Old Nov 16, 2010, 07:35 PM
SKYRYDER1000 is offline
Find More Posts by SKYRYDER1000
SKYRYDER1000's Avatar
NEW JERSEY U.S.A.
Joined Mar 2010
Originally Posted by The Don View Post
Is there any addendum in the manual or anything acknowledging the 70mm fan unit?
No! Not at all. The manual for this kit only mentions and shows the 55mm fan I still don't know what motor I have here.. I'm not sure If I have the 3400kv or the 3800kv. Either way when I ran this motor and 70mm fan it was drawing more than 30amps. So the 30amp esc it comes with can not be used. To make a long story short I chose not to use the 70mm and I went with the 55mm fan and a wicked 5400. I am more than happy
SKYRYDER1000 is offline Find More Posts by SKYRYDER1000
Old Nov 17, 2010, 03:04 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Mine has black motor wires, silver and red outrunner, and 3 bladed fan. Draws 21.5 amps, at about 35,000 rpm on an old 3 cell lipo.
A video and some pictures are posted a little earlier in this thread http://www.rcgroups.com/forums/showt...9#post16240128
I placed the fan so the end of the thrust tube was about even with the end of the tail pipe. It was about the manuals location for the 170 gram lipo. Placed receiver in manuals location, and 2500mah 3 cell lipo about 1 inch in front of the receiver.
Roto Rob is offline Find More Posts by Roto Rob
Old Nov 17, 2010, 08:31 AM
thrashmaster71 is online now
Find More Posts by thrashmaster71
thrashmaster71's Avatar
USA, NY, Buffalo
Joined Dec 2007
Originally Posted by blueapplepaste View Post
Here are pics of the fan unit, motor, and ESC that came with mine.
The end of my tube isn't round, more of an oval shape. Is this a problem? Should I try to straighten it out or just not worry about it?
I would think that once you push your tube through the tail cone, it will take care of the shape problem. Just make sure you glue your tailcone on straight.
thrashmaster71 is online now Find More Posts by thrashmaster71
Old Nov 17, 2010, 08:45 AM
cmala is offline
Find More Posts by cmala
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
So if I wanted to build another P3 F16 but not glass it, not use the A/S fiberglass parts and run it on 3S, what fan/motor combo would be best? Could I get at least 80 mph out of it? I bet it would fly a little better than the brick I have now.
cmala is offline Find More Posts by cmala
Old Nov 17, 2010, 11:36 AM
G-Forse is offline
Find More Posts by G-Forse
Denver, CO
Joined Nov 2007
What fan would you use? 70mm or other?
G-Forse is offline Find More Posts by G-Forse
Old Nov 17, 2010, 02:26 PM
cmala is offline
customstandoffs
cmala's Avatar
USA, AL, Madison
Joined Dec 2007
Doesn't matter to me but that was part of my question. The only fan I currently own is an HET 6904 but I assumed that it wouldn't be good for the type of setup I was referring to.
Old Nov 18, 2010, 04:08 PM
scotware is offline
Find More Posts by scotware
United States, MA, Milford
Joined Sep 2004
FWIW I have one with Don's 5400 motor & fan combo, P40 ESC, running on 3 cell 2350 25C Rhinos. 18oz before battery. The local constablary clocked it at 103mph on his radar gun. I did use the morgan mills strakes and internal half duct. 50 plus flights, might be showing a wee bit of wear, particularly after doing an unscheduled touch & go at speed through goose s@#t!
scotware is offline Find More Posts by scotware
Old Nov 18, 2010, 05:38 PM
dmize is offline
Find More Posts by dmize
United States, OH, Cleveland
Joined Feb 2010
what are those? got any links?
dmize is offline Find More Posts by dmize
Old Nov 18, 2010, 06:09 PM
catfish2 is offline
Find More Posts by catfish2
USA, TX, Tyler
Joined Oct 2010
I purchased mine 2 weekends ago from a lhs and got same 3 blade unit band black wired moter as Roto Rob. Date stamp on the price tag indicates the store received the kit in July. My fan tube was worse off, almost completly untaped. I just used clear packing tape to secure the long seam and to re-attach to the fan. No problems, got the maiden flight in last weekend using 3s battery.
catfish2 is offline Find More Posts by catfish2
Old Nov 18, 2010, 06:12 PM
catfish2 is offline
USA, TX, Tyler
Joined Oct 2010
Just received my strakes, hope to install and try out this weekend
http://www.morganmill.com/RC
Old Nov 21, 2010, 02:53 PM
jmrust is offline
Find More Posts by jmrust
Once-ler
United States, FL, Gainesville
Joined Jul 2008
OK Stats on the 4s 3blade squall fan that is going in the F-16s
4s 30c 1800mAh 16.7volts
350 watts WOT static
Only 31amps......
Sounds like this could use a light 5s...the esc is good for 45 amps
jmrust is offline Find More Posts by jmrust
Old Nov 25, 2010, 12:31 PM
jmrust is offline
Once-ler
Joined Jul 2008
Here are some pics of the newest build
CF added to tailerons up to trailing edge of wing. This is going to be the mild 100mph version with HET 6904, Turnigy 2636-3200kv on 4s. I epoxied the lower fuse and cut into 3 pcs to access the fan when I wanna get STOOOOOPID.
How about some action here ladies and gents?
Old Nov 25, 2010, 04:48 PM
Tinkasochi is offline
Find More Posts by Tinkasochi
Can anybody see it?
Tinkasochi's Avatar
Baker , FL
Joined Dec 2009
I would suggest putting some thin (2 or 3mm) depron over the wiring in front of the fan with a hole cut out for the esc to cool. It will make a huge difference reducing drag over the wires and hot glue. A large styrofoam cup would work well too. It's already shaped for you.
Tinkasochi is offline Find More Posts by Tinkasochi
Old Nov 25, 2010, 05:24 PM
jmrust is offline
Once-ler
Joined Jul 2008
Yeah, I forgot my slicker..thanks Tink. Got the wings and stab on. I have some 2 sided foam that I'll slap in there.
Old Nov 25, 2010, 07:52 PM
bdp3822 is offline
Find More Posts by bdp3822
bdp3822's Avatar
Honolulu, HI
Joined Jun 2007
Stock motor/fan setup.
Quick question about the stock config... what should the stock exit diameter be? Ive upgraded mine and am helping a friend set up a different plane with my stock setup.
Thanks in advance.
Bryon
PS Ive changed the outlet diameter for my upgraded F16 and have forgotten the original diameter.
bdp3822 is offline Find More Posts by bdp3822
Help! Phase 3 Hobbypeople F16- build tips? Smokescreen38 Foamy EDFs 101 Jun 07, 2016 09:53 PM
Discussion Phase 3 - Hobbypeople F16 UPGRADES (cont.) Flying Beagle Foamy EDFs 13 Nov 10, 2010 02:54 AM
Discussion Phase 3 - Hobbypeople F16 UPGRADES ducatirdr Foamy EDFs 11482 Nov 09, 2010 10:05 PM
Wanted Phase 3 F16 body dmize Aircraft - Electric - Jets (FS/W) 0 Oct 01, 2010 10:36 PM
Sold Phase 3 f16 arf NorCal Hobbies Aircraft - Electric - Jets (FS/W) 1 Sep 02, 2010 07:30 PM
