This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Nov 13, 2010, 02:23 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Originally Posted by Herb View Post
Rodger, I think some reinforcement there is absolutely crucial
There is NO way those main mounts can hold up to repeated abuse .. on Thursday I flew in 25mph winds so there's always that harder than normal landing . I think V2. needs stronger mains mounts.
I started putting some jb weld on the mains rails to get clean drilled holes for the retract mounts. Some 1/64 or 1/32 ply & laminating epoxy will go in there as well.
Regarding the main gear angle, things are not trivial unless you change the gear opening location. See what I mean:
Can you get an offset trunion so that the strut diameter doesn't interfere with the retract closing all the way?
I certainly wouldn't want to make the plane sit any higher than intended... usually I'm trying to lower the "stilt" legs that come with planes....
chalmrast is offline Find More Posts by chalmrast
Old Nov 14, 2010, 02:15 PM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Is it just me? I can't see that video from Rolf. Says private video.
Steph280 is offline Find More Posts by Steph280
Old Nov 15, 2010, 11:47 AM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Not sure what happened to that video ...
yes you can bend the struts a bit (actually I bend the pins) to make them fit in the wheel wells.
Herb is offline Find More Posts by Herb
Old Nov 15, 2010, 11:58 AM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Weight so far on mine is as follows (all in oz) :
wing complete with 4 servos & Springair 602's installed 17.0
fuse empty 27.6
hatches, intakes 4.6
elevators, elevator servos, joiner, rudder servo 3.8
sub-fin + hook 0.8
canopy 2.8
nosegear + steering 2.4
wheel collars 0.6
ducts & fan 6.6
esc (100A) + wiring 7.1
receiver battery 1.9
Springair air valve, servo & air tank 1.4
misc hardware 0.6
Neu motor 11.0
glue (est) 1.0
Airframe rtf w/o batteries 86.6 oz = 5.4 lbs
9S 3000's 30.1 oz
9S 4000's 39.2 oz
Weight rtf (est.) 86.6 + 30.1 = 116 oz = 7.2 lbs = 3.29 kg
Old Nov 15, 2010, 12:02 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Esc (here actually 120A) + necessary wiring
Old Nov 15, 2010, 12:06 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
By bending the pin I was able to fit the HK oleos.
The Springair strut alternative comes with a coil.
Old Nov 15, 2010, 12:07 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Nice I figured it would be close to 8lbs all up. Have you fitted your ducts yet?
rvincent is offline Find More Posts by rvincent
Old Nov 15, 2010, 12:11 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Nose gear options:
Bae Hawk - style nosegear (simpler) vs. T-45 - style nosegear (cuter) :
Old Nov 15, 2010, 12:14 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Nosegear mount - like mains mounts - looks a bit on the weak side.
I put two hardwood rails in...
Old Nov 15, 2010, 12:20 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Yes ... duct fitting .. the center piece needs to be trimmed a bit.
But the ducts are nicely made. The WeMoTec MidiFan or similar is a perfect fit.
I am out of carbon tow, waiting for my carbon tow & carbon cloth from the composite store.
Old Nov 15, 2010, 12:28 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
On the original T-45 the nosegear is quite short ... In turbine setups this can cause problems due to the Hawk getting glued to the tarmac on takeoff, esp. when the model has a negative wing incidence.
My nosegear strut will be a bit longer than scale, to give a positive stance.
Old Nov 15, 2010, 12:32 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Someday the CMPro T-45 pilots will be available ... in the meantime I was looking for a 1:9 scale (actually to be picky, 1:9.8 from the fuse and 1:8.2 from the wing) pilot.
Needless to say, I opted for the Parkzone one (x2) for now . It will need a new paint job...
http://www.horizonhobby.com/Products...ProdID=PKZ4414
Old Nov 15, 2010, 01:38 PM
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
The Parkzone pilots are a good value. They are made of soft rubber and the body is easily trimmed with a scissors for height adjustments.
I used them in my L-39.
I also have two pilot figures I bought from Nitroplanes a while back that are very nice but I think they are too big for this bird. They look very similar to the CMPro units.
http://www.nitroplanes.com/rcmodelpilot9.html
Old Nov 15, 2010, 07:57 PM
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Please PM me if I'm bothering you on your Build log....
I received my plane today.... a little smaller than I was expecting. Very close in size to the ProEDF 90mm planes (my buddy has the Mig 15, Mig 29, & F-18).
I don't see why this plane won't fly great on a nice 6S, 2000W setup. It will be in 6.5-7.0lb range. As I said earlier, my buddy's Mig 15 goes 120MPH on 6S.
I took the Nitroplane's pilots and set them in the super thin cockpit. Do you think they are the right scale or are they too big? The rear pilot's head is hitting the canopy so his body will have to be trimmed to make him a little shorter. Both will require a few millimeters shaved off their shoulders...
Edit: OK I just looked at some T-45 pics and these guys are too big. Could probably get away with them if they are shortened 1/2" or so.... not trying to place in a TopGun qualitfier here so these guys might just stay!!
Old Nov 16, 2010, 08:33 AM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
I think they look great!! A wee bit big but the others will look like midgets
Question CMPro T-45? gp125racer Nitro Planes 5 Dec 22, 2010 06:42 PM
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Discussion Im In love with this T-45 Goshawk mikes68charger Electric Ducted Fan Jet Talk 3 Nov 06, 2010 12:23 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Off Site Sapac T-45 Goshawk Composite TokageWeasel Aircraft - Electric - Jets (FS/W) 3 Oct 06, 2010 10:24 PM
