This thread is privately moderated by Herb, who may elect to delete unwanted replies.
Old Dec 03, 2010, 12:56 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Rob I mounted mine on a ply tray ... the cooling holes opening would have have to be drilled both inside and outside. I get some airflow from the front gear opening.
On my big F-86 I mounted a graphics card fan (3.5v) on top of the same esc. Works very well, except new I can't remember where I got that tiny neat graphics card fan
Herb is offline Find More Posts by Herb
Old Dec 03, 2010, 12:58 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Fan hatch secured with a thin bead of ge silicone, & held down with masking tape for 2 days.
Old Dec 03, 2010, 01:02 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
Receiver battery assembled with high quality ultralow self-discharge Sanyo Eneloop cells , fantastic for receiver packs.
http://www.eneloop.info/home/general-description.html
4AA's with 2000mAh capacity, needed for 9 servos. 12 cell pack at costco + charger for $20.
Old Dec 03, 2010, 02:58 PM
Sunbather is offline
Find More Posts by Sunbather
Santa Rosa, CA
Joined Nov 2008
Originally Posted by RobNHood View Post
John - Did you run the HET fan in that set up or what fan was it?
Herb - What is the HC Esc you're referring to? Thanks for the fancalc link I am slowing figuring it out - very cool. Only wish it had the Changesun fan and a few more motors.
I used the Het 9305V2 for 700 series motors. I'm actually quite impressed with this fan. The feedback I got at the field was very positive due to the sound coming from the Super Sniper.
I used the TURNIGY K-Force 70A-HV OPTO Brushless ESC. It works very well.
http://www.hobbycity.com/hobbycity/s...idProduct=9130
Sunbather is offline Find More Posts by Sunbather
Old Dec 03, 2010, 03:10 PM
sherlockshah is offline
Find More Posts by sherlockshah
Joined Feb 2006
Just got mine NO damage to the fuse or parts
LOOKS real nice and scale. The elevators look small, you guys think it has enough surface area?
sherlockshah is offline Find More Posts by sherlockshah
Old Dec 03, 2010, 10:09 PM
Janusz Jawien is offline
Find More Posts by Janusz Jawien
Janusz Jawien's Avatar
Los Angeles Van Nuys, California, United States
Joined Apr 2002
Regarding the wing fences:
I am not an Hawk expert but IMHO the version we got from Nitro is a arcraft carrier version.... it will not have big and small wing fences because it has the movable leading edge,
If we want to avoid wing dropping tendencies we should add the vortex generators with a proper 10 deg. angles as marine version has them....
Just my two pennies....
Janusz
Janusz Jawien is offline Find More Posts by Janusz Jawien
Old Dec 04, 2010, 04:09 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
Freewing Retracts / Struts
OK, I received my $63.00 electric Freewing retracts / struts. As I posted earlier, the struts are going to be way too long and will have to be cut down.
Today I cut one of the struts down. I used a dremel w/ a heavy cut-off wheel. I then re-drilled the 4mm hole in the top. I will use the original spring retaining screw to now also work as a set screw. I then drilled & tapped the other side so there are two set screws again.
The spring is alot stronger than I was expecting. I thought in the pics they looked a little flimsy. But, it takes about 5-6lbs of pressure just to make the strut deflect. At 7+ lbs there is still room left to move. Notice how the wheels are squishing!!
The downside I see is that the body of the retract will not allow it to fit perfectly flush. There is about 1/8th of an inch of rib underneath that is stopping in from sitting flush. Debating about whether or not to sand it down....
chalmrast is offline Find More Posts by chalmrast
Old Dec 04, 2010, 06:30 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
I have a sneaky feeling Herb maidened his today Those earlier pics were a pretty much ready to fly model
rvincent is offline Find More Posts by rvincent
Old Dec 04, 2010, 06:33 PM
Herb is offline
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
It flew Twice
HD video later ...
Old Dec 04, 2010, 06:36 PM
RobNHood is offline
Find More Posts by RobNHood
Just plane addicted!
RobNHood's Avatar
Monterey, CA
Joined Jan 2007
Chalmrast - nice work they look great and affordable. Do they fit within the molded retract well when cut down? Looks like the trailing link geometry makes it a bit tricky.
RobNHood is offline Find More Posts by RobNHood
rvincent is offline
rvincent's Avatar
Joined Jul 2004
Ha-ha! I knew it
Well?
Old Dec 04, 2010, 06:47 PM
balistc1000 is offline
Find More Posts by balistc1000
balistc1000's Avatar
Chandler, AZ
Joined Nov 2008
Originally Posted by Herb View Post
It flew Twice
HD video later ...
Great and congrats!
balistc1000 is offline Find More Posts by balistc1000
Old Dec 04, 2010, 06:52 PM
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
No, it won't fit in that. I'll have to figure out what I'm going to do with that later... I have some ideas though
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
It flew Twice
HD video later ...
OHHH YEAH!!!! Best thing I've heard all day!!! Can't wait for the video & report!
Old Dec 04, 2010, 08:34 PM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Bob Herb is just playing with us ......cause he can .....
AIR SALLY is offline Find More Posts by AIR SALLY
Question CMPro T-45? gp125racer Nitro Planes 5 Dec 22, 2010 06:42 PM
Discussion Nitroplanes CMP 90MM T-45 Hawk FlyBoyTha1 Electric Ducted Fan Jet Talk 216 Nov 10, 2010 12:24 PM
Discussion Im In love with this T-45 Goshawk mikes68charger Electric Ducted Fan Jet Talk 3 Nov 06, 2010 12:23 PM
Cool New CMPro Composite T-45 90mm chalmrast Electric Ducted Fan Jet Talk 5 Nov 03, 2010 10:54 PM
Off Site Sapac T-45 Goshawk Composite TokageWeasel Aircraft - Electric - Jets (FS/W) 3 Oct 06, 2010 10:24 PM
