 2011
Where would i go about fan placement. My manual has a guide for a 4s but not sure its taking into account a 70mm fan. Also my fan with intake ring will not fit. Should i take intake ring off?
stingeragents is offline Find More Posts by stingeragents
Old Nov 16, 2012, 04:13 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
You dont need the intake ring, you will likely need to sand out foam to get the fan to settle nicely in the fuse, and depending on the weight the fan will need to go around 10-20mm in front of the LE of the servo case.
With wemo/2W18 I had the fan about 15mm in front of servo, 80A esc in the normal location, and could get it to balance with both 2600 and 3200 4s packs.
Old Nov 16, 2012, 04:30 PM
Joined Jan 2011
Ok. Thanks. Im using 2200 packs so ill place it about 20 forward
Old Nov 16, 2012, 05:47 PM
efflux RC's Avatar
Joined Aug 2009
Most guys put the fan (any 70mm EDF) about 2" behind the stock postion. (very close to the servos, but not so close as to interfere with the thrust tube)
This will allow you to go with bigger batteries, For the smaller 2650's, you simply move the battery forward a bit. You have more battery options this way without have to redo things later.
Site Sponsor
Old Nov 16, 2012, 11:45 PM
Joined Jan 2011
All my electronics wont be in till tuesday. Glassed the elevons today as well as started glassing pylons. Canopy and latch are done. Gotta pick up a couple servo extensions. Still gotta decide on paint job and fix my airbrush. Will most likely be glassing the whole plane. At the very least the wings nose and underbelly. May just end up doing whole thing. Gotta finish this build and my f22 i been working on. Aiming to maiden this probably next thur
Old Nov 17, 2012, 11:28 AM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
yep my inlet duct for 70mm fans is set up for 2" aft of the stock location .
AIR SALLY is online now Find More Posts by AIR SALLY
Old Nov 17, 2012, 11:29 AM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
whats the kv on that one ?
Old Nov 17, 2012, 04:55 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
3300Kv, I havent had a chance to check one for Kv yet but HET are pretty good with their specs. Its a very long can and 180g in weight, solid motor.
Old Nov 17, 2012, 11:04 PM
smccrory60 is offline
Find More Posts by smccrory60
United States, CO, Keystone
Joined Feb 2011
Originally Posted by Airplanekid333 View Post
pretty basic but proud with my work
Looks good!!! However, speaking from experience, I would add some color to it so it doesn't disapear in the sky. My first one I painted in a blue and grey camo scheme, and it worked On my first lap it disapeared against the blue sky and clouds. Fortunatly I was able to salvage all the electrics, but the battery and airframe were toast!
smccrory60 is offline Find More Posts by smccrory60
Old Nov 18, 2012, 12:05 AM
voxel is offline
Find More Posts by voxel
United States, FL, Altamonte Springs
Joined Jun 2012
Wemo rotor
Skyworld housing
Caslte ICE 100 ESC
2550+watts.
Is this a 4s setup? Or 6s? Just bought 2 EF-16 kits (my current EF-16 is rather beat up) and 2 more Squalls (so much for no more belly landers) so am in the market for hop-ups... that also could transfer and be usable to bigger 70mm jets later
voxel is offline Find More Posts by voxel
Old Nov 18, 2012, 02:01 AM
efflux RC's Avatar
Joined Aug 2009
6s setup. (can also be flown on 5s with less power output.)
The bench test was done with 6s, 40c, 4000mAh, since that's what I have.
The Habu2 will fly with 3200's
We also have the HET 1W-40 (3300kv) in stock.
I haven't tested it yet either, but it's gonna pull higher amps. I'd probably run it with a Wemotec minfan Pro EDF, or Wemo rotor in an alloy housing.
Site Sponsor
Old Nov 18, 2012, 10:09 AM
Joined Jan 2011
Efflux, do you have that velocity motor? Also how many amps will that setup run
Old Nov 18, 2012, 02:20 PM
rlc2052 is offline
Find More Posts by rlc2052
Something Something RC
rlc2052's Avatar
United States, PA, Philadelphia
Joined Nov 2010
It's never a good idea to go with the sky camo paint scheme.
rlc2052 is offline Find More Posts by rlc2052
Help! Phase 3 Hobbypeople F16- build tips? Smokescreen38 Foamy EDFs 99 Aug 31, 2015 01:57 AM
Discussion Phase 3 - Hobbypeople F16 UPGRADES (cont.) Flying Beagle Foamy EDFs 13 Nov 10, 2010 03:54 AM
Discussion Phase 3 - Hobbypeople F16 UPGRADES ducatirdr Foamy EDFs 11482 Nov 09, 2010 11:05 PM
Wanted Phase 3 F16 body dmize Aircraft - Electric - Jets (FS/W) 0 Oct 01, 2010 11:36 PM
Sold Phase 3 f16 arf NorCal Hobbies Aircraft - Electric - Jets (FS/W) 1 Sep 02, 2010 08:30 PM
