Joined Feb 2004
Here you go should be ready in a short while,
The video and flying are excellent !!
Very nice !!You are being way too modest, I do like those puffy white clouds as background, gorgeous british weather. The sound of the WeMoTec Midi balanced rotor in the Jepe assembled fan is one hundred times better than my HET fan sound (they did a poor job balancing the HET 90 rotor). Performance looks very similar. Also yours has the same wooshy sound of the intakes like mine. I think you will have shorter landings when you will develop the courage to slow it down a bit more, and maybe move the CG back a tad ... |
Latest blog entry: BAe Hawk 90mm EDF
Joined Feb 2004
Hi Herb,
If you like a nice sounding wemo try this one, ![]()
messed up the landing a bit but I do like this plane, shame its a foamy! |
Joined Feb 2004
Interesting analysis of the cog issues here; page 20 post 299
http://translate.google.co.uk/transl...%26prmd%3Divns bit hard to follow but we get the picture. |
The T-45 is a good flier but feels a bit draggier and heavier than my other 90mm edf jets, I tend to limit aerobatics to some rather basic stuff.
The T-45 needs flaps maybe for looks only imo, it lands just fine & slow without flaps due to that thick wing ! The elevators need some smaller servos, I have some 9g Futaba servos in there. The Hitec HS-125 slims will work well for the ailerons, I also like these BlueBird digital ones they look very similar, I bought a bunch: http://www.hobbyking.com/hobbyking/s...idProduct=8957 http://www.hobbyking.com/hobbyking/s...idCategory=298 Bluebird servos are generally very good quality, as good if not better than HiTec. I have no experience with the HET servos, they are probably made by some china outfit and re-labelled as het. Maybe they are fine. . |
![]() After watching all the dust that had accumulated on mine flying at the field over the weekend, I freshened up the paint a bit with future: . |
Joined Feb 2004
Hi Herb,
With the rafale test flight I was expecting the usuall dip straight after take off even though I let it build a lot of speed but it nearly caught me out. The rest of the flight it was sort of flying me as I was trying hard to catch up with it so to speak. The landing was the easiest part just point it in the right direction and slowly let the speed bleed off holding the nose up. I was amazed at the trim after the flight there was a good deal of up maybee 5mm in the right elevon and about 3 in the left. I will get round to fly it again but probably not this year to much bulding and testing to do. more photos of the electric only event it was madiened at here, http://greenacresmac.co.uk/Images/Funflys/e%202009/ A great field as it was a Spitfire base during the war. |
How did I attach the canopy? I guess you are talking about attaching the finished canopy to the body of the plane
http://www.hobbyking.com/hobbyking/s..._10pcsbag.html In front I used a wood block to hold a wooden dowel 1/8in then glued another block of wood with a 1/8in hole for the dowel to go into. In back I will be using a canopy lock from Hobby-king. Also I did make a frame for inside the canopy to give it some strength - no flexing or vibrating at max. speed. --1/16 by 1/8 plywood for the frame. One more item-the inside detailed cockpit is glued to the canopy so its all one unit. This way I can remove it and get to the battery without using any tools. |
| Thread Tools | |
| Question CMPro T-45? | gp125racer | Nitro Planes | 5 | Dec 22, 2010 06:42 PM |
| Discussion Nitroplanes CMP 90MM T-45 Hawk | FlyBoyTha1 | Electric Ducted Fan Jet Talk | 216 | Nov 10, 2010 12:24 PM |
| Discussion Im In love with this T-45 Goshawk | mikes68charger | Electric Ducted Fan Jet Talk | 3 | Nov 06, 2010 12:23 PM |
| Cool New CMPro Composite T-45 90mm | chalmrast | Electric Ducted Fan Jet Talk | 5 | Nov 03, 2010 10:54 PM |
| Off Site Sapac T-45 Goshawk Composite | TokageWeasel | Aircraft - Electric - Jets (FS/W) | 3 | Oct 06, 2010 10:24 PM |
