I think that fan is way too heavy for the T-45 !
The T-45 airframe (fuselage) is already heavy to start with, so you need to pick very lightweight components - otherwise you will end up with a flying brick. I suggest you look at a lightweight fan setup like WeMoTec Midifan, DS-51, Change Sun, Het 90mm fan etc. You can always use the heavier fan in a bigger model that requires 3k+ watts... 8S 3000 or 9S 3000 sounds fine, but again lighter is better ... if you want to fly longer then get a second pack I don't own any CC controller so I don't have any experience with them. |
Latest blog entry: BAe Hawk 90mm EDF
Canopy mod
Corsair,
Can you tell me how u did your canopy mod. I like how you cut it. My question is how do you secure it. With tape. I'm planning on doing the same. Any info would be helpful Manny Quote:
Fan/Motor question
Does anyone have any idea how this model would behave with the E-flite Delta-V32 fan and BL32 DF motor? It's only an 80mm fan but it seems to push the Habu32 around the sky pretty well.
The E-flite fan and motor are both pretty inexpensive .... should that fact scare someone or is it just a factor of mass production? Thanks |
Maiden
I maidened my third hawk today, first flight the esc went into thermo shut down. And it was brought down with no problems.
Second flight, same thing. Esc is the dlux turnigy 100a. Changesun motor and fan, 6s 5000 40-50c packs. I really don't know y it did that. I thought I had good cooling. |
| Thread Tools | |
| Question CMPro T-45? | gp125racer | Nitro Planes | 5 | Dec 22, 2010 06:42 PM |
| Discussion Nitroplanes CMP 90MM T-45 Hawk | FlyBoyTha1 | Electric Ducted Fan Jet Talk | 216 | Nov 10, 2010 12:24 PM |
| Discussion Im In love with this T-45 Goshawk | mikes68charger | Electric Ducted Fan Jet Talk | 3 | Nov 06, 2010 12:23 PM |
| Cool New CMPro Composite T-45 90mm | chalmrast | Electric Ducted Fan Jet Talk | 5 | Nov 03, 2010 10:54 PM |
| Off Site Sapac T-45 Goshawk Composite | TokageWeasel | Aircraft - Electric - Jets (FS/W) | 3 | Oct 06, 2010 10:24 PM |
