This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Nov 20, 2010, 10:58 AM
Pied727-200 is offline
Find More Posts by Pied727-200
east coast
Joined Oct 2008
Hi
returned from my trip , looked very carefully at this yesterday ,
with all the CMP parts , airframe ,fan/motor ,retracts /struts
pilots - using a castle 80 amp esc and 6s 30c 4000 pack,reciver ,servos and
weighing everthing I get 2875 grams.
the stock unit(fan/motor) has a 1700 kv motor , this being my
first large EDF and reading through I feel like this stock setup
will not have enough power .
not looking super speed but not looking for a vastly underpowered
model
Please suggestion's are most welcome
Pied727-200 is offline Find More Posts by Pied727-200
Old Nov 20, 2010, 01:50 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by Pied727-200 View Post
... using a castle 80 amp esc and 6s 30c 4000 pack, receiver, servos and weighing everthing I get 2875 grams....
Hi, you are quite a bit lighter than my estimate :
http://www.rcgroups.com/forums/showp...8&postcount=64
Your setup will be good for ca. 1300W which is a bit marginal on the T-45 ...
You need - as I mentioned above - a 20% headroom on the ESC to fly safely. Thus 64A x 6 x 3.5V = 1340W.
The Hawk / T-45 has a small thin wing with a relatively high wingloading no matter what batts you use ... it will not like flying too slow, it's not really a glider wing. For speed and acceleration you will generally need some half-decent power ...
Herb is offline Find More Posts by Herb
Old Nov 20, 2010, 01:55 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Originally Posted by jonnyspeed View Post
... I am wondering if 6s or 8s is the way to go. I wan to keep the amps down. I would rather have more flight time than max speed...
Welcome to the EDF world ... A jet needs speed and power which generally means shorter flying times - unless the setup is super-efficient. If you want long flighttimes get a glider
Having said that, you don't need to fly full throttle all the time. It is better (imo) & easiet on the batts, esc & motor to have a bit more power for takeoff & aerobatics and then throttle back a bit, than fly full bore all the time...
Old Nov 20, 2010, 03:03 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Hi
model
Pied,
If the fan you bought is indeed the Changesun unit as it appears in the CMPro photos, your kV is too low for 6S. You can either go up to 8S or get a motor with a higher kV... 1900. You should be the 1700-1800 watt range.
Last night I measured the dia of the exhaust tube at 72mm. This is the absolute lowest I would ever go but it will make for good top end speed. Testing will review how much thrust it robs though.
The good news is that today at the AZ Jet Rally I was able to procure most of the components I need for the build (servos, esc, wires, etc.)
Just need the retracts. I'm also thinking I may need an AR9000 because of the flaps, dual elevators, and rudder / steering servos. I have one in a 4 channel Kyosho Kelly that I may swap out since it's overkill for that plane.
chalmrast is offline Find More Posts by chalmrast
Old Nov 20, 2010, 04:20 PM
east coast
Joined Oct 2008
Herb
thank you ,for your help. I have been flying Rc for many
years , electric almost 10 years , just new to edf
I have the HL f-4 and F-16 both 70mm and the HL
su-34 and they fly well , but this is my first kit jet
I was going to buy the fly fly Hawk - but when I saw this
and the price was so cheap , and I do see what your saying
about the high wing loading,
chalmrast : it looks like the one on there site , what
1900 kv motor would you recomend?
it better to have more power and throttle back , then
be under powered
Old Nov 20, 2010, 06:08 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Raining all day ... have a bit of time to get some work done on the T-45.
Waiting for the motor & fan not much else left to do.
Pictures of the balsa spar :
Old Nov 20, 2010, 06:10 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
After gluing in the CA hinges, I added blenderm hinge tape on the bottom side for added safety & hinge gap seal.
Old Nov 20, 2010, 06:13 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The two $7 PZ pilots turned out satisfactory ... they really improve after getting rid of that bug green uniform .
Old Nov 20, 2010, 06:27 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I was writing down for fun and reference the specs on various EDF Hawks/T-45's (approx figures) :
E-Flite Hawk: WS=33'' WA =206sq in WT rtf 2.8 lbs price $160 (70mm)
Sapac Hawk: WS=37'' WA =279sq in WT rtf 3.7 lbs price $210 (70mm)
JetTeng Hawk: WS=43'' WA =?? sq in WT rtf 9.8 lbs price $600 (90mm)
CMP Hawk: WS=46'' WA =372 sq in WT rtf 7.1 lbs price $200 (90mm)
DS Hawk: WS=48'' WA =464 sq in WT rtf 7.5 lbs price $1150 (90mm)
Sapac Hawk: WS=52'' WA =524 sq in WT rtf 10.5 lbs price $650 (100mm)
Fox Hawk: WS=53'' WA =?? sq in WT rtf 12. lbs price $830 (110mm)
AMD Hawk: WS=55'' WA =992 sq in WT rtf 9.8 lbs price $300 (120mm)
Sapac T-45: WS=67'' WA =?? sq in WT rtf ?? lbs price $980 (JL Hawk)
All prices airframe only.
Edit: Quality often - but not always - comes at a price
Old Nov 20, 2010, 06:33 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Herb did you add any reinforcements to the cockpit base? I am not sure if the thin plastic can hold those pilots. They might puncture through on a hard landing!
What about that balsa spar? Did you do anything to reinforce it?
Wow based on that list this CMP Hawk is a bargain!
Steph280 is offline Find More Posts by Steph280
Old Nov 20, 2010, 06:56 PM
MFALLON is offline
Find More Posts by MFALLON
MFALLON's Avatar
Sapac Fl.
Joined Oct 2007
here is another two
Sapac 100mm
Wing Span: 51.51"
Wing Area: 3.64 SQ./FT
All Up Weight: 10-11 lbs
Wing Loading: 44-48oz SQ./FT
$649.00
1/6 scale sapac 127mm
T-45 ARF
Scale: 1/6
Wingspan:67"/1700mm
Length: 71"/1800mm
$980.00
MFALLON is offline Find More Posts by MFALLON
Old Nov 20, 2010, 07:06 PM
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
AMD Hawk
Here's another:
AMD BAE Hawk $299.00:
Wingspan = 55.1"
Wing Area = 64sq. dm
AUW = 4300-4500g
Wing Loading = 76.9g/sq dm
http://www.rcmart.com/catalog/rc-pla...a-p-12059.html
AMD T-45 Hawk W/ 120MM Dyn-E-Max Fan 2nd Flight (4 min 24 sec)
Old Nov 21, 2010, 01:15 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
The PZ pilots, besides being a really good bargain, are quite light. The whole cockpit dressing (with pilots) only added 0.9 oz
... What about that balsa spar? Did you do anything to reinforce it? ...
I looked at the mains retract mounts again, from the other side ... there's plenty of thin ply. I was wrong. It seems they are well made, I will keep it the way it is for now. I added a thin fillet of 30min epoxy mixed with microballons to where the ply retract boxes join edges. It should be fine, I hope . It is really a well designed kit for it's price.
Old Nov 21, 2010, 01:20 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
I agree Herb I went in with hysol around all the wheel well boxes but didn't think it really needed any beefing up.
rvincent is online now Find More Posts by rvincent
Old Nov 21, 2010, 05:38 PM
sikky is offline
Find More Posts by sikky
speedin n da weeds :)
sikky's Avatar
USA, AZ, Glendale
Joined Feb 2008
Any flight reports yet??
BTW whats hysol??
sikky is offline Find More Posts by sikky
Question CMPro T-45? gp125racer Nitro Planes 5 Dec 22, 2010 06:42 PM
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Discussion Im In love with this T-45 Goshawk mikes68charger Electric Ducted Fan Jet Talk 3 Nov 06, 2010 12:23 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Off Site Sapac T-45 Goshawk Composite TokageWeasel Aircraft - Electric - Jets (FS/W) 3 Oct 06, 2010 10:24 PM
